This is a good suggestion and only you can do and isolate the issue of your boards.
I've tested again and again my board here and be sure the issue is not caused by either the ArduinoCore-mbed v2.4.1, the LittleFS_Mbed_RP2040 v1.0.1 or WiFiManager_NINA_Lite v1.4.0.
Be sure to check if you're using the same core /library version
LittleFS_Test on Nano RP2040 Connect
With #define FORCE_REFORMAT true
Start LittleFS_Test on Nano RP2040 Connect
[LFS] LittleFS size (KB) = 64
[LFS] LittleFS Mount OK
Writing file: /littlefs/hello1.txt => Open OK
* Writing OK
Reading file: /littlefs/hello1.txt => Open OK
Hello from Nano RP2040 Connect
LittleFS_Counting on Nano RP2040 Connect
Start LittleFS_Counting on Nano RP2040 Connect
Times have been run = 1
=> Open to write OK
RP2040_WiFiNINA on MBED NANO_RP2040_CONNECT
After reformat => start over
Starting RP2040_WiFiNINA on MBED NANO_RP2040_CONNECT
[WN] Hostname=RP2040-Master-Controller
LittleFS Mount OK
Loading DRD file failed
Flag read = 0x0
No doubleResetDetected
Saving DOUBLERESETDETECTOR_FLAG to DRD file : 0xd0d01234
Saving DRD file OK
SetFlag write = 0xd0d01234
[WN] bg: isForcedConfigPortal = false
[WN] bg:Stay forever in CP:No ConfigDat
[WN] clearForcedCP
[WN] SaveCPFile
[WN] OK
[WN] SaveBkUpCPFile
[WN] OK
[WN] SSID=WIFININA_51F485,PW=MyWIFININA_51F485
[WN] IP=192.168.4.1,CH=4
F
Your stored Credentials :
Blynk Server1 = account.duckdns.org
Token1 = token1
Blynk Server2 = account.ddns.net
Token2 = token2
Port = 8080
MQTT Server = mqtt.duckdns.org
Stop doubleResetDetecting
Saving to DRD file : 0xd0d04321
Saving DRD file OK
LittleFS Flag read = 0xd0d04321
ClearFlag write = 0xd0d04321
Run normally
LittleFS Mount OK
Saving DRD file OK
[WN] CCSum=0x113d,RCSum=0x113d
[WN] CrCCsum=0x1480,CrRCsum=0x1480
[WN] Valid Stored Dynamic Data
[WN] ======= Start Stored Config Data =======
[WN] Hdr=WIFININA,SSID=HueNet1,PW=12345678
[WN] SSID1=HueNet,PW1=12345678
[WN] BName=Nano_RP2040
[WN] i=0,id=sv1,data=Blynk_server1
[WN] i=1,id=tk1,data=token1
[WN] i=2,id=sv2,data=Blynk_server2
[WN] i=3,id=tk2,data=token2
[WN] i=4,id=prt,data=8080
[WN] i=5,id=mqt,data=mqtt_server
[WN] con2WF:SSID=HueNet1,PW=12345678
[WN] con2WF:OK
[WN] IP=192.168.2.111
[WN] SSID=HueNet1,RSSI=-13
[WN] b:WOK
H
Blynk Server1 = Blynk_server1
Token1 = token1
Blynk Server2 = Blynk_server2
Token2 = token2
Port = 8080
MQTT Server = mqtt_server
Saving DRD file OK
HHH
