WiFiManager - proper way using callbacks?
My intention is to show messages on a LCD1602 to tell a person to connect to the WiFiManager portal to configure the WiFi.
Also to show message "Connected" when connected and "Disconnected" when disconnected.
Got so far so I realized that WiFiManager must run in "wm.setConfigPortalBlocking(false);" so other code can be executed in parallel to show/toggle messages on the display.
But how to get a flag set, to act upon, when in portal mode?
In the example:
    if(wm.autoConnect("AutoConnectAP")){
        Serial.println("connected...yeey :)");
    else {
        Serial.println("Configportal running");
Here it's easy to set a flag when entering "Portal Mode". But how to know when exiting?
I finally got it working by checking if IP 192.168.4.1 was present.. But it must be a more correct and cleaner way to do it?
Tried to implement this without success:
I just get a compile error :- (
I assume the documentation is a bit outdated since wifiManger.xxxx seam to have been replaces with wm.xxxx
I'm pretty clueless for the moment... Please help! How do I get a "bool portalRunning = true;"?
// WiFiManager in non blocking mode to toggle between messages on display.
// Also noticed that:
// Entering the wrong WiFi-password in config portal will fuck it up. Not possible to change to correct password. My code? Do not know.
// Solution seam to be a "wm.resetSettings();" or connect to another AP temorary.
LiquidCrystal_I2C lcd(0x27, 16, 2);  // I2C address 0x27, 16 column and 2 rows connected to SCL --> D1, SDA -> D2
#include <WiFiManager.h>             // https://github.com/tzapu/WiFiManager  (2.0.15-rc.1) Latest available @ 230121
WiFiManager wm;
  WiFi.mode(WIFI_STA);  // explicitly set mode, esp defaults to STA+AP
  lcd.init();  // initialize the lcd
  lcd.backlight();
  //reset settings - wipe credentials for testing
  //wm.resetSettings();
  std::vector<const char *> menu = { "wifi", "restart", "exit" };  // Added by me...
  wm.setMenu(menu);
  wm.setConfigPortalTimeout(60);
  //automatically connect using saved credentials if they exist
  //If connection fails it starts an access point with the specified name
wm.setAPCallback(configModeCallback);  // TEST --------------------   callback  -----------------------
  if (wm.autoConnect("MyPortal", "password")) {
    Serial.println("connected...yeey)");
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("Connected!!!");
    // } else {
    //   Serial.println("Configportal running");
    //   runningConfigPortal = true;
//****************************************************************** callback  ----------------
void configModeCallback (WiFiManager *myWiFiManager) {
  Serial.println("Entered config mode --------------------   callback  -----------------------");
  Serial.println(WiFi.softAPIP());
  Serial.println(myWiFiManager->getConfigPortalSSID());
void setBreakAfterConfig(boolean shouldBreak);
//wm.setSaveConfigCallback(saveConfigCallback);       // Get the following compile error if this line is not commented out:
/*/home/pepe/Arduino/AutoConnectNonBlocking_fred_test_callback/AutoConnectNonBlocking_fred_test_callback.ino:46:1: error: 'wm' does not name a type
   46 | wm.setSaveConfigCallback(saveConfigCallback);
exit status 1
Compilation error: 'wm' does not name a type
//flag for saving data
bool shouldSaveConfig = false;
//callback notifying us of the need to save config
void saveConfigCallback() {
  Serial.println("Should save config");
  shouldSaveConfig = true;
//************************************************* End of callback   *****************
unsigned int currentMillis;
unsigned int startMillis;
unsigned int WiFiErrorCount;
bool portalMode;
bool startingUp = true;
  wm.process();
  currentMillis = millis();
  if (currentMillis - startMillis > 2000) {  //test whether the period has elapsed
    String checkMode;
    checkMode = WiFi.softAPIP().toString();  // See if this returns 192.168.4.1 = Portal Mode. Did not manage to find any other way to get notice
    Serial.println(checkMode);               // of when exiting from "PortalMod".
    if (checkMode == "192.168.4.1") {
      Serial.println("###################################### IN PORTAL MODE ################### ");
      portalMode = true;
      startingUp = true;
      portalMode = false;
    Serial.print("Every second - WiFi.status is : ");
    Serial.println(WiFi.status());
    if (WiFi.status() == WL_CONNECTED) {  //
      lcd.clear();
      WiFiErrorCount = 0;
      startingUp = false;
    } else if ((WiFi.status() != WL_CONNECTED) && (portalMode == false)) {
      lcd.clear();
      lcd.print("NOT Connected!!!");
      lcd.setCursor(0, 1);
      lcd.print("Restarting.");
      lcd.print(WiFiErrorCount);
      WiFiErrorCount++;
      if ((WiFiErrorCount > 100) && (startingUp == false)) {  // Restart device after about 200 sec if no WiFi.
        ESP.restart();
    startMillis = currentMillis;
  if ((WiFi.status() != WL_CONNECTED) && (portalMode == true)) {  // Show configuration messages on display if no WiFi and in PortalMode.
    portalDisplayMessages();
    // futureCrappyCode();      // Code dependent on an active WiFi connection.
void portalDisplayMessages() {
  int currentMillis;
  static unsigned int startMillis;
  static unsigned int messageCount = 0;
  if (currentMillis - startMillis > 10000) {  //test whether the period has elapsed
    Serial.println("Running portal,  10 seconds message switch");
    switch (messageCount) {
      case 0:
        lcd.clear();
        lcd.print("AccessPoint:");
        lcd.print("MyPortal");
        messageCount++;
      case 1:
        lcd.clear();
        lcd.print("Password:");
        lcd.print("gggggggg");
        messageCount = 0;
