WiFiNINA Updater Error validating flashed firmware
Trying to update the Nina firmware on the UNO WiFi rev2 board and failing with error validating flashed firmware. I’m using IDE 1.8.12 and NINA firmware 1.3.0 for Arduino Uno WiFi Rev2 and the updater fails repeatedly after erasing the existing firmware, programming 986112 bytes with the message “Error validating flashed firmware”. I’ve tried earlier versions of NINA as well and get same failure. Also note that during the update, I get the following message on the updater in the ide: java.lang.Exception: Error validating flashed firmware
at cc.arduino.plugins.wifi101.flashers.java.NinaFlasher.updateFirmware(NinaFlasher.java:106)
at cc.arduino.plugins.wifi101.UpdaterImpl$2.run(UpdaterImpl.java:214)
And during the upload of the updater to the UNO board I get the following error: avrdude: WARNING: invalid value for unused bits in fuse “fuse5”, should be set to 1 according to datasheet
This behaviour is deprecated and will result in an error in future version
You probably want to use 0xcd instead of 0xc9 (double check with your datasheet first). I don’t think that last bit is relevant but for completeness I included it.
I would really like to get this fixed since now the WiFi is totally broken.
SOLVED -- Used an external power supply instead of just the USB connection and lo and behold the update worked.
Well, it worked once, but trying to do it again it fails repeatedly again. Would really appreciate some help from Arduino here!
Bought another board (from Arduino) and it too fails to verify the update. Are these boards just bad or there something wrong with the updater? I've tried using external (not USB) power and still no luck. As I stated in my original post it did work once but then kept failing repeatedly in the same configuration. Does anyone else have this issue?
