I am trying to GET the daily peak power output from my uploaded data from my PVOutput.org account.
My Arduino MKR1010 does not connect to the server!!!
All I get is the "disconnecting from server" message after about 10sec.
The data does exist as I can get it manually typing the following in my Chrome browser
https://pvoutput.org/service/r2/getstatus.jsp?key=myapireadkey&sid=mychID&d=20210530
My MKR code compiles OK using the github example WiFiSSLClient.ino modified for my API's
What is the or my coding problem?
#include <WiFiNINA.h>
#include "secrets.h"
WiFiSSLClient client;
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
char server[] = "pvoutput.org";
//Initialize serial:
//while(!Serial);//may hang if usb unplugged
for (int i = 0; i < 5; i++) {
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
if (client.connect(server, 443)) { // port 80 for HTTP, port 443 for HTTPS ?
Serial.println("connected to server");
// Make a HTTP request:
client.println("GET /getstatus.jsp?key=myapikey&sid=mysid&d=20210530 HTTP/1.1");
client.println("Host: pvoutput.org/service/r2");
client.println("Connection: close");
client.println();
// if there are incoming bytes available
// from the server, read them and print them:
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting from server.");
client.stop();
// do nothing forevermore:
while (true);
Serial.println("end Setup");
