Wifiping & Sent_HTML
De esp mail client.h code en een aangepaste wifiping code die afzonderlijk werken ok dus geen probleem . Bij de wifiping code zie je staan Serial.print("FAILED! Error code: "); digitalWrite (LED_PIN3, LOW);digitalWrite (LED_PIN4,HIGH);delay(12000); De bedoeling is, indien digitalWrite (LED_PIN4,HIGH) is
een email te sturen met esp mail client .Kan dit samen werken ? En een tip graag .
Samenvatting : if LED_PIN4,HIGH -----> send mail .
Gebruik deuralarmen.
Wifiping
#include <SPI.h>
#include <WiFiNINA.h>
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the WiFi radio's status
#define LED_PIN1 8
#define LED_PIN2 9
#define LED_PIN3 10
#define LED_PIN4 11
// Specify IP address or hostname
String hostName = "192.......";
String hostName1 = "192........";
String hostName2 = "192........";
int pingResult;
// Initialize serial and wait for port to open:
pinMode(LED_PIN1, OUTPUT);
pinMode(LED_PIN2, OUTPUT);
pinMode(LED_PIN3, OUTPUT);
pinMode(LED_PIN4, OUTPUT);
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 5 seconds for connection:
delay(4000);
// you're connected now, so print out the data:
Serial.println("You're connected to the network");
printCurrentNet();
printWiFiData();
Serial.print("Pinging ");
Serial.print(hostName);
Serial.print(": ");
pingResult = WiFi.ping(hostName);
if (pingResult >= 0) {
Serial.print("SUCCESS! RTT = ");digitalWrite (LED_PIN1, HIGH); digitalWrite (LED_PIN4,LOW) ;
Serial.print(pingResult);
Serial.println(" ms");
Serial.print("FAILED! Error code: "); digitalWrite (LED_PIN1, LOW); digitalWrite (LED_PIN4,HIGH);delay(12000);
Serial.println(pingResult);
Serial.print(hostName1);
Serial.print(": ");
pingResult = WiFi.ping(hostName1);
Serial.print("SUCCESS! RTT = ");digitalWrite (LED_PIN2, HIGH);digitalWrite (LED_PIN4,LOW) ;
Serial.print("FAILED! Error code: "); digitalWrite (LED_PIN2, LOW);digitalWrite (LED_PIN4,HIGH);delay(12000);
Serial.print(hostName2);
Serial.print(": ");
pingResult = WiFi.ping(hostName2);
Serial.print("SUCCESS! RTT = ");digitalWrite (LED_PIN3, HIGH); digitalWrite (LED_PIN4,LOW) ;
delay(4000);
void printWiFiData() {
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP address : ");
Serial.println(ip);
Serial.print("Subnet mask: ");
Serial.println((IPAddress)WiFi.subnetMask());
Serial.print("Gateway IP : ");
Serial.println((IPAddress)WiFi.gatewayIP());
// print your MAC address:
byte mac[6];
WiFi.macAddress(mac);
Serial.print("MAC address: ");
printMacAddress(mac);
void printCurrentNet() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print the MAC address of the router you're attached to:
byte bssid[6];
WiFi.BSSID(bssid);
Serial.print("BSSID: ");
printMacAddress(bssid);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI): ");
Serial.println(rssi);
// print the encryption type:
byte encryption = WiFi.encryptionType();
Serial.print("Encryption Type: ");
Serial.println(encryption, HEX);
void printMacAddress(byte mac[]) {
for (int i = 5; i >= 0; i--) {
if (mac[i] < 16) {
Serial.print("0");
Serial.print(mac[i], HEX);
if (i > 0) {
Serial.print(":");
hier code Sent_HTML
 #include <Arduino.h>
#if defined(ESP32) || defined(ARDUINO_RASPBERRY_PI_PICO_W)
#include <WiFi.h>
#elif defined(ESP8266)
#include <ESP8266WiFi.h>
#elif __has_include(<WiFiNINA.h>)
#elif __has_include(<WiFi101.h>)
#include <WiFi101.h>
#elif __has_include(<WiFiS3.h>)
#include <WiFiS3.h>
#endif
#include <ESP_Mail_Client.h>
#define WIFI_SSID "<ssid>"
#define WIFI_PASSWORD "<password>"
/** For Gmail, the app password will be used for log in
 *  Check out https://github.com/mobizt/ESP-Mail-Client#gmail-smtp-and-imap-required-app-passwords-to-sign-in
 * For Yahoo mail, log in to your yahoo mail in web browser and generate app password by go to
 * https://login.yahoo.com/account/security/app-passwords/add/confirm?src=noSrc
 * To use Gmai and Yahoo's App Password to sign in, define the AUTHOR_PASSWORD with your App Password
 * and AUTHOR_EMAIL with your account email.
/** The smtp host name e.g. smtp.gmail.com for GMail or smtp.office365.com for Outlook or smtp.mail.yahoo.com */
#define SMTP_HOST "<host>"
/** The smtp port e.g.
 * 25  or esp_mail_smtp_port_25
 * 465 or esp_mail_smtp_port_465
 * 587 or esp_mail_smtp_port_587
#define SMTP_PORT esp_mail_smtp_port_587
/* The log in credentials */
#define AUTHOR_EMAIL "<email>"
#define AUTHOR_PASSWORD "<password>"
/* Recipient email address */
#define RECIPIENT_EMAIL "<recipient email here>"
/* Declare the global used SMTPSession object for SMTP transport */
SMTPSession smtp;
/* Callback function to get the Email sending status */
void smtpCallback(SMTP_Status status);
#if defined(ARDUINO_RASPBERRY_PI_PICO_W)
WiFiMulti multi;
#endif
#if defined(ARDUINO_ARCH_SAMD)
  while (!Serial)
#endif
  multi.addAP(WIFI_SSID, WIFI_PASSWORD);
  multi.run();
#else
  WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
#endif
  Serial.print("Connecting to Wi-Fi");
  unsigned long ms = millis();
#endif
  while (WiFi.status() != WL_CONNECTED)
    Serial.print(".");
    delay(300);
    if (millis() - ms > 10000)
#endif
  Serial.print("Connected with IP: ");
  /*  Set the network reconnection option */
  MailClient.networkReconnect(true);
  // The WiFi credentials are required for Pico W
  // due to it does not have reconnect feature.
  MailClient.clearAP();
  MailClient.addAP(WIFI_SSID, WIFI_PASSWORD);
#endif
  /** Enable the debug via Serial port
   * 0 for no debugging
   * 1 for basic level debugging
   * Debug port can be changed via ESP_MAIL_DEFAULT_DEBUG_PORT in ESP_Mail_FS.h
  smtp.debug(1);
  /* Set the callback function to get the sending results */
  smtp.callback(smtpCallback);
  /* Declare the Session_Config for user defined session credentials */
  Session_Config config;
  /* Set the session config */
  config.server.host_name = SMTP_HOST;
  config.server.port = SMTP_PORT;
  config.login.email = AUTHOR_EMAIL;
  config.login.password = AUTHOR_PASSWORD;
  /** Assign your host name or you public IPv4 or IPv6 only
   * as this is the part of EHLO/HELO command to identify the client system
   * to prevent connection rejection.
   * If host name or public IP is not available, ignore this or
   * use loopback address "127.0.0.1".
   * Assign any text to this option may cause the connection rejection.
  config.login.user_domain = F("127.0.0.1");
  Set the NTP config time
  For times east of the Prime Meridian use 0-12
  For times west of the Prime Meridian add 12 to the offset.
  Ex. American/Denver GMT would be -6. 6 + 12 = 18
  See https://en.wikipedia.org/wiki/Time_zone for a list of the GMT/UTC timezone offsets
  config.time.ntp_server = F("pool.ntp.org,time.nist.gov");
  config.time.gmt_offset = 3;
  config.time.day_light_offset = 0;
  /* The full message sending logs can now save to file */
  /* Since v3.0.4, the sent logs stored in smtp.sendingResult will store only the latest message logs */
  // config.sentLogs.filename = "/path/to/log/file";
  // config.sentLogs.storage_type = esp_mail_file_storage_type_flash;
  /* Declare the message class */
  SMTP_Message message;
  /* Set the message headers */
  message.sender.name = F("ESP Mail");
  message.sender.email = AUTHOR_EMAIL;
  message.subject = F("Test sending html Email");
  message.addRecipient(F("Admin"), RECIPIENT_EMAIL);
  String htmlMsg = "<p>This is the <span style=\"color:#ff0000;\">html text</span> message.</p><p>The message was sent via ESP device.</p>";
  message.html.content = htmlMsg;
  /** The html text message character set e.g.
   * us-ascii
   * utf-8
   * utf-7
   * The default value is utf-8
  message.html.charSet = F("us-ascii");
  /** The content transfer encoding e.g.
   * enc_7bit or "7bit" (not encoded)
   * enc_qp or "quoted-printable" (encoded)
   * enc_base64 or "base64" (encoded)
   * enc_binary or "binary" (not encoded)
   * enc_8bit or "8bit" (not encoded)
   * The default value is "7bit"
  message.html.transfer_encoding = Content_Transfer_Encoding::enc_7bit;
  /** The message priority
   * esp_mail_smtp_priority_high or 1
   * esp_mail_smtp_priority_normal or 3
   * esp_mail_smtp_priority_low or 5
   * The default value is esp_mail_smtp_priority_low
  message.priority = esp_mail_smtp_priority::esp_mail_smtp_priority_low;
  /** The Delivery Status Notifications e.g.
   * esp_mail_smtp_notify_never
   * esp_mail_smtp_notify_success
   * esp_mail_smtp_notify_failure
   * esp_mail_smtp_notify_delay
   * The default value is esp_mail_smtp_notify_never
  // message.response.notify = esp_mail_smtp_notify_success | esp_mail_smtp_notify_failure | esp_mail_smtp_notify_delay;
  /* Set the custom message header */
  message.addHeader(F("Message-ID: <abcde.fghij@gmail.com>"));
  /* Set the TCP response read timeout in seconds */
  // smtp.setTCPTimeout(10);
  /* Connect to the server */
  if (!smtp.connect(&config))
    MailClient.printf("Connection error, Status Code: %d, Error Code: %d, Reason: %s\n", smtp.statusCode(), smtp.errorCode(), smtp.errorReason().c_str());
    return;
  if (!smtp.isLoggedIn())
    Serial.println("Error, Not yet logged in.");
    if (smtp.isAuthenticated())
      Serial.println("Successfully logged in.");
      Serial.println("Connected with no Auth.");
  /* Start sending Email and close the session */
  if (!MailClient.sendMail(&smtp, &message))
    MailClient.printf("Error, Status Code: %d, Error Code: %d, Reason: %s\n", smtp.statusCode(), smtp.errorCode(), smtp.errorReason().c_str());
  // to clear sending result log
  // smtp.sendingResult.clear();
  MailClient.printf("Free Heap: %d\n", MailClient.getFreeHeap());
  /* Print the current status */
  Serial.println(status.info());
  /* Print the sending result */
  if (status.success())
    // MailClient.printf used in the examples is for format printing via debug Serial port
    // that works for all supported Arduino platform SDKs e.g. SAMD, ESP32 and ESP8266.
    // In ESP8266 and ESP32, you can use Serial.printf directly.
    Serial.println("----------------");
    MailClient.printf("Message sent success: %d\n", status.completedCount());
    MailClient.printf("Message sent failed: %d\n", status.failedCount());
    Serial.println("----------------\n");
    for (size_t i = 0; i < smtp.sendingResult.size(); i++)
      /* Get the result item */
      SMTP_Result result = smtp.sendingResult.getItem(i);
      // In case, ESP32, ESP8266 and SAMD device, the timestamp get from result.timestamp should be valid if
      // your device time was synched with NTP server.
      // Other devices may show invalid timestamp as the device time was not set i.e. it will show Jan 1, 1970.
      // You can call smtp.setSystemTime(xxx) to set device time manually. Where xxx is timestamp (seconds since Jan 1, 1970)
      MailClient.printf("Message No: %d\n", i + 1);
      MailClient.printf("Status: %s\n", result.completed ? "success" : "failed");
      MailClient.printf("Date/Time: %s\n", MailClient.Time.getDateTimeString(result.timestamp, "%B %d, %Y %H:%M:%S").c_str());
      MailClient.printf("Recipient: %s\n", result.recipients.c_str());
      MailClient.printf("Subject: %s\n", result.subject.c_str());
    // You need to clear sending result as the memory usage will grow up.
