Hello everyone
A part of my project involves getting the standard information of a network and the routers. Because I love Arduino, I have chosen Arduino Mega 2560 and the official Wifishield for my purpose.
I did some experimentation and research to get the information from network through the Wifishield. Arduino has made my life easy with their example ScanNetworks, but i can't get the correct BSSID information of the different routers.
My intention is to scan a network with information of SSID, BSSID and RSSI.
Arduino board: Mega 2560
Shield: Official Wifishield
IDE: 1.0.2.
Libraries: SPI.h and WiFi.h
Place of use: Hospital
Experience in programming: Moderate
Any help would be welcome
Serial information:
Scanning available networks...
** Scan Networks **
MAC: 78:C4:E:1:DD:2C
** Scan Networks **
number of available networks:10
0) Signal: -72 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
1) Signal: -75 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
2) Signal: -76 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
3) Signal: -77 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
4) Signal: -78 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
5) Signal: -79 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
6) Signal: -82 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
7) Signal: -82 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
8) ZOL Guest Signal: -82 dBm Encryption: None
BSSID: 0:0:0:0:0:EE
9) Signal: -89 dBm Encryption: WPA2
BSSID: 0:0:0:0:0:EE
My Code:
#include <SPI.h>
#include <WiFi.h>
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
// Print WiFi MAC address:
printMacAddress();
// scan for existing networks:
Serial.println("Scanning available networks...");
listNetworks();
delay(10000);
listNetworks();
void printMacAddress() {
// the MAC address of your Wifi shield
byte mac[6];
// print your MAC address:
WiFi.macAddress(mac);
Serial.print("MAC: ");
Serial.print(mac[5],HEX);
Serial.print(":");
Serial.print(mac[4],HEX);
Serial.print(":");
Serial.print(mac[3],HEX);
Serial.print(":");
Serial.print(mac[2],HEX);
Serial.print(":");
Serial.print(mac[1],HEX);
Serial.print(":");
Serial.println(mac[0],HEX);
void listNetworks() {
// scan for nearby networks:
Serial.println("** Scan Networks **");
int numSsid = WiFi.scanNetworks();
if (numSsid == -1)
Serial.println("Couldn't get a wifi connection");
while(true);
// print the list of networks seen:
Serial.print("number of available networks:");
Serial.println(numSsid);
// print the network number and name for each network found:
for (int thisNet = 0; thisNet<numSsid; thisNet++) {
Serial.print(thisNet);
Serial.print(") ");
Serial.print(WiFi.SSID(thisNet));
Serial.print("\tSignal: ");
Serial.print(WiFi.RSSI(thisNet));
Serial.print(" dBm");
Serial.print("\tEncryption: ");
printEncryptionType(WiFi.encryptionType(thisNet));
printBSSID(thisNet);
Serial.print("\n");
void printEncryptionType(int thisType) {
// read the encryption type and print out the name:
switch (thisType) {
case ENC_TYPE_WEP:
Serial.println("WEP");
case ENC_TYPE_TKIP:
Serial.println("WPA");
case ENC_TYPE_CCMP:
Serial.println("WPA2");
case ENC_TYPE_NONE:
Serial.println("None");
case ENC_TYPE_AUTO:
Serial.println("Auto");
void printBSSID(int thisType2) {
switch (thisType2) {
case 0:
byte bssid0[6];
byte bssid00[6];
WiFi.BSSID(bssid00);
Serial.print("BSSID: ");
Serial.print(bssid00[5],HEX);
Serial.print(":");
Serial.print(bssid00[4],HEX);
Serial.print(":");
Serial.print(bssid00[3],HEX);
Serial.print(":");
Serial.print(bssid00[2],HEX);
Serial.print(":");
Serial.print(bssid00[1],HEX);
Serial.print(":");
Serial.println(bssid00[0],HEX);
case 1:
byte bssid1[6];
WiFi.BSSID(bssid1);
Serial.print(bssid1[5],HEX);
Serial.print(":");
Serial.print(bssid1[4],HEX);
Serial.print(":");
Serial.print(bssid1[3],HEX);
Serial.print(":");
Serial.print(bssid1[2],HEX);
Serial.print(":");
Serial.print(bssid1[1],HEX);
Serial.print(":");
Serial.println(bssid1[0],HEX);
case 2:
byte bssid2[6];
WiFi.BSSID(bssid2);
Serial.print(bssid2[5],HEX);
Serial.print(":");
Serial.print(bssid2[4],HEX);
Serial.print(":");
Serial.print(bssid2[3],HEX);
Serial.print(":");
Serial.print(bssid2[2],HEX);
Serial.print(":");
Serial.print(bssid2[1],HEX);
Serial.print(":");
Serial.println(bssid2[0],HEX);
case 3:
byte bssid3[6];
WiFi.BSSID(bssid3);
Serial.print(bssid3[5],HEX);
Serial.print(":");
Serial.print(bssid3[4],HEX);
Serial.print(":");
Serial.print(bssid3[3],HEX);
Serial.print(":");
Serial.print(bssid3[2],HEX);
Serial.print(":");
Serial.print(bssid3[1],HEX);
Serial.print(":");
Serial.println(bssid3[0],HEX);
case 4:
byte bssid4[6];
WiFi.BSSID(bssid4);
Serial.print(bssid4[5],HEX);
Serial.print(":");
Serial.print(bssid4[4],HEX);
Serial.print(":");
Serial.print(bssid4[3],HEX);
Serial.print(":");
Serial.print(bssid4[2],HEX);
Serial.print(":");
Serial.print(bssid4[1],HEX);
Serial.print(":");
Serial.println(bssid4[0],HEX);
case 5:
byte bssid5[6];
WiFi.BSSID(bssid5);
Serial.print(bssid5[5],HEX);
Serial.print(":");
Serial.print(bssid5[4],HEX);
Serial.print(":");
Serial.print(bssid5[3],HEX);
Serial.print(":");
Serial.print(bssid5[2],HEX);
Serial.print(":");
Serial.print(bssid5[1],HEX);
Serial.print(":");
Serial.println(bssid5[0],HEX);
case 6:
byte bssid6[6];
WiFi.BSSID(bssid6);
Serial.print(bssid6[5],HEX);
Serial.print(":");
Serial.print(bssid6[4],HEX);
Serial.print(":");
Serial.print(bssid6[3],HEX);
Serial.print(":");
Serial.print(bssid6[2],HEX);
Serial.print(":");
Serial.print(bssid6[1],HEX);
Serial.print(":");
Serial.println(bssid6[0],HEX);
case 7:
byte bssid7[6];
WiFi.BSSID(bssid7);
Serial.print(bssid7[5],HEX);
Serial.print(":");
Serial.print(bssid7[4],HEX);
Serial.print(":");
Serial.print(bssid7[3],HEX);
Serial.print(":");
Serial.print(bssid7[2],HEX);
Serial.print(":");
Serial.print(bssid7[1],HEX);
Serial.print(":");
Serial.println(bssid7[0],HEX);
case 8:
byte bssid8[6];
WiFi.BSSID(bssid8);
Serial.print(bssid8[5],HEX);
Serial.print(":");
Serial.print(bssid8[4],HEX);
Serial.print(":");
Serial.print(bssid8[3],HEX);
Serial.print(":");
Serial.print(bssid8[2],HEX);
Serial.print(":");
Serial.print(bssid8[1],HEX);
Serial.print(":");
Serial.println(bssid8[0],HEX);
case 9:
byte bssid9[6];
WiFi.BSSID(bssid9);
Serial.print(bssid9[5],HEX);
Serial.print(":");
Serial.print(bssid9[4],HEX);
Serial.print(":");
Serial.print(bssid9[3],HEX);
Serial.print(":");
Serial.print(bssid9[2],HEX);
Serial.print(":");
Serial.print(bssid9[1],HEX);
Serial.print(":");
Serial.println(bssid9[0],HEX);
