WifiShield-Connecting from 3G using phone personal hotspot
When connect from router wifi there is no problem it detects text change and no problem.Serial print shows it right;
HTTP/1.1 200 OK
Cache-Control: max-age=1209600
Content-Type: text/plain
Last-Modified: Sun, 21 Jun 2015 23:38:36 GMT
Accept-Ranges: bytes
ETag: "4dd098647bacd01:0"
Server: Microsoft-IIS/8.5
X-Powered-By: ASP.NET
Date: Sun, 21 Jun 2015 23:53:07 GMT
Connection: close
Content-Length: 6
start#
After seeing this i connected from my phone's hotspot.But when connect from phone i receive different message and i am sure text remains same.The text message at the end not matching current one;
HTTP/1.1 200 OK
ETag: "ce56f11266acd01:0"
Content-Length: 2
Date: Sun, 21 Jun 2015 22:55:23 GMT
Last-Modified: Sun, 21 Jun 2015 21:05:59 GMT
Connection: close
This is a text on my server and start# writing on it.However when i read it from phone it somehow read old data or maybe some recorded data.It doesn't recognise the change.
Let me share my code;
#include <SPI.h>
#include <WiFi.h>
#include <String.h>
#include <TextFinder.h>
#include <Servo.h>
#define echoPin A1 // Echo Pin = Analog Pin 0#include <Servo.h>
#define trigPin A2 // Trigger Pin = Analog Pin 1
boolean rotation =0;
int i=0;
int pos = 0;
boolean getdist=false;
Servo myservo;
long distance=0; // Calculated Distance
boolean startultrasonic=false;
long duration; // Duration used to calculate distance
boolean sendrequest=false;
char ssid[] = "tkt"; //  your network SSID (name)AIRTIES_RT-205
char pass[] = "---";    // your network password (use for WPA, or use as key for WEP)
String yourdata ;
int status = WL_IDLE_STATUS;
char server[] = "arduinocontrol.somee.com";
WiFiClient client;
//TextFinder finder(client);
// yourdata.reserve(1400);
   pinMode(trigPin, OUTPUT);
 myservo.attach(6);
 pinMode(echoPin, INPUT);
yourdata="";
 analogReference(INTERNAL);
  //Initialize serial and wait for port to open:
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println(F("WiFi shield not present"));
    // don't continue:
    while (true);
  String fv = WiFi.firmwareVersion();
  if ( fv != "1.1.0" )
    Serial.println(F("Please upgrade the firmware"));
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
   Serial.print(F("Attempting to connect to SSID: "));
    Serial.println(ssid);
    status = WiFi.begin(ssid,pass);
    // wait 10 seconds for connection:
    delay(10000);
Serial.println("\nStarting connection to server...");
      httpRequest();
String add;
while(client.connected() && !client.available()) delay(1); //waits for data
  while (client.connected() || client.available()) { //connected or data available
    char c = client.read();
    add+=c;
   Serial.print(add);
if(startultrasonic){
getDistance();
if(sendrequest && !startultrasonic){
delay(3000);
httpRequest();
if(!startultrasonic){
   if(add.indexOf("?")>=0){
  Serial.print(F("dont start"));
  getdist=false;
httpRequest();
  if(add.indexOf("start")>=0){
  Serial.print(F("baslaaaa"));
  delay(300);
startultrasonic=true;
void httpRequest() {
  // close any connection before send a new request.
  // This will free the socket on the WiFi shield
  client.stop();
  // if there's a successful connection:
  if (client.connect(server, 80)) {
    Serial.println(F("connecting for data receive..."));
    // send the HTTP PUT request:
   client.println("GET /command.txt HTTP/1.1");
    client.println("Host: arduinocontrol.somee.com");
    client.println("Connection: close");
    client.println();
    Serial.println("DATA RECEIEVED");
  sendrequest=false;
    // note the time that the connection was made:
 delay(6000);
  else {
    // if you couldn't make a connection:
    Serial.println(F("connection failed"));
  void httpsendRequest() {
  client.stop();
 Serial.println(F("connecting for data send..."));
   Serial.println(yourdata);
  client.println("POST /Graph.aspx HTTP/1.1");
  client.println("User-Agent: Arduino/1.0");
  client.println("Content-Type: application/x-www-form-urlencoded;");
 client.print("Content-Length: ");
  client.println(yourdata.length());
  client.println();
  int x = yourdata.length(), i=0,j;
const char * charptr=yourdata.c_str();  // get access to the internal c_str of data.
while (i<x){
   j=50;
   if((i+j)>x) j = x - i;
   client.write(&charptr[i],j);  // starting at charptr[i] send then next j bytes.
   i = i + j;
yourdata=" ";
    Serial.println(F("DATA SEND"));
    sendrequest=true;
pos=0;
 delay(6000);
  else {
void getDistance(){
for(int i=0;i<181;i++){
 myservo.write(pos);
 if(pos>179)
   rotation = 1;
 if (pos<1)
   rotation =0;
 if(rotation == 0)
 {pos=pos+1;}
 digitalWrite(trigPin, LOW);
 delayMicroseconds(2);
 digitalWrite(trigPin, HIGH);
 delayMicroseconds(5);
 duration = pulseIn(echoPin, HIGH);
 //Calculate the distance (in cm) based on the speed of sound.
 distance = duration/58.2;
String d=String(i);
 if(i==0){
 yourdata="F=1&D"+d+"="+String(distance);
 else{
yourdata.concat("&D"+d+"="+distance);
if(d=="180"){
 httpsendRequest();
What is the reason you think?Before that i also did experiment with phone and see it was unable to detect change.
Your cellphone data provider probably uses a caching proxy server. It really shouldn't cache a POST response, but that is not certain. You should try to put some cache control stuff in the server's response header.
Do a Google search for http cache control.
edit: This header line returned from your server is probably causing the caching.
It allows using a cached response for 1209600 seconds. That is 14 days.
SurferTim:
Thanks for your answer.In my web config;
Changed to;
Problem is gone.I changed it long time ago for some reason and now it was the problem.
