I find example in WiFiS3 -> WifiWebClientSSL after connecting he show result with all page using
void read_request() {
uint32_t received_data_num = 0;
while (client.available()) {
/* actual data reception */
char c = client.read();
/* print data to serial port */
Serial.print(c);
/* wrap data to 80 columns*/
received_data_num++;
if(received_data_num % 80 == 0) {
And show all data
15:15:14.383 -> connected to server
15:15:15.319 -> HTTP/1.1 200 OK
15:15:15.319 -> Server: nginx
15:15:15.319 -> Content-Type: text/html; charset=UTF-8
15:15:15.319 -> Transfer-Encoding: chunked
15:15:15.319 -> Connection: close
15:15:15.319 -> Vary: Accept-Encoding
15:15:15.521 -> Cache-Control: no-cache, private
15:15:15.521 -> Date: Wed, 29 May 2024 12:15:13 GMT
15:15:15.521 -> Set-Cookie: zU0NTk5IiwidGFnIjoiIn0%3D; expires=Wed, 29 May 2024 14:15:13 GMT; Max-Age=7200; path=/; httponly; samesite=lax
15:15:15.890 -> Strict-Transport-Security: max-age=63072000; includeSubdomains;
15:15:15.890 -> All page data - many many lines
How can I tell him to check and display only the header with the status (15:15:15.319 -> HTTP/1.1 200 OK) , thereby saving traffic and time, there is no need to load the entire page.
int st = -1;
if (client.findUntil((char*) "HTTP/1.1 ", (char*) "\n")) {
int l = client.readBytesUntil(' ', buff, sizeof(buff)); // status code
if (l >= 0) {
buff[l] = 0;
if (strlen(buff) == 3) {
st = atoi(buff);
st = -4;
st = -3;
st = -2;
if (st == 200) {
Can you add this in complete code, i try but allready have error
This is full of original code
#include "WiFiS3.h"
#include "WiFiSSLClient.h"
#include "IPAddress.h"
#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = SECRET_SSID; // your network SSID (name)
char pass[] = SECRET_PASS; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "www.google.com"; // name address for Google (using DNS)
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
WiFiSSLClient client;
//Initialize serial and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network.
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
printWifiStatus();
Serial.println("\nStarting connection to server...");
// if you get a connection, report back via serial:
if (client.connect(server, 443)) {
Serial.println("connected to server");
// Make a HTTP request:
client.println("GET / HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
/* just wrap the received data up to 80 columns in the serial print*/
void read_response() {
Serial.print(c);
read_response();
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting from server.");
client.stop();
// do nothing forevermore:
while (true);
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
I try to add this code block in void read_request() but have an error
'buff' was not declared in this scope
if add char buff[256]; its compile good, but not working in serialmonitor.
Can you add you code in right place, very grateful in advance.
For this client/board, a default CA bundle is used when you don't set the cert. I didn't see any reference to what is included in that bundle though. (Google would be in there of course.) Might be baked into the firmware.
