Wifly arduino shield RSSI Vout (signal strength)
I have bought a Wifly shield for Arduino (http://www.sparkfun.com/products/9954). I want to read the strength of any Wifi signal in the area to control some LEDs, I noticed that the module incorporates a function called "show RSSI" as it says in the data sheet: http://www.sparkfun.com/datasheets/Wireless/WiFi/WiFlyGSX-um2.pdf.
I can't figure out how to successfully read a value for RSSI (signal strength). Would somebody be able to help me get started with this code?
Most recent library for Wifly: http://forum.sparkfun.com/viewtopic.php?f=32&t=25216.
This library includes three example codes.
Please help!!
Thanks, Darren.
Do you have a serial port connected to the WiFly UART port?
You switch to command mode by sending "$$$". I think you have to send nothing else within one seconds before and one second after.
WiFly.write("$$");
If the first thing you get back is not "CMD" then something is wrong.
I voted for the second option, although I'm still not sure if I was right.
Hope that helps.
I voted for the first option, just to be contrary.
Hope that helps.
I was going to vote for the underdog but they are tied at 1 and 1 so I'm going to boycott this poll instead.
Thank you for that.
Using: WiFly.write("$$$"); came up with an error: ‘class WiFlyDevice’ has no member named write. I replaced it with Serial.write("$$$");.
It returns: <2.23>
My code is attached to this post.
Darren
WiFly_trying_to_read_rssi.pde (646 Bytes)
Actually the code wasn’t attached. Here it is:
#include “WiFly.h”
#include “Credentials.h”
Serial.begin(9600); //initialise serial comms
WiFly.begin(); //initialise WiFly comms
Serial.write("$$$"); //initialise command mode
void loop(){
delay(100);
Serial.write(“show rssi”); //request RSSI value
while(SpiSerial.available()) {
Serial.print(SpiSerial.read(), BYTE);
/* if (WiFly.join(ssid, passphrase)) {
int ch = WiFly.read();
Serial.println(ch);
if(Serial.available()) { // Outgoing data
SpiSerial.println(Serial.read(), BYTE);
Serial.write("show rssi");      //request RSSI value
Serial.write() is for binary data. Serial.print() is for strings and for converting numeric types to strings. Why are you using Serial.write() this way?
Using: WiFly.write("$$$"); came up with an error: 'class WiFlyDevice' has no member named write. I replaced it with Serial.write("$$$");.
What is connected to the Serial port? Why didn't you try LCD.write()?
I was using Serial.wite() because I saw someone using it in another post. I'm now using SpiSerial.print() and the comms works with that.
This is a page about troubleshooting using the WiFly shield:
http://forum.sparkfun.com/viewtopic.php?f=32&t=25129
My code is able now to write a series of commands to the WiFly shield in the following order: - $$$ (with no carrige return)(this command enters command mode) - set wlan ssid BTHub3-Q9Z8 - set wlan phrase df2387da92 - join BTHub3-Q9Z8 - show rssi
It seams to bring back a number for the signal strength (RSSI) but it isn't very consistent and its very slow to respond when I move the shield relative to my wifi router. My code:
include "WiFly.h" // We use this for the preinstantiated SpiSerial object.
//#include "WiFlySerial.h"
int pos = 0; int crap = 0; int rssi_read = 0; int rssi_val = 0; long i = 0;
Serial.begin(9600); Serial.println("SPI UART on WiFly Shield terminal tool"); Serial.println("--------------------------------------"); Serial.println(); Serial.println("This is a tool to help you troubleshoot problems with the WiFly shield."); Serial.println("For consistent results unplug & replug power to your Arduino and WiFly shield."); Serial.println("(Ensure the serial monitor is not open when you remove power.)"); Serial.println();
Serial.println("Attempting to connect to SPI UART..."); SpiSerial.begin(); Serial.println("Connected to SPI UART."); Serial.println();
Serial.println(" * Use $$$ (with no line ending) to enter WiFly command mode. (\"CMD\")"); Serial.println(" * Then send each command followed by a carriage return."); Serial.println();
Serial.println("Waiting for input."); Serial.println(); }
void loop(){ Serial.println("loop");
//void command(){ delay (1000); SpiSerial.print("$$$"); //enters WiFly's command mode, should return CMD delay (1000); Serial.print(SpiSerial.read(), BYTE);
SpiSerial.println("set wlan ssid BTHub3-Q9Z8"); //delay (2000); Serial.print(SpiSerial.read(), BYTE);
SpiSerial.println("set wlan phrase df2387da92"); //delay (200); Serial.print(SpiSerial.read(), BYTE);
SpiSerial.println("join BTHub3-Q9Z8"); delay(2000); Serial.print(SpiSerial.read(), BYTE); delay(2000); Serial.print(SpiSerial.read(), BYTE); delay(2000);
SpiSerial.println("show rssi"); Serial.print(SpiSerial.read(), BYTE);
for(;;){ SpiSerial.println("show rssi"); Serial.print(SpiSerial.read(), BYTE); }
I based my code on the sample code: SpiUartTerminal.pde
This code gives me a good predictable RSSI reading that dynamically updates when I move the shield relative to my router.
This code can be found here: http://forum.sparkfun.com/viewtopic.php?f=32&t=25129
And here:
SpiUartTerminal - tool to help troubleshoot problems with WiFly shield
This code will initialize and test the SC16IS750 UART-SPI bridge then enable you to send commands to the WiFly module.
Copyright (c) 2010 SparkFun Electronics. http://sparkfun.com LGPL 3.0
void loop() { // Terminal routine
// Always display a response uninterrupted by typing // but note that this makes the terminal unresponsive // while a response is being received. while(SpiSerial.available() > 0) { Serial.print(SpiSerial.read(), BYTE); }
if(Serial.available()) { // Outgoing data SpiSerial.print(Serial.read(), BYTE); } }
