I've just unpacked my first WiFly bee, and have it strapped in a Bees shield. I've been following the steps outlined here Cairo Hacker Space: A beginner’s guide to connecting and operating the WiFly to Arduino Serially but with the trick that our network is WEP 128 secured. After not succeeding I added some debugging as follows:
boolean initSettings() {
Serial << "set wlan auth 1, " ;
if(!WiFly.SendCommand("set wlan auth 1","AOK")) Serial << "FAIL. " ;
Serial << endl << "set wlan key, " ;
if(!WiFly.SendCommand("set wlan key <...key snipped...>","AOK")) Serial << "FAIL. " ;
Serial << endl << "set wlan channel 0, " ;
if(!WiFly.SendCommand("set wlan channel 0","AOK")) Serial << "FAIL. " ;
Serial << endl << "set wlan join 1, " ;
if(!WiFly.SendCommand("set wlan join 1","AOK")) Serial << "FAIL. " ;
Serial << endl << "set dhcp 0, " ;
if(!WiFly.SendCommand("set dhcp 0","AOK")) Serial << "FAIL. " ;
Serial << endl << "set IP address, ";
if(!WiFly.SendCommand("set ip address 192.168.34.166","AOK")) Serial << "FAIL. ";
Serial << endl << "set netmask, ";
if(!WiFly.SendCommand("set netmask 255.255.255.0","AOK")) Serial << "FAIL. ";
Serial << endl << "save, " ;
if(!WiFly.SendCommand("save","AOK")) Serial << "FAIL. " ;
Serial << endl << "reboot." ;
if(!WiFly.SendCommand("reboot","AOK")) Serial << "FAIL. " ;
The output indicates some of these SendCommands aren't returning true:
RAM :659
MAC: 00:06:66:71:c8:5e
set wlan auth 1,
set wlan key,
set wlan channel 0,
set wlan join 1,
set dhcp 0, FAIL.
set IP address,
set netmask, FAIL.
save, FAIL.
reboot.FAIL.
Is this normal, or what could be causing the issue?
I've yet to be able to log onto the network, but this would indicate I'm not getting past basic setup. Any ideas?
Also, to get this running I've installed IDE 0022. Is there a library to support serial WiFly comms that's IDE 1.0 compatible ?
Thanks
Geoff
