Wifly crashed and will reboot...but never does
I'm using a wifly module from roving networks for wifi posting to the Web.
I've noticed that after a while of working just fine, it spits out this message:
Wifly crashed and will reboot...but never does!
If it rebooted I guess it would be great because I might get my data again. But the problem is that it doesn't. I looked into Wifly.cpp and found that after that debug message it doesn't really call for a reboot. Should I add that in manually, wifly.reboot()?
Here is my full sketch:
#include <Wire.h>
#include "RTClib.h"
#include <Time.h>
#include <TimeAlarms.h>
#include <WiFlyHQ.h>
#include <SoftwareSerial.h>
RTC_DS1307 rtc;
////////////////////////SETUP GROVE SHIELD////////////////////////////////////
int pin = 8;
unsigned long duration;
unsigned long starttime;
unsigned long sampletime_ms = 30000;//sampe 30s ;
unsigned long lowpulseoccupancy = 0;
float ratio = 0;
float concentration = 0;
long previousMillis = 0;
long interval = 1000;
SoftwareSerial wifiSerial(2,3); //WIFI SHIELD CLIENT
#define DEBUG 1                       //CO2 Sensor
const int pinRx = 8;                  //CO2 Sensor
const int pinTx = 7;                  //CO2 Sensor
SoftwareSerial sensor(pinTx,pinRx);  //CO2 Sensor
const unsigned char cmd_get_sensor[] =
    0xff, 0x01, 0x86, 0x00, 0x00,
    0x00, 0x00, 0x00, 0x79
unsigned char dataRevice[9];          //CO2 Sensor
int temperature;                      //CO2 Sensor
int CO2PPM;                           //CO2 Sensor
WiFly wifly;                          //WIFI
String data;                          //WIFI
const char mySSID[] = "linksys";
const char myPassword[] = "mykey";
const char site[] = "myserver.com";
void terminal();
void setup(){
  Wire.begin();
  rtc.begin();
  if (! rtc.isrunning()) {
    Serial.println("RTC is NOT running!");
    //rtc.adjust(DateTime(__DATE__, __TIME__));
  DateTime now = rtc.now();
  setTime(now.hour(), now.minute(), now.second(), now.month(), now.day(), now.year());
  Serial.print("Time is: ");
  Serial.println(now.hour());
  //Alarm.alarmRepeat(dowSaturday,8,30,30,WeeklyAlarm);  // 8:30:30 every Saturday
  Alarm.timerRepeat(1800, MorningAlarm);            // timer for every 1800 seconds (30mins)
  Serial.print("Alarms set!");
void  loop(){
  Alarm.delay(10); // wait one second between clock display
void wifiStuff(){
  ///////////////////WiFi CLIENT SETUP////////////////////////////////////////////
   char buf[32];
   data = "";
   Serial.print("Free memory: ");
   Serial.println(wifly.getFreeMemory(),DEC);
   wifiSerial.begin(9600);
   if (!wifly.begin(&wifiSerial, &Serial)) {
       Serial.println("Failed to start wifly");
	terminal();
        //failedToJoin = true;
        //waitAndTryAgain();
   /* Join wifi network if not already associated */
   if (!wifly.isAssociated()) {
	/* Setup the WiFly to connect to a wifi network */
	Serial.println("Joining network");
	wifly.setSSID(mySSID);
        wifly.setPassphrase(myPassword);
	wifly.enableDHCP();
	if (wifly.join()) {
	    Serial.println("Joined wifi network");
	    Serial.println("Failed to join wifi network");
	    terminal();
       Serial.println("Already joined network");
   wifly.setDeviceID("Wifly-WebClient");
   Serial.print("DeviceID: ");
   Serial.println(wifly.getDeviceID(buf, sizeof(buf)));
   if (wifly.isConnected()) {
       Serial.println("Old connection active. Closing");
	wifly.close();
void initialiseSensor(){
  sensor.begin(9600);
  Serial.println("get a 'g', begin to read from sensor!");
  Serial.println("********************************************************");
void MorningAlarm(){
  Serial.println("Morning Alarm...");
  initialiseSensor();
  delay(3000);
  printCO2();
  wifiStuff();
  reportToCloud();
void reportToCloud() {
   if (wifly.available() > 0) {
	char ch = wifly.read();
	Serial.write(ch);
	if (ch == '\n') {
	    /* add a carriage return */
	    Serial.write('\r');
   if (wifly.open(site, 80)) {
       Serial.print("Connected to ");
	Serial.println(site);
    // Set data to send
    static char outstr[15];
    String dataString = dtostrf(CO2PPM, 8, 2, outstr);
    data = String("name=Station1&age=" + dataString);
    Serial.print(data);
        /* Send the request */
	wifly.println("POST /arduino/process.php HTTP/1.0");
	wifly.println("Host: www.myserver.com"); // SERVER ADDRESS HERE TOO
        wifly.println("Content-Type: application/x-www-form-urlencoded" );
        wifly.print("Content-Length: ");
        wifly.println(data.length());
        //Replaced by wifly.close() at bottom of next if
        //wifly.println("Connnection: close");
	wifly.println();
        wifly.print(data);
       Serial.println("Failed to connect");
   if (Serial.available() > 0) {
	wifly.write(Serial.read());
/* Connect the WiFly serial to the serial monitor. */
void terminal(){
   while (1) {
	    Serial.write(wifly.read());
void printCO2() {
  Serial.println("printing co2...");
  if(dataRecieve())
    Serial.print("Temperature: ");
    Serial.print(temperature);
    Serial.print("  CO2: ");
    Serial.print(CO2PPM);
    Serial.println("");
bool dataRecieve(void) {
  byte data[9];
  int i = 0;
  //transmit command data
  for(i=0; i<sizeof(cmd_get_sensor); i++)
    sensor.write(cmd_get_sensor[i]);
  //begin reveiceing data
  if(sensor.available())
    while(sensor.available())
      for(int i=0;i<9; i++)
        data[i] = sensor.read();
  #if DEBUG
  for(int j=0; j<9; j++)
    Serial.print(data[j]);
    Serial.print(" ");
  Serial.println("");
  #endif
  if((i != 9) || (1 + (0xFF ^ (byte)(data[1] + data[2] + data[3]
    + data[4] + data[5] + data[6] + data[7]))) != data[8])
    Serial.println("false returned");
    return false;
  CO2PPM = (int)data[2] * 256 + (int)data[3];
  temperature = (int)data[4] - 40;
  Serial.println(temperature);
  return true;
How do I set the condition for wdt to reset the arduino when this happens?
Apparently the wifly crashing is quite common. So the WiFlyHQ.cpp does this:
if (!getPrompt()) {
	debug.println(F("Failed to get prompt"));
	debug.println(F("WiFly has crashed and will reboot..."));
	while (1); /* wait for the reboot */
	return false;
How do I make this signal my wdt such that I can reboot it?
