WiFly drives me crazy... simple http GET
Hello,
I am fighting for days now to create a simple script that writes a value with GET to a SQL database
On the ethernet Arduino i have it working but i want to do it with wifi / wifly
I tried a lot of code all over from google but i cannot get it running
Who can help me with the loop?
If it just connects and then writes a value to a “domain.com/test.php?value=12345” i am happy!!
The final plan is that the “value” comes from an id-12 rfid reader
Thanks for your help!
It would be helpful to see the code that you have so people can start helping you with it.
for the loop i do not have any code because nothing is working, sorry
and to connect i use the code of example webclientgetpost.
the following from the examples puts something in the sql
  Serial << F("Beginning of Loop RAM:") << freeMemory() << endl ;
  // Perform GET example
  float fSampleValue = iLoopCounter + (iLoopCounter / 10 );
  Do_GET_Example(   iLoopCounter, fSampleValue );
  // Perform POST example
  Do_POST_Example ( iLoopCounter, fSampleValue );
  // Serial << "Clear leftovers" << endl;
  // flush the wifi buffer by reading and showing anything left around.
  while ((chMisc = wifi.read()) > -1) {
    Serial << chMisc;
  iLoopCounter++;
  // wait a bit
  Serial << F("Waiting a moment..") << endl;
  delay(2000);
but i want to change this to some simple lines to put the rfid code
And this is what i do with the Arduino ethernet, so this is what i wish :wink: to do… finally
void loop () {
  lcd.setCursor(0,1);
  lcd.print("                ");
  byte i = 0;
  byte val = 0;
  byte code[6];
  byte checksum = 0;
  byte bytesread = 0;
  byte tempbyte = 0;
  if(mySerial.available() > 0) {
    if((val = mySerial.read()) == 2) {                  // check for header
      digitalWrite(ledRfid, HIGH);   // set the LED on
      bytesread = 0;
      while (bytesread < 12) {                        // read 10 digit code + 2 digit checksum
        if( mySerial.available() > 0) {
          val = mySerial.read();
          if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02)) { // if header or stop bytes before the 10 digit reading
            break;                                    // stop reading
          // Do Ascii/Hex conversion:
          if ((val >= '0') && (val <= '9')) {
            val = val - '0';
          else if ((val >= 'A') && (val <= 'F')) {
            val = 10 + val - 'A';
          // Every two hex-digits, add byte to code:
          if (bytesread & 1 == 1) {
            // make some space for this hex-digit by
            // shifting the previous hex-digit with 4 bits to the left:
            code[bytesread >> 1] = (val | (tempbyte << 4));
            if (bytesread >> 1 != 5) {                // If we're at the checksum byte,
              checksum ^= code[bytesread >> 1];       // Calculate the checksum... (XOR)
          else {
            tempbyte = val;                           // Store the first hex digit first...
          bytesread++;                                // ready to read next digit
      // Output to Serial:
      if (bytesread == 12) {                          // if 12 digit read is complete
        Serial.print("5-byte code: ");
        for (i=0; i<5; i++) {
          if (code[i] < 16) Serial.print("0");
          Serial.print(code[i], HEX);
          Serial.print(" ");
        Serial.print("Checksum: ");
        Serial.print(code[5], HEX);
        Serial.println(code[5] == checksum ? " -- passed." : " -- error.");
        Serial.println("connecting...");
        if (client.connect(server, 80)) {
          Serial.println("connected");
          client.print(getLine);
            if (code[i] < 16) client.print("0");
            client.print(code[i], HEX);
          client.println(" HTTP/1 .1");
          client.println("Host: domain.com");
          client.println("User-Agent: arduino-ethernet");
          client.println("Connection: close");
          client.println();
          client.stop();
          digitalWrite(ledRfid, LOW);    // set the LED off
        else {
          Serial.println("connection failed");
      bytesread = 0;
Thanks for the code. I'm not the most experienced with this, but I gave your code a quick skim.
check out how i arranged my wifly code. you can see it on this: http://arduino.cc/forum/index.php/topic,119159.0.html topic.
But as the topic suggests, I also have buggy code.
