WiFly on Arduino
Hi, I tried to make a wifly work with arduino duemilanove for some time now. First of all I made a connection between Vin pin on Arduino and Vin pin on Wifly and then i read that the Vin pin should not take more than 3.3V. Have i damaged the Wifly card because of this?
Then i tried another Wifly card (the same type) but i get different feedback/messages from two Wifly cards with the same code program and same connections on pins.(No. 10-13 pins on Arduino to No. 10-13 pins on Wifly) ,(3.3V pin on Arduino to Vin pin on Wifly), (GND to GND)
here is the code that i found on sparkfun[dot]com :
 * "WiFly_Terminal"
 * WiFly UART-SPI bridge Example
 * Copyright (c) 2010 SparkFun Electronics.  All right reserved.
 * Written by Chris Taylor
 * This code was written to demonstrate the WiFly Shield from SparkFun Electronics
 * This code will initialize and test the SC16IS750 UART-SPI bridge, and allow
 * transparent communication with the device from a terminal.
 * sparkfun[dot]com
#include <string.h> // Required for strlen()
// SCI16IS750 Registers
#define THR        0x00 << 3
#define RHR        0x00 << 3
#define IER        0x01 << 3
#define FCR        0x02 << 3
#define IIR        0x02 << 3
#define LCR        0x03 << 3
#define MCR        0x04 << 3
#define LSR        0x05 << 3
#define MSR        0x06 << 3
#define SPR        0x07 << 3
#define TXFIFO     0x08 << 3
#define RXFIFO     0x09 << 3
#define DLAB       0x80 << 3
#define IODIR      0x0A << 3
#define IOSTATE    0x0B << 3
#define IOINTMSK   0x0C << 3
#define IOCTRL     0x0E << 3
#define EFCR       0x0F << 3
#define DLL        0x00 << 3
#define DLM        0x01 << 3
#define EFR        0x02 << 3
#define XON1       0x04 << 3
#define XON2       0x05 << 3
#define XOFF1      0x06 << 3
#define XOFF2      0x07 << 3
// Arduino SPI pins
#define CS         10
#define MOSI       11
#define MISO       12
#define SCK        13
// Communication flags and variables
char incoming_data;
char TX_Fifo_Address = THR;
char clr = 0;
char polling = 0;
// SC16IS750 Configuration Parameters
struct SPI_UART_cfg
  char DivL,DivM,DataFormat,Flow;
struct SPI_UART_cfg SPI_Uart_config = {
  0x50,0x00,0x03,0x10};
  // Initialize SPI pins
  pinMode(MOSI, OUTPUT);
  pinMode(MISO, INPUT);
  pinMode(SCK,OUTPUT);
  pinMode(CS,OUTPUT);
  digitalWrite(CS,HIGH); //disable device
  SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1)|(1<<SPR0);
  clr=SPSR;
  clr=SPDR;
  delay(10);
  Serial.println("\n\r\n\rWiFly Shield Terminal Routine");
  // Test SPI communication
  if(SPI_Uart_Init()){
    Serial.println("Bridge initialized successfully!");
  else{
    Serial.println("Could not initialize bridge, locking up.\n\r");
    while(1);
  // Poll for new data in SC16IS750 Recieve buffer
  if(SPI_Uart_ReadByte(LSR) & 0x01)
    polling = 1;
    while(polling)
      if((SPI_Uart_ReadByte(LSR) & 0x01))
        incoming_data = SPI_Uart_ReadByte(RHR);
        Serial.print(incoming_data,BYTE);
        polling = 0;
  // Otherwise, send chars from terminal to SC16IS750
  else if(Serial.available())
    incoming_data = Serial.read();
    select();
    spi_transfer(0x00); // Transmit command
    spi_transfer(incoming_data);
    deselect();
char SPI_Uart_Init(void)
// Initialize SC16IS750
  char data = 0;
  SPI_Uart_WriteByte(LCR,0x80); // 0x80 to program baudrate
  SPI_Uart_WriteByte(DLL,SPI_Uart_config.DivL); //0x50 = 9600 with Xtal = 12.288MHz
  SPI_Uart_WriteByte(DLM,SPI_Uart_config.DivM);
  SPI_Uart_WriteByte(LCR, 0xBF); // access EFR register
  SPI_Uart_WriteByte(EFR, SPI_Uart_config.Flow); // enable enhanced registers
  SPI_Uart_WriteByte(LCR, SPI_Uart_config.DataFormat); // 8 data bit, 1 stop bit, no parity
  SPI_Uart_WriteByte(FCR, 0x06); // reset TXFIFO, reset RXFIFO, non FIFO mode
  SPI_Uart_WriteByte(FCR, 0x01); // enable FIFO mode
  // Perform read/write test to check if UART is working
  SPI_Uart_WriteByte(SPR,'H');
  data = SPI_Uart_ReadByte(SPR);
  if(data == 'H'){
    return 1;
  else{
    return 0;
void SPI_Uart_WriteByte(char address, char data)
// Write byte to register address on SC16IS750
  long int length;
  char senddata[2];
  senddata[0] = address;
  senddata[1] = data;
  select();
  length = SPI_Write(senddata, 2);
  deselect();
long int SPI_Write(char* srcptr, long int length)
// Send entire string to SC16IS750
  for(long int i = 0; i < length; i++)
    spi_transfer(srcptr[i]);
  return length;
void SPI_Uart_WriteArray(char *data, long int NumBytes)
// Send entire string to THR of SC16IS750
  long int length;
  select();
  length = SPI_Write(&TX_Fifo_Address,1);
  while(NumBytes > 16) // Split array into 16 character chunks
    length = SPI_Write(data,16);
    NumBytes -= 16;
    data += 16;
  length = SPI_Write(data,NumBytes);
  deselect();
char SPI_Uart_ReadByte(char address)
// Read from SC16IS750 register
  char data;
  address = (address | 0x80);
  select();
  spi_transfer(address);
  data = spi_transfer(0xFF);
  deselect();
  return data;
void SPI_Uart_println(char *data)
// Write string to SC16IS750 followed by a carriage return
  SPI_Uart_WriteArray(data,strlen(data));
  SPI_Uart_WriteByte(THR, 0x0d);
void SPI_Uart_print(char *data)
// Write string to SC16IS750, no carriage return
char spi_transfer(volatile char data)
  SPDR = data;                    // Start the transmission
  while (!(SPSR & (1<<SPIF)))     // Wait for the end of the transmission
  return SPDR;                    // return the received byte
void select(void)
  digitalWrite(CS,LOW);
void deselect(void)
On the first card i get this messeage:
"WiFly Shield Terminal Routine
and then i get "yyy :y yy yyyyyyyyyyy : yyyy"
On the other card i can not even initalize the bridge. I get this messeage after connecting everything on the same way as first card:
Could not initialize bridge, locking up."
Can someone help me please. What am i doing wrong here? Is not code suppose to be like this:
CMD
Auto-Assoc roving1 chan=1 mode=NONE FAILED"
and so on????!!!!
is there anything wrong with my pin connections? or do i need to configurate the code a bit?!
Hey ramtin,
I'm having the same problem as the one you hve in your second board, the "Not able to connect bridge" :-[
I really don't know what the problem is, but as soon as I can figure it out, I'll post something here...
Have you been having any luck lately? What OS do you have? I'm trying to do things on a Mac OS X...
Also, do you know if your shield has a 14MHz crystal, or a 12MHz crystal? You can see it in that little silver thingy next to pins 6-7.
I'm guessing that if you're using the code written for the 12MHz with a 14MHz, it won't communicate properly...
However, I still haven't found how to change this...
Ok, I figured out how to change the frequency expected from the board, because of the new crystals. if your shield has a 14MHz crystal, the the code:
should be changed to:
0x60,0x00,0x03,0x10};
I know this doesn't exactly help with the bridge initialization problem, but might help with your other problem.
Well, this seems more like a monologue than anything else, but my problem is solved. What happened was, me being dumb as a rock, I wasn't connecting the pin properly.
First, I was connecting pins 10-13, plus pin GND and... pin 3.3V :-[ Obviously, this is wrong, as the correct pin is pin Vin.
Secondly, my pins 10-13 weren't actually connect... had to do a bit of a hacking to connect all he pins to the respective Arduino pins.
Now my problem is I can't get communication through HTTP. I change the port to 80, ping it from another computer connected to the same network, and it answers back. But if I try to open an http page from another computer, it returns nothing, and nothing shows up on the terminal where the WiFly is connected...
Thanks :slight_smile: I was only trying to help him... :slight_smile:
Anyway, what I found is here just in case someone has the same issues
I'm going to revive the thread again (or at least try).
I'm following the Sparkfun tutorial:
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=158
I'm getting stuck trying the Transparent Terminal Sketch (Search the page for it, and it will come up as the 2nd hit).
I'm trying to execute the paragraph right after that. I'm trying to send the command "$$$" (no quotes) to enter the command mode of the WiFly.
When I hook up the system, I'm getting (In the Arduino Serial Monitor, TeraTerm, and Multi Terminal from Sourceforge):
At this point I've tried entering the "$$$" command, and nothing else happens.
I've tried the other tutorials, and have not made progress with this shield (I can't get the system to associate with wireless access points yet).
Once again, I'm worried I'm missing something basic.
You might want to try the WiFly library for Arduino I created: WiFly Shield code library alpha.
--Philip;
I'm there as well. I feel that I haven't even gotten to that point yet. I can't even get communication with the WiFly module (I don't think). As near as I can tell, I'm only getting information from the Arduino.
However, I just noticed that your topic is very current (posts 2 days ago). I hope you'll pardon my duplication, but I'm going to post there as well.
By the way, thanks for your library. It's folks like you that make this kind of DIY possible.
Okay, I'll follow up there then. :slight_smile:
--Philip;
