wiflyhq and httpclient is not posting data
I am very much new to arduino to be precise new to embedded programming itself, although got some knowledge on c++.Basically I am trying to send some data from my arduino Duemilenove to pc via RN-171 wifly module. So i started to play with various wifi sketches available with arduino , but wiflyhq and wifiserial are only working with RN-171. to test I downloaded the code from GitHub - ericbenwa/POST-Arduino-Data-Wireless: A simple way to send data from an Arduino and save it to a database (MySQL) over WiFi. here. which posts some value to php which is then saved to a mysql db, I have done almost all the same except , the code uses wifi.h and i am using wiflyhq.h as include file. But i am unable to send data to the php page in my windows 7 laptop. the php code is also taken from the same link. and when i tested the php via browser it works as expected. for the reference i am posting my arduino program here
#include <WiFlyHQ.h>
#include <SoftwareSerial.h>
SoftwareSerial wifiSerial(8,9);
//#include <AltSoftSerial.h>
//AltSoftSerial wifiSerial(8,9);
WiFly wifly;
/* Change these to match your WiFi network */
const char mySSID[] = "DLink";
const char myPassword[] = "asdfgf";
//const char site[] = "arduino.cc";
//const char site[] = "www.google.co.nz";
const char site[] = "192.168.1.100";
int yourarduinodata=999;
String yourdatacolumn= "yourdata=";
String yourdata;
void terminal();
    char buf[32];
    Serial.println("Starting");
    Serial.print("Free memory: ");
    Serial.println(wifly.getFreeMemory(),DEC);
    wifiSerial.begin(9600);
    if (!wifly.begin(&wifiSerial, &Serial)) {
        Serial.println("Failed to start wifly");
	terminal();
    /* Join wifi network if not already associated */
    if (!wifly.isAssociated()) {
	/* Setup the WiFly to connect to a wifi network */
	Serial.println("Joining network");
	wifly.setSSID(mySSID);
	wifly.setPassphrase(myPassword);
	wifly.enableDHCP();
	if (wifly.join()) {
	    Serial.println("Joined wifi network");
	    Serial.println("Failed to join wifi network");
	    terminal();
        Serial.println("Already joined network");
    //terminal();
    Serial.print("MAC: ");
    Serial.println(wifly.getMAC(buf, sizeof(buf)));
    Serial.print("IP: ");
    Serial.println(wifly.getIP(buf, sizeof(buf)));
    Serial.print("Netmask: ");
    Serial.println(wifly.getNetmask(buf, sizeof(buf)));
    Serial.print("Gateway: ");
    Serial.println(wifly.getGateway(buf, sizeof(buf)));
    wifly.setDeviceID("Wifly-WebClient");
    Serial.print("DeviceID: ");
    Serial.println(wifly.getDeviceID(buf, sizeof(buf)));
    if (wifly.isConnected()) {
        Serial.println("Old connection active. Closing");
	wifly.close();
    yourdata = yourdatacolumn + yourarduinodata;
    if (wifly.open(site, 80)) {
        Serial.print("Connected to ");
	Serial.println(site);
	/* Send the request */
	 wifly.println("POST /phptest/insert_mysql.php HTTP/1.1");
         wifly.println("Host: 192.168.1.100");
         wifly.println("User-Agent: Arduino/1.0");
         wifly.println("Connection: close");
         wifly.println("Content-Length: ");
         wifly.println(yourdata.length());
         wifly.println();
         wifly.println(yourdata);
         Serial.println(yourdata);
        Serial.println("Failed to connect");
/* Connect the WiFly serial to the serial monitor. */
void terminal()
    while (1) {
	if (wifly.available() > 0) {
	    Serial.write(wifly.read());
	if (Serial.available() > 0) {
	    wifly.write(Serial.read());
I am not sure what i am doing wrong. the serial monitor correctly displays the values in relation to wify and it also shows connected to the site and finally the serial monitor prints yourdata=999 , but when i check in mysql server in my laptop there is no new data added to it.
Any pointers.
those who are looking for further details regarding rn-171 here it is
get e
wifly-EZX Ver 4.00.1, Apr 19 2013 11:47:20 on RN-171
Beacon=102
Reboot=0
IF=UP
DHCP=OFF
IP=192.168.1.101:2000
NM=255.255.255.0
GW=192.168.1.1
HOST=0.0.0.0:2000
PROTO=TCP,
MTU=1524
FLAGS=0x7
TCPMODE=0x0
BACKUP=0.0.0.0
OPEN=*OPEN*
CLOSE=*CLOS*
REMOTE=*HELLO*
FlushSize=1420
MatchChar=0
FlushTimer=5
IdleTimer=0
CmdChar=$
DNS=0.0.0.0
Name=dns1
Backup=rn.microchip.com
Lease=86400
FTP=0.0.0.0:21
File=wifly-EZX.img
User=roving
Pass=Pass123
Dir=public
Timeout=200
FTP_mode=0x0
SSID=DLink
Chan=0
ExtAnt=0
Join=1
Auth=OPEN
Mask=0x1fff
Rate=12, 24 Mb
Linkmon-Infra=30
Linkmon-AP=3600
Passphrase=asdfgf
TxPower=12
EAP_Id=userid
EAP_User=peap-user
SleepTmr=0
WakeTmr=0
Trigger=0x1
Autoconn=0
IoFunc=0x0
IoMask=0x21f0
IoValu=0x0
ERR: ?-Cmdx0
<4.00> l=0x1
LaunchStr=web_app
TimeEna=0
TIMEADR=64.90.182.55:123
Zone=7
Baudrate=9600
Flow=0x0
Mode=0x0
Cmd_GPIO=0
JoinTmr=1000
Replace=0x24
DeviceId=WiFly-EZX
Password=
Format=0x0
Signal=0
Average=5
BCAST=255.255.255.255:55555
Interval=0x7
Backup=0.0.0.0:0
Sensor=0x0
SensePwr=0x0
and the connections from my rn-171 to arduino are
RX-2nd pin arduino
TX-3rd pin arduino.
