I have been trying to run this example from the WiFlyHQ library, but the serial monitor is giving me weird output.
* WiFlyHQ Example tcpclient.ino
* This sketch implements a simple TCP client that connects to a
* TCP server, sends any serial monitor input to the server and any
* data received from the server to the TCP monitor, and disconnects
* after 10 seconds.
* This sketch is released to the public domain.
#include <SoftwareSerial.h>
SoftwareSerial wifiSerial(10,11);
//#include <AltSoftSerial.h>
//AltSoftSerial wifiSerial(8,9);
#include <WiFlyHQ.h>
/* Change these to match your WiFi network */
const char mySSID[] = "ash";
const char myPassword[] = "*****";
void terminal();
WiFly wifly;
char buf[64];
Serial.begin(57600);
Serial.println("Starting");
Serial.print("Free memory: ");
Serial.println(wifly.getFreeMemory(),DEC);
wifiSerial.begin(9600);
if (!wifly.begin(&wifiSerial, &Serial)) {
Serial.println("Failed to start wifly");
terminal();
/* Join wifi network if not already associated */
if (!wifly.isAssociated()) {
/* Setup the WiFly to connect to a wifi network */
Serial.println("Joining network");
wifly.setSSID(mySSID);
wifly.setPassphrase(myPassword);
wifly.enableDHCP();
if (wifly.join()) {
Serial.println("Joined wifi network");
Serial.println("Failed to join wifi network");
terminal();
Serial.println("Already joined network");
Serial.println("WiFly ready");
Serial.print("MAC: ");
Serial.println(wifly.getMAC(buf, sizeof(buf)));
Serial.print("IP: ");
Serial.println(wifly.getIP(buf, sizeof(buf)));
Serial.print("Netmask: ");
Serial.println(wifly.getNetmask(buf, sizeof(buf)));
Serial.print("Gateway: ");
Serial.println(wifly.getGateway(buf, sizeof(buf)));
Serial.println("Set DeviceID");
wifly.setDeviceID("Wifly-TCP");
Serial.print("DeviceID: ");
Serial.println(wifly.getDeviceID(buf, sizeof(buf)));
wifly.setIpProtocol(WIFLY_PROTOCOL_TCP);
if (wifly.isConnected()) {
Serial.println("Old connection active. Closing");
wifly.close();
uint32_t connectTime = 0;
int available;
if (wifly.isConnected() == false) {
Serial.println("Connecting");
if (wifly.open("192.168.1.60",8042)) {
Serial.println("Connected");
connectTime = millis();
Serial.println("Failed to open");
available = wifly.available();
if (available < 0) {
Serial.println("Disconnected");
} else if (available > 0) {
Serial.write(wifly.read());
/* Disconnect after 10 seconds */
if ((millis() - connectTime) > 10000) {
Serial.println("Disconnecting");
wifly.close();
/* Send data from the serial monitor to the TCP server */
if (Serial.available()) {
wifly.write(Serial.read());
void terminal()
while (1) {
if (wifly.available() > 0) {
if (Serial.available()) { // Outgoing data
I just changed the SSID and the password, and the software serial pin numbers.
and the output i get in the serial monitor is :
C°rüèbþWu|Ô°9{
I’ll be really grateful, if anyone could help me with this. Tell me what the problem is? or why is this happening ?
