I am building a quadcopter and I want it to stabilize itself.
That said I have been messing around with a stock Nintendo Wii Motion plus and I have been unable to get it to start sending data...
Here is the code that I found to get it started.
#include <Wire.h>
byte data[6]; //six data bytes
int yaw, pitch, roll; //three axes
int yaw0, pitch0, roll0; //calibration zeroes
void wmpOn(){
Wire.beginTransmission(0x53); //WM+ starts out deactivated at address 0x53
Wire.send(0xfe); //send 0x04 to address 0xFE to activate WM+
Wire.send(0x04);
Wire.endTransmission(); //WM+ jumps to address 0x52 and is now active
void wmpSendZero(){
Wire.beginTransmission(0x52); //now at address 0x52
Wire.send(0x00); //send zero to signal we want info
void calibrateZeroes(){
for (int i=0;i<10;i++){
wmpSendZero();
Wire.requestFrom(0x52,6);
for (int i=0;i<6;i++){
data[i]=Wire.receive();
yaw0+=(((data[3]>>2)<<8)+data[0])/10; //average 10 readings
pitch0+=(((data[4]>>2)<<8)+data[1])/10;
roll0+=(((data[5]>>2)<<8)+data[2])/10;
Serial.print("Yaw0:");
Serial.print(yaw0);
Serial.print(" Pitch0:");
Serial.print(pitch0);
Serial.print(" Roll0:");
Serial.println(roll0);
void receiveData(){
wmpSendZero(); //send zero before each request (same as nunchuck)
Wire.requestFrom(0x52,6); //request the six bytes from the WM+
yaw=((data[3]>>2)<<8)+data[0]-yaw0;
pitch=((data[4]>>2)<<8)+data[1]-pitch0;
roll=((data[5]>>2)<<8)+data[2]-roll0;
}/Extension_Controllers#Wii_Motion_Plus
//for info on what each byte represents
void setup(){
Serial.println("WM+ tester");
Wire.begin();
wmpOn(); //turn WM+ on
calibrateZeroes(); //calibrate zeroes
void loop(){
receiveData(); //receive data and calculate yaw pitch and roll
Serial.print("yaw:");
Serial.print(yaw); //for info on which axis is which
Serial.print(" pitch:");
Serial.print(pitch);
Serial.print(" roll:");
Serial.println(roll);
delay(100);
My nunchuck works fine with some other code so it cant be my board or one of the libraries...
Tried the code in 0018 and 0019, Not in 0021 yet.
Using a 328 Dual.
Wiichuck adapter.
Tried 5v and 3.3v.
Anyone have any ideas ?
Thanks
