Wii motion plus yaw problem
Hello to every one
I am trying to read the data of the gyros from the wii motion plus with an Arduino UNO . The problem is that although I make the neccesary connections between the arduino and the wii motion plus the data of the yaw doesn’t change all the other readings for the roll pitch seems to be ok. The sketch that I have aploaded to he arduino is the following.could it be that my motion plus is damaged?
#include <Wire.h>
byte data[6];          //six data bytes
int yaw, pitch, roll;  //three axes
int yaw0, pitch0, roll0;  //calibration zeroes
void wmpOn(){
  Wire.beginTransmission(0x53);    //WM+ starts out deactivated at address 0x53
  Wire.send(0xfe);                 //send 0x04 to address 0xFE to activate WM+
  Wire.send(0x04);
  Wire.endTransmission();          //WM+ jumps to address 0x52 and is now active
void wmpSendZero(){
  Wire.beginTransmission(0x52);    //now at address 0x52
  Wire.send(0x00);                 //send zero to signal we want info
void calibrateZeroes(){
  for (int i=0;i<10;i++){
    wmpSendZero();
    Wire.requestFrom(0x52,6);
    for (int i=0;i<6;i++){
      data[i]=Wire.receive();
    yaw0+=(((data[3]>>2)<<8)+data[0])/10;        //average 10 readings for each zero
    pitch0+=(((data[4]>>2)<<8)+data[1])/10;
    roll0+=(((data[5]>>2)<<8)+data[2])/10;
  Serial.print("Yaw0:");
  Serial.print(yaw0);
  Serial.print("  Pitch0:");
  Serial.print(pitch0);
  Serial.print("  Roll0:");
  Serial.println(roll0);
void receiveData(){
  wmpSendZero();                   //send zero before each request (same as nunchuck)
  Wire.requestFrom(0x52,6);        //request the six bytes from the WM+
  yaw=((data[3]>>2)<<8)+data[0]-yaw0;        //see http://wiibrew.org/wiki/Wiimote/Extension_Controllers#Wii_Motion_Plus
  pitch=((data[4]>>2)<<8)+data[1]-pitch0;    //for info on what each byte represents
  roll=((data[5]>>2)<<8)+data[2]-roll0;
void setup(){
  Serial.println("WM+ tester");
  Wire.begin();
  wmpOn();                        //turn WM+ on
  calibrateZeroes();              //calibrate zeroes
void loop(){
  receiveData();                  //receive data and calculate yaw pitch and roll
  Serial.print("yaw:");           //see diagram on randomhacksofboredom.blogspot.com
  Serial.print(yaw);              //for info on which axis is which
  Serial.print("  pitch:");
  Serial.print(pitch);
  Serial.print("  roll:");
  Serial.println(roll);
  delay(100);
