wii nunchuck joystick and servo issues
Hello all. I'm a newbie and am in desperate need of some help with my code for the wii nunchuck. I'm using most of the code that is derived from todbot.com (tod E kurt). I know the setup is good because his sample code with the x-axis accel works fine. I'm wanting to use the xaxis of the joystick to control my servo and am having major issues. Can anyone take a peek at my code and give some guidance. I've been trying all sorts of stuff and am getting no where. It looks like the xaxis values range from about 27 to the midpointof 121 and a max of 216. I thought I could use the map function to transpose them to the servo positions. Is this wrong? If so, what should I be doing. Thanks for the help!
 * based off code from tod E kurt.
 * 2007 Tod E. Kurt, http://todbot.com/blog/
 * The Wii Nunchuck reading code is taken from Windmeadow Labs
 *   http://www.windmeadow.com/node/42
 */#include <Servo.h>
#include <Wire.h>
Servo myservo;
int servoPin=9;
int pulse = 0;        // Amount to pulse the servo
int refreshTime = 20; // the time needed in between pulses
int ledPin = 13;
int loop_cnt=0;
  myservo.attach(servoPin);
  myservo.write(0);
  Serial.begin(19200);
  nunchuck_setpowerpins(); // use analog pins 2&3 as fake gnd & pwr
  nunchuck_init(); // send the initilization handshake
  Serial.print("NunchuckServo ready\n");
  checkNunchuck();
  updateServo();   // update servo position
    if( nunchuck_zbutton() )      // light the LED if z button is pressed
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin,LOW);
  delay(1);        // this is hear to give a known time per loop
void checkNunchuck()
  if( loop_cnt > 100 ) {  // loop()s is every 1msec, this is every 100msec
    nunchuck_get_data();  //get chuck data
    nunchuck_print_data();
    pulse= (float) nunchuck_joyx();    //use nunchuck values to transpose to servo position
    loop_cnt = 0;  // reset for
  loop_cnt++;
void updateServo()
pulse=map(pulse,27,216,0,179);  //map xaxis values to servo positions?
myservo.write(pulse);  //write resulting servo positions
delay(refreshTime);  // wait 20 sec
// Nunchuck functions
static uint8_t nunchuck_buf[6];   // array to store nunchuck data,
// Uses port C (analog in) pins as power & ground for Nunchuck
static void nunchuck_setpowerpins()
#define pwrpin PORTC3
#define gndpin PORTC2
    DDRC |= _BV(pwrpin) | _BV(gndpin);
    PORTC &=~ _BV(gndpin);
    PORTC |=  _BV(pwrpin);
    delay(100);  // wait for things to stabilize
// initialize the I2C system, join the I2C bus,
// and tell the nunchuck we're talking to it
void nunchuck_init()
  Wire.begin();                      // join i2c bus as master
  Wire.beginTransmission(0x52);      // transmit to device 0x52
  Wire.send(0x40);            // sends memory address
  Wire.send(0x00);            // sends sent a zero.
  Wire.endTransmission();      // stop transmitting
// Send a request for data to the nunchuck
// was "send_zero()"
void nunchuck_send_request()
  Wire.send(0x00);            // sends one byte
// Receive data back from the nunchuck,
// returns 1 on successful read. returns 0 on failure
int nunchuck_get_data()
  int cnt=0;
  Wire.requestFrom (0x52, 6);      // request data from nunchuck
  while (Wire.available ()) {
    // receive byte as an integer
    nunchuck_buf[cnt] = nunchuk_decode_byte(Wire.receive());
    cnt++;
  nunchuck_send_request();  // send request for next data payload
  // If we recieved the 6 bytes, then go print them
  if (cnt >= 5) {
    return 1;   // success
  return 0; //failure
// Print the input data we have recieved
// accel data is 10 bits long
// so we read 8 bits, then we have to add
// on the last 2 bits.  That is why I
// multiply them by 2 * 2
void nunchuck_print_data()
  static int i=0;
  int joy_x_axis = nunchuck_buf[0];
  int joy_y_axis = nunchuck_buf[1];
  int accel_x_axis = nunchuck_buf[2]; // * 2 * 2;
  int accel_y_axis = nunchuck_buf[3]; // * 2 * 2;
  int accel_z_axis = nunchuck_buf[4]; // * 2 * 2;
  int z_button = 0;
  int c_button = 0;
  // byte nunchuck_buf[5] contains bits for z and c buttons
  // it also contains the least significant bits for the accelerometer data
  // so we have to check each bit of byte outbuf[5]
  if ((nunchuck_buf[5] >> 0) & 1)
    z_button = 1;
  if ((nunchuck_buf[5] >> 1) & 1)
    c_button = 1;
  if ((nunchuck_buf[5] >> 2) & 1)
    accel_x_axis += 2;
  if ((nunchuck_buf[5] >> 3) & 1)
    accel_x_axis += 1;
  if ((nunchuck_buf[5] >> 4) & 1)
    accel_y_axis += 2;
  if ((nunchuck_buf[5] >> 5) & 1)
    accel_y_axis += 1;
  if ((nunchuck_buf[5] >> 6) & 1)
    accel_z_axis += 2;
  if ((nunchuck_buf[5] >> 7) & 1)
    accel_z_axis += 1;
  Serial.print(i,DEC);
  Serial.print("\t");
  Serial.print("joy:");
  Serial.print(joy_x_axis,DEC);
  Serial.print(",");
  Serial.print(joy_y_axis, DEC);
  Serial.print("  \t");
  Serial.print("acc:");
  Serial.print(accel_x_axis, DEC);
  Serial.print(",");
  Serial.print(accel_y_axis, DEC);
  Serial.print(",");
  Serial.print(accel_z_axis, DEC);
  Serial.print("\t");
  Serial.print("but:");
  Serial.print(z_button, DEC);
  Serial.print(",");
  Serial.print(c_button, DEC);
  Serial.print("\r\n");  // newline
  i++;
// Encode data to format that most wiimote drivers except
// only needed if you use one of the regular wiimote drivers
char nunchuk_decode_byte (char x)
  x = (x ^ 0x17) + 0x17;
  return x;
// returns zbutton state: 1=pressed, 0=notpressed
int nunchuck_zbutton()
   return ((nunchuck_buf[5] >> 0) & 1) ? 0 : 1;  // voodoo
int nunchuck_cbutton()
   return ((nunchuck_buf[5] >> 1) & 1) ? 0 : 1;  // voodoo
// returns value of x-axis joystick
int nunchuck_joyx()
  return nunchuck_buf[0];
// returns value of y-axis joystick
int nunchuck_joyy()
  return nunchuck_buf[1];
// returns value of x-axis accelerometer
int nunchuck_accelx()
  return nunchuck_buf[2];   // FIXME: this leaves out 2-bits of the data
// returns value of y-axis accelerometer
int nunchuck_accely()
  return nunchuck_buf[3];   // FIXME: this leaves out 2-bits of the data
// returns value of z-axis accelerometer
int nunchuck_accelz()
  return nunchuck_buf[4];   // FIXME: this leaves out 2-bits of the data
