Wiichuck Accelerometer Servo Control Issues
Hey Everyone,
I'm working on a ball labyrinth game controlled by two servos. I've been able to get the servos to respond to both the xy axis of the accelerometer of the Wiichuck but the servos are very shaky. The servos are hooked up directly to the digital inputs.
I've been reading about oversampling as a possible solution but I'm not too experienced with the arduino and coding in general any advice would be great. I've included a video as well: Servos connected to Labyrinth - YouTube
Thanks!
Code:
 * WiiChuckDemo --
 * 2008 Tod E. Kurt, http://thingm.com/
#include <Wire.h>
#include "nunchuck_funcs.h"
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
Servo myservo2;
int val;    // variable to read the value from the analog pin
int val2;
int loop_cnt=0;
byte accx,accy,zbut,cbut;
int ledPin = 13;
    Serial.begin(19200);
    nunchuck_setpowerpins();
    nunchuck_init(); // send the initilization handshake
    Serial.print("WiiChuckDemo ready\n");
        myservo.attach(10);  // attaches the servo on pin 9 to the servo object
        myservo2.attach(11);
    if( loop_cnt > 1 ) { // every 100 msecs get new data
        loop_cnt = 0;
        nunchuck_get_data();
        accx  = nunchuck_accelx(); // ranges from approx 70 - 182
        accy  = nunchuck_accely(); // ranges from approx 65 - 173
        zbut = nunchuck_zbutton();
        cbut = nunchuck_cbutton();
        Serial.print("accx: "); Serial.print((byte)accx,DEC);
        Serial.print("\taccy: "); Serial.print((byte)accy,DEC);
        Serial.print("\tzbut: "); Serial.print((byte)zbut,DEC);
        Serial.print("\tcbut: "); Serial.println((byte)cbut,DEC);
  val = accx;
  val = map(val, 70, 182, 0, 180 );
  myservo.write(val);
  delay(15);
  val2 = accy;
  val2 = map(val2, 173, 65, 0, 180);
  myservo2.write(val2);
  delay(15);
    loop_cnt++;
    delay(0);
Servo myservo2;
int val2;
I love consistency. Makes it so much easier to understand code.
  val = accx;
As opposed to
  val = map(accx, 70, 182, 0, 180 );
    delay(0);
Lovely.
I wire mine to outputs, but, whatever floats your boat.
