WiiChuck-Error No such file or directory
Hi!
I’m trying to make a wii nunchuck controlled robot using the WiiChuck library.
When I’m writing #include and compiling it I get this error message:
Arduino:1.6.9 (Windows 7), Board:“Arduino/Genuino Uno”
WARNING: Spurious .github folder in ‘Adafruit Motor Shield library’ library
C:\Users\Isac\Desktop\programmering\arduino\Skräp Arduino\sketch_feb22a\sketch_feb22a\sketch_feb22a\sketch_feb22a\sketch_feb22a.ino:1:20: fatal error: WiiChuck: No such file or directory
compilation terminated.
exit status 1
Error compiling for board Arduino/Genuino Uno.
And after a couple of seconds, this pops up:
Invalid library found in C:\Users\Isac\Documents\Arduino\libraries\Fritzing-master: C:\Users\Isac\Documents\Arduino\libraries\Fritzing-master
Invalid library found in C:\Users\Isac\Documents\Arduino\libraries\wiichuck_adapter-master: C:\Users\Isac\Documents\Arduino\libraries\wiichuck_adapter-master
“Show verbose output during compilation”
option enabled in File → Preferences.
When I’m going to Sketch->include library->Handle library and searching on WiiChuck it says installed.
Do you have a file named WiiChuck on your system ?
Do you perhaps have a library folder named WiiChuck with files named WiiChuck.h and WiiChuck.cpp in it ?
If so you should almost certainly be #including WiiChuck.h in your program.
Are there any examples with the WiiChuck library, assuming that you have the library in the first place.
Please post your complete program.
I have a library folder named WiiChuck and some of the files in it are named WiiChuck and not WiiChuck.h.
My library has two examples, WiiServoMap and WiiChuck_Serial_Demo.
They have write #include <WiiChuck.h> in my library examples, and when I’m compiling it this error comes:
Arduino:1.6.9 (Windows 7), Kort:“Arduino/Genuino Uno”
C:\Users\Isac\Documents\Arduino\libraries\WiiChuck\examples\Arduino\WiiServoMap\WiiServoMap.ino: In function ‘void setup()’:
WiiServoMap:20: error: ‘D3’ was not declared in this scope
myChuck.addControlMap(D3, // Servo IO pin
WiiServoMap:28: error: ‘D4’ was not declared in this scope
myChuck.addControlMap(D4, // Servo IO pin
WiiServoMap:40: error: ‘D6’ was not declared in this scope
myChuck.addButtonMap(D6, // Servo IO pin
exit status 1
It does not say No such file or directory.
That sounds like the Windows trick of hiding file extensions as you cannot have 2 files with the same name in the same folder.
Anyway, it seems that the problem has moved on, albeit to a different error. Can you please post the complete program that gave the errors quoted in your previous message.
Here is the example code:
#if defined(ARDUINO_ARCH_ESP8266)
#define SDA D2
#define SCL D1
#endif
WiiChuck myChuck(SDA, SCL);
Serial.println("\n\nStarting WiiChuck Demo");
myChuck.printServos=true;
myChuck.usePullUpClock = false;
// optional functions
//JOY_X,JOY_Y,ROLL,PITCH,ACCELX,ACCELY ,ACCELZ,
//classic controller
//RSPRESSURE,LSPRESSURE,LEFTSTICKX,LEFTSTICKY,RIGHTSTICKX,RIGHTSTICKY
20, // Servo low value
50, // servo middle
130, // servo upper bound
-100, // ontroller lower bound
0, // controller middle
100, //controller upper bound
JOY_X); // Enum for the data source
170, // mapping cna be reversed by swapping upper and lower
92, // swapping upper and lower pivots around center
20, // upper value need not be larger than the lower
-100, //lower bound cna be non symetric with upper bound
100, // upper controller bound
JOY_Y);// different enum for another function
// button mapping
//CBUTTON,ZBUTTON
//LZ,RZ,LD,RD,UD,DD,SL,H,START,X,Y,A,B
60,// released value
130, //pressed falue
ZBUTTON);// select a button funtion
myChuck.begin();
myChuck.readData();
delay(60);
And the error:
exit status 1
Where did you get the WiiChuck library from ?
I found a Wiichuck library at Wiichuck library but the examples are nothing like the one you posted.
Note the subtle difference in the names of the libraries.
Hi!
I downloaded the Wiichuck library from GitHub and when I’m writing #include <Wiichuck.h> and compiling it, it says no error!!! Thank you for helping me. Now can I finish my project!
