Wildly incorrect Wire.requestFrom() results!
I’m getting radically inconsistent results using Wire.requestFrom()
EDIT: The master is a NodeMCU (ESP8266 based). I think that’s the problem. It seems to work fine with a Leonardo.
It seems to either pass the correct byte back to the master, or the master receives the value of the byte divided by 2 or 4. I haven’t found a consistent way to reproduce the bugs.
Everything else i2c works totally fine.
I made this test script to debug:
#include <Wire.h>
byte readbyte = 0;
  Wire.begin(D3, D4);
  Wire.requestFrom(12, 1);
  while (Wire.available()) {
    readbyte = byte(Wire.read());
    Serial.println(readbyte);
  delay(100);
#include <Wire.h>
byte urmom = 255;
  Wire.begin(12);
  Wire.onRequest(requestEvent);
void requestEvent() {
  Wire.write(byte(40));
  Serial.println(urmom);
//  urmom++;
//  if (urmom == 255)
//    urmom = 0;
In the slave code, I tried using a byte variable, a constant byte, and a constant byte with the byte() function. I also tried incrementing a byte by one between each request.
It either sends the byte just fine, or the master receives the byte divided by 4 or 2, or the master receives the byte divided by either 4 but occasionally changes to dividing by two whille the program is running (or 2 to 4).
The results are not consistent.
What is going on here?!
So, it's sporadically losing a bit or two. I'd suggest that this might be something electrical - capacitance across the leads, or something like that.
Try using a different pin. Try using a different set of connecting leads. Try making i2c wire as short as possible. Fool with the value of the i2c pull-up resistor. Add a decouplng capacitor somewhere - I don't know that much about electronics, not sure where it would go. Make sure that both pieces of equipment have a common ground - bad soldering?
That kind of thing. Computers are deterministic, you aren't going to find the cause of an intermittent bug in the code. Well, not usually.
