Will a Neopixel code work on Dotstar?
Hi everyone, i was wonder if i can use the code i used in adafruit Neopixel to my new Dotstar Strip,, i was really planing to buy the neopixel coz im comfortable with it , but unluckly its out of stock ,,, and how to change the pin assignments since Dotstar apa102 has 2, the data pin and clock pin,,, your help is Highly appreciated...
What library are you using? What ever it is their will be an option when you initialise it to select both the LED type and the pin assignment. All the rest of the code will run just the same.
thnx for the reply Grumpy_Mike:
here is my example code
#ifdef AVR
#include <avr/power.h>
#endif
#define PIN 6
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic ‘v1’ (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, PIN, NEO_GRB + NEO_KHZ800);
// IMPORTANT: To reduce NeoPixel burnout risk, add 1000 uF capacitor across
// pixel power leads, add 300 - 500 Ohm resistor on first pixel’s data input
// and minimize distance between Arduino and first pixel. Avoid connecting
// on a live circuit…if you must, connect GND first.
// This is for Trinket 5V 16MHz, you can remove these three lines if you are not using a Trinket
#if defined (AVR_ATtiny85)
if (F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
// End of trinket special code
strip.begin();
strip.show(); // Initialize all pixels to ‘off’
// Some example procedures showing how to display to the pixels:
colorWipe(strip.Color(255, 0, 0), 50); // Red
colorWipe(strip.Color(0, 255, 0), 50); // Green
colorWipe(strip.Color(0, 0, 255), 50); // Blue
//colorWipe(strip.Color(0, 0, 0, 255), 50); // White RGBW
// Send a theater pixel chase in…
theaterChase(strip.Color(127, 127, 127), 50); // White
theaterChase(strip.Color(127, 0, 0), 50); // Red
theaterChase(strip.Color(0, 0, 127), 50); // Blue
rainbow(20);
rainbowCycle(20);
theaterChaseRainbow(50);
// Fill the dots one after the other with a color
void colorWipe(uint32_t c, uint8_t wait) {
for(uint16_t i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, c);
strip.show();
delay(wait);
void rainbow(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256; j++) {
for(i=0; i<strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel((i+j) & 255));
strip.show();
delay(wait);
// Slightly different, this makes the rainbow equally distributed throughout
void rainbowCycle(uint8_t wait) {
uint16_t i, j;
for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
for(i=0; i< strip.numPixels(); i++) {
strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
strip.show();
delay(wait);
//Theatre-style crawling lights.
void theaterChase(uint32_t c, uint8_t wait) {
for (int j=0; j<10; j++) { //do 10 cycles of chasing
for (int q=0; q < 3; q++) {
for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
strip.setPixelColor(i+q, c); //turn every third pixel on
strip.show();
delay(wait);
strip.setPixelColor(i+q, 0); //turn every third pixel off
//Theatre-style crawling lights with rainbow effect
void theaterChaseRainbow(uint8_t wait) {
for (int j=0; j < 256; j++) { // cycle all 256 colors in the wheel
strip.setPixelColor(i+q, Wheel( (i+j) % 255)); //turn every third pixel on
strip.show();
delay(wait);
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
WheelPos = 255 - WheelPos;
if(WheelPos < 85) {
return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
if(WheelPos < 170) {
WheelPos -= 85;
return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
WheelPos -= 170;
return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
Please read the how to use this forum sticky post on how to correctly post code.
That looks like an independent version of the library, they do have one that supports dot star.
MackieZ:
#ifdef AVR
#endif
#define PIN 6
#endif
strip.begin();
rainbow(20);
rainbowCycle(20);
strip.show();
delay(wait);
uint16_t i, j;
strip.show();
delay(wait);
uint16_t i, j;
strip.show();
delay(wait);
strip.show();
delay(wait);
strip.show();
delay(wait);
if(WheelPos < 85) {
WheelPos -= 85;
WheelPos -= 170;
[code][/code]
i have to apologize Grumpy_Mike, i was also having a problem on how to load codes here in forums,,, did i do it right on the 2nd post?,,,, tnx for the correction
You still have not done it right. You are using the quote icon, you need to use the code icon, it is the one on the top left and looks like </>
Just put the code between the tags not the words. You can edit your post, the lower right corner of your post is a triangle, clicks on that and pick modify. Then you get your post to edit. Yes u also need to say what pins you are going to connect to what button and how you have wired it up.
(deleted)
See this for the Adafruit dot star driver:- https://learn.adafruit.com/adafruit-dotstar-leds/overview Their is a link to down load the libiary.
fastLED is a much better library for controlling "neopixels" (ws2812) and "dotstats" (apa104)... and the best part is you write code for one set of led strips, then by changing one line of code, have them work for a different set of led strips.
fastLED
many tnx for all your replys, i just want to try if the code that i send would work on dotstar,, ill try to give it a shot & ill visit ur links,, & i really would like to give fastLED a big try too...
