Will it be to much for my arduino Uno?
In my project I'll connect to my arduino 5V output a Servo LCD and a 5V DC Motor (fan) will it be to much for my arduino to supply (power wise).
Also I have a 4Ω spekar connected to one of the PWM pins.
Is it OK or should I get an 9V external battery with 5V regulator(7805)?
You should not power even a single motor or servo from the Arduino 5v pin.
If you need a simple external power supply for a servo a pack of 4 AA NiMh batteries would be a good option.
I presume you have circuit of some sort (maybe just a transistor) between the Arduino and the fan.
The PP3 type of 9v battery is useless as it cannot provide enough current. And a 7805 is a very wasteful voltage regulator.
I am not familiar with using speakers but I would worry that any of them (4, 8 or 16ohms) would draw too much current from an Arduino pin. The absolute max you should draw is 40 mA and at 5v that would require a 125 ohm resistance. 20 mA and 250 ohms would be a lot more sensible.
...R
Robin2:
...R
I do have a transistor and a diode in the fan circuit.
You think a 4 pack of 1.5V AA battries will do the work?
I only need it to work once and not continously so reachargable batteries is not neccessery.
But will 6v AA battery will do the work for a DC 5V Motor, Servo and a LCD?
To my knowladge it's fine to connected a small speaker (such as 4Ω-3A) to the arduino with 1K resistor in line with it.
But I'll ask my teacher about it too.
(It's high scool priject for senoir year).
T-rex166:
You did not mention the 1k resistor earlier. That will provide protection.
As to the batteries, try it and see what happens.
I assume the Arduino will be powered from the USB connection to your PC and there should be no problem powering the LCD from the Arduino.
...R
Robin2:
...R
OK thank you for your help.
