will not read value of button?
hi I am using a button to control two continuous servo motors the button is a input pullup but when I press the button nothing happens, when I checked Serial monitor when button is pressed it only returns a value 1 never 0 I don't know why. here is code also circuit is below.
[code]
#include <Servo.h>
Servo rightMotor;
Servo leftMotor;
const int button = 12;
int buttonPress = 0;
void setup(){
  rightMotor.attach(5);
  leftMotor.attach(6);
  pinMode(button, INPUT_PULLUP);
void loop(){
 buttonPress = digitalRead(button);
 Serial.print(buttonPress);
 Serial.println(" ");
 if(buttonPress == LOW){
  moveForward(1000);
  Stop(500);
  turnRight(800);
  Stop(500);
  turnLeft(800);
  Stop(500);
  moveBack(800);
  Stop(300);
  turnRight(300);
  Stop(300);
 else{
  stopAll();
void moveForward(int delay1){
  rightMotor.write(0);
  leftMotor.write(180);
  delay(delay1);
void moveBack(int delay2){
  rightMotor.write(180);
  leftMotor.write(0);
  delay(delay2);
void turnRight(int delay3){
  leftMotor.write(91);
  delay(delay3);
void turnLeft(int delay4){
  rightMotor.write(91);
  delay(delay4);
void Stop(int delay5){
  delay(delay5);
void stopAll(){
[/code]
Show us a good picture of the actual wiring.
image is below
Did you try turning the button 90 degrees?
yes I even switched the button with another
Try replacing the two wires connected to the switch.
Also replace the black wire going to GND on the Arduino.
thanks it worked
If you have a DVM you should check all your wires for continuity.
