Will the bootloader be erased if hex code is uploaded using programmer?
I am going to buy a programmer and test it out. Will the bootloader be erased if hex code is uploaded using programmer? If I want to use back the Arduino IDE, do I have to re-upload the Arduino bootloader back?
Right. If an Arduino ("chip", et al.) is uploaded via ICSP then the bootloader gets wiped out. To then upload to the Arduino via USB/serial will require its being re-bootloaded. You can upload via ICSP from within the Arduino IDE, too.
lightaiyee: I am going to buy a programmer and test it out. Will the bootloader be erased if hex code is uploaded using programmer?
[/quote]
Yes.
lightaiyee: If I want to use back the Arduino IDE, do I have to re-upload the Arduino bootloader back?
Yes.
lightaiyee: I am going to buy a programmer and test it out. Will the bootloader be erased if hex code is uploaded using programmer? If I want to use back the Arduino IDE, do I have to re-upload the Arduino bootloader back?
Just make sure the last hex code file you program is a bootloader. :)
