hi everyone!
well iv been serverly bored lately so im going to actually spend some money and do a project (a elabrate car remote/ electronic key).
i have a few questions before i buy mainly if the stuff i want will actualy work:
is this tranciever compatible with arduino? http://www.sparkfun.com/commerce/product_info.php?products_id=153# if so i will buy 2 for communication between each other.
am i able to use the attiny13 with arduino (without the bootloader) http://www.sparkfun.com/commerce/product_info.php?products_id=211 otherwise can you please point me to some smaller microcontrollers as i dont want the remote to be to big (itl only be 2 buttons with wireless and a few wires coming out the front) otherwise ill just use the atmega168
wil the MAX1555 constantly power the microcontroller while switching between charging and running off battery? also which switcher should i use if i dont use lipo batterys as i would pefer to use a littler battery (3v rechargable cell)
how would i make it if its plugged into the "car" as a key that it only sends the codes throught the wireing to the "cars" controller and not over the wireless?
getting more random now...
if it works and well (unlikely(ill probably give up by then :P)) i would like to do it properly onto a pcb so here are the new questions:
is there any reason i cannot use the Crystal SMD 16MHz over the normal non smd chip?
also where is a good site that sells SMD components (resistors ect)
another thing with the random code
heres my code:
void setup(){
void loop(){
Serial.println(random(100000000, 999999999));
delay(20);
so extremely simple just produce a random number between 100000000 and 999999999 (so the output is always that many digits long) the problem is it never goes random for the whole thing. so heres an example output
100016807
100015089
100011481
100003114
100014210
100023240
100003800
100002558
100012099
100001101
100006296
100015445
100004748
100023522
100021683
100014151
100014615
100016657
100017304
100018772
100011823
100011025
100005677
100002821
100012888
100026357
100000363
100007638
100030600
100007431
100025753
100013458
100003912
100020787
100028258
100005185
100019699
100003853
100020515
100027365
100030815
100013616
100008913
100030408
100030189
100017761
100026636
100005451
100010498
100021557
100000057
100020609
100025732
100009656
100025876
100007074
100013212
100026292
100028250
100004711
100011306
100013514
100023269
100004680
100018921
100008389
100001521
100008880
100022212
100007189
100011146
100004581
100027291
100030797
100017209
100030198
100002039
100009960
100019617
100004101
100027347
100030974
100029677
100019877
100014549
100024819
100006873
100019684
100015451
100015354
100021612
100003523
100004433
100029666
100007200
100008110
100004108
100007905
100032006
100009880
100024685
100014177
100024575
100028980
100006305
100031774
100015129
100006909
100023094
100012880
100017129
100003511
100006785
100012175
100004035
100029754
100017182
100028943
100007616
100022316
100004676
100013397
100019066
100004040
100011947
100024144
100001225
100026034
100006366
100008882
100026870
100010421
100011746
100023116
100024655
100031709
100000927
100023688
100028263
100021181
100011726
100022047
100019442
100008545
100028928
100030606
100009848
100006551
100011671
100009486
100023092
100010850
100018183
100009431
100011358
100025671
100006817
100018520
100013353
100006286
100018267
100014242
100003061
100007010
100019526
100002438
100030620
100016068
100016174
100009014
100018730
100027906
if someone can help me so i can make it so it is using all the numbers for randomness.
thanks heaps in advance :D
callum
