will this code for communicating between an uno and attiny84 work?
Hello! I wanted communication between arduino uno and attiny84 in hardware , but for the time being, i started to write a sketch to bitbang i2c until the hardware version could be ready . till now, for attiny, i did this
unotx(B00001000);//ADDRESS OF UNO - 8
unotx(B01001100);// i dont know what this byte  means, i just felt like using it
/*register description -
 * no need to set any pins as outputs. method will do it on its own, it transmits ONE byte, it clears everything and sets pins to input after execution.
 * NOTE!- GPIOR0,1,2,PORTB,DDRB are being used. they will be CLEARED before usage! please tell if this hampers with any functionality of anything.
 * 0x13- GPIOR0- the register to store how many bits were transmitted (counting thingy)
 * 0x14 -GPIOR1- the register in which you have to put  data in (source)
 * ox15- GPIOR2- the register on which all operations are performed and the next state of portb is determined(mediator)
 * 0x18- portb- the register to use temporarily to transmit data to arduino uno's hardware i2c
 * 0x17-ddrb (data direction  register)
void unotx(byte x){
  GPIOR1 = x;
  asm("andi 0x15,0\n"
      "andi 0x13,0\n"
      "andi 0x18,252\n"
      "ori 0x17,3\n"
      "s:\n"
      "cbi 0x18,1\n"
      "cp 0x13,8\n"
      "breq a\n"
      "mov 0x15,0x14\n"
      "andi 0x15,1\n"
      "mov 0x18,0x15\n"
      "sbi 0x18,1\n"
      "ror 0x15\n"
      "inc 0x13\n"
      "rjmp s\n"
      "a:\n"
      "andi 0x17,252\n"
      "andi 0x15,0\n"
      "andi 0x18,252\n"
      "andi 0x13,0\n");}
sorry for lack of documentation in asm block, PB0 should function as data, PB1 should function as clock
after that , i thought that i should be able to use this without any reprogramming for arduino uno . so i got a copy of arduinoisp sketch and added the lines necessary for recieving the byte to it.
i added “#include <Wire.h>” before everything;
i added " Wire.begin(8); // join i2c bus with address #8
Wire.onReceive(receiveEvent); // register event" to setup
i added "void receiveEvent(int howMany) {
byte c = Wire.read(); // receive byte
SERIAL.println(c,BIN); // print the character in binary format
i used asm on attiny because i thought it could save me some memory .
after the neccesary connections, will it WORK?
i wanted to ask this before uploading this to attiny and arduino uno to avoid any damage.
i want the scond code to - 1)upload code to attiny,
2)take data from it and put it into serial monitor to it when it asks.
i want the communication to be one- way to make the code lightweight.
thanks!
ok, i think " 8 )" means an emoji .... sorry for that.
