Will this work or is there a better way to do it ?
So right now I am designing pcb for my first bigger project and I have some questions. First is are these L9110 chips able to run 4 5V dc motors at once or is there a better alternative? They will be power through power bank same as the arduino. Thanks
Four of them could possibly run 4 motors but unfortunately you’ve missed out the important part of the motor specification, the current needed. If it is within the L9110’s current limit it will be o.k. If it isn’t it won’t.
Steve
Sorry, at 5 V it is 100mA. I have heard that there is a voltage drop from the tranzistor at around 1.4V in the L9110 chip. Will it still be able to run the motors ?
Do those motors need to run both directions? Speed control?
There are lots of more modern H-bridges around, based on CMOS technology. Those don't have the total 2V loss (the datasheet that I found indicates losses of 0.45V for the low side and 1.5V for the high side).
This project should be something like a rc car controled by a IR sensor or a joystick so the motors have to run both directions but I don't need a speed control.
Please rearead HOW TO USE THIS FORUM.
It is a sticky post at the top of every forum
Please read #6 about subject lines
And #7 about how to post code.
I don't think it has been added to so as to shshow how to post pictures......
