Win 8 woes
If it were me responding to this post I would say, “This cannot be.” But here it is anyway:
The accompanying sketch compiles fine on my Windows 7 desktop and the sketch runs in the application just fine.
So I copied the sketch to my Winows 8.1 laptop and download the same Arduino IDE 1.0.5-r2. In that system the sketch evokes error messages from the IDE when I try to compile. Both arduino folders have the same compliment of libraries.
What’s going on?
ERROR MESSAGES:
Cat_Feeder_10:24: error: ‘AF_DCMotor’ does not name a type
Cat_Feeder_10.ino: In function ‘void setup()’:
Cat_Feeder_10:33: error: ‘motor’ was not declared in this scope
Cat_Feeder_10.ino: In function ‘void MoveDoor(int)’:
Cat_Feeder_10:130: error: ‘motor’ was not declared in this scope
Cat_Feeder_10:130: error: ‘BACKWARD’ was not declared in this scope
Cat_Feeder_10:137: error: ‘RELEASE’ was not declared in this scope
Cat_Feeder_10:147: error: ‘RELEASE’ was not declared in this scope
Cat_Feeder_10:155: error: ‘motor’ was not declared in this scope
Cat_Feeder_10:155: error: ‘FORWARD’ was not declared in this scope
Cat_Feeder_10:157: error: ‘RELEASE’ was not declared in this scope
// CF_8: Change setup of serial software CF_10: try to eliminate hatch close delay
#include <SoftwareSerial.h>
#include <AFMotor.h>
const int DOORSENSOR_OPEN=14;
const int DOORSENSOR_CLOSED=15;
const int MODE_pin=16;
const int MANUALOPEN_pin=17;
const int IR_pin = 4;
const int IR_cutoff=50;
int printed_already;
const int rxpin = 0; //TT from RFID_3
const int txpin = 1; //TT
//RF reader is connected to RX pin 0 for serial input
const int OPEN=1;
const int CLOSE=0;
int door_state;
int val;
const int set_time1=2000;
long startMillis;
AF_DCMotor motor(3, MOTOR12_64KHZ);
SoftwareSerial mySerial(rxpin, txpin); //TT: WAS: //SoftwareSerialmySerial(2, 3)
int incomingByte = 0;
  mySerial.begin(9600);
  Serial.println("Cat feeder!");
  motor.setSpeed(255);
  digitalWrite(14, LOW);
  digitalWrite(15, LOW);
  digitalWrite(16, LOW);
  digitalWrite(17, LOW);
  door_state=CLOSE;
  printed_already=0;
  byte valr;
  if(digitalRead(MODE_pin)==LOW) //switch set to manual
    delay(10);
    if(digitalRead(MODE_pin)==LOW)//debouncing
     if((printed_already==0) || (printed_already==2))
     Serial.println("MODE = manual");
     printed_already=1;
      if(digitalRead(MANUALOPEN_pin)==HIGH) //toggle button is pressed
        delay(10);
        if(digitalRead(MANUALOPEN_pin)==HIGH)//debouncing
          if(door_state==OPEN)
            Serial.println("trying to close now ...");
            MoveDoor(CLOSE);//close the door
          else if(door_state==CLOSE)
            Serial.println("trying to open now ...");
            MoveDoor(OPEN);//close the door
  else if(digitalRead(MODE_pin)==HIGH) //switch set to automatic
  delay(10);
  if(digitalRead(MODE_pin)==HIGH) //debouncing
    if((printed_already==0) | (printed_already==1))
      Serial.println("MODE = automatic");
      printed_already=2;
    if((RFID() == 1) && (door_state==CLOSE))//RF activated
      MoveDoor(OPEN);
    else //RF not active, we may have to close the door
      if(door_state==OPEN)//DOOR is open
        if(analogRead(IR_pin)<IR_cutoff)//there is no cat
          startMillis = millis();
          Serial.println("starting timer...");
          //while nothing happens, the timer runs out
          while(millis()-startMillis<set_time1)
            if(millis()%50<5) // Was 500
            Serial.println(analogRead(IR_pin));
            if(analogRead(IR_pin)>=IR_cutoff)
              Serial.println("Cat detected. Resetting timer ...");
              delay(100); // originally 1000
          //RF is still not activated, there really is no cat
            Serial.println("Timer ran out.");
              while(mySerial.available())
              valr = mySerial.read();//empty the buffer
            MoveDoor(CLOSE); //close the door
void MoveDoor(int openclose)
    int cat_alert;
    cat_alert=0;
    if(openclose==CLOSE) //close the door!
      motor.run(BACKWARD);
      while ( (digitalRead(DOORSENSOR_CLOSED)==LOW) && cat_alert==0)
         {if(analogRead(IR_pin)>IR_cutoff)
           {delay(20);
             cat_alert=1;
             motor.run(RELEASE);
             openclose=OPEN;
       //if there is no cat
       //if there is, door opens in next if-statement
        if(cat_alert==0)
          motor.run(RELEASE);
          door_state=CLOSE;
          Serial.println("it's closed.");
    if(openclose==OPEN) //open the door!
      motor.run(FORWARD);
      while ((digitalRead(DOORSENSOR_OPEN)==LOW) );
      motor.run(RELEASE);
      door_state=OPEN;
      Serial.println("it's open.");
int RFID()
  byte i = 0;
  byte val = 0;
  byte code[6];
  byte checksum = 0;
  byte bytesread = 0;
  byte tempbyte = 0;
  int result = 0;
  if(mySerial.available()) {
    result=1;
    if((val = mySerial.read()) == 0x02) {
      bytesread = 0;
      Serial.println("I read it");
      while (bytesread < 12) {// read 10 digit code + 2 digit checksum
          val = mySerial.read();
          if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02)) {
            break; // stop reading
          // Do Ascii/Hex conversion:
          if ((val >= '0') && (val <= '9')) {
            val = val - '0';
          } else if ((val >= 'A') && (val <= 'F')) {
            val = 10 + val - 'A';
          // Every two hex-digits, add byte to code:
          if (bytesread & 1 == 1) {
            // make some space for this hex-digit by
            // shifting the previous hex-digit with 4 bits to the left:
            code[bytesread >> 1] = (val | (tempbyte << 4));
            if (bytesread >> 1 != 5) {// If we're at the checksum byte,
              checksum ^= code[bytesread >> 1];// Calculate the checksum... (XOR)
            tempbyte = val; // Store the first hex digit first...
          bytesread++; // ready to read next digit
      // Output to Serial:
      if (bytesread == 12) {  // if 12 digit read is complete
        Serial.print("5-byte code: ");
        for (i=0; i<5; i++) {
          if (code[i] < 16) mySerial.print("0");
          Serial.print(code[i], HEX);
          Serial.print(" ");
        Serial.print("Checksum: ");
        Serial.print(code[5], HEX);
        Serial.println(code[5] == checksum ? " -- passed." : " -- error.");
        if(code[5] == checksum)
        result=1;
      bytesread = 0;
  return result;
What's going on?
But, clearly your Arduino sketchbook libraries folders do not match.
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the # button above the posting area.
How to use this forum
Turn on verbose compiling. It looks like it didn’t find the library (AFMotor.h).
lesizz:
Do you mean the Arduino app folder, or your sketchbook/libraries folder?
Sorry about the posting error. I manually inserted the demarcations for the code and got them backwards (D'oh!).
Being the newbie and not having played with the Arduino recently I forgot about the sketchbook/libraries folder, and that's where the requisite library was missing.
Thanks for the assist.
I still don't like Windows 8.
