Hi there, It is arming now but when I switch on the the arduino my motor starts running. The speed control is not that good and it stutters a bit. I can switch the motor off with my app and when i close the app it still is operating. Here is my code. Maybe there is a simple way and maybe mine is to complex. any help would be much appreciated
#include <Servo.h>
#include <SoftwareSerial.h>
int incomingByte = 0; // for incoming serial data
int armingTime;
int pin = 9;
int counter = 0;
int pulseTime = 1100; //microseconds
boolean highSpeed = true;
Servo myservo;
void setup(){
myservo.attach(9);
Serial.println(“Enter 0-9 to adjust motor speed.”);
Serial.println(“Enter h or l to change the speed range.”);
void loop(){
digitalWrite(pin, HIGH);
delayMicroseconds(pulseTime);
digitalWrite(pin, LOW);
delay(10-(pulseTime/1000));
if(Serial.available() > 0){
incomingByte = Serial.read();
//void incomingByte(){
//void readSerialVal(){
switch (incomingByte) {
case ‘0’:
setTimingParams(1100);
incomingByte=’*’;
Serial.print(“Throttle: “);
Serial.print((pulseTime-1100)/8);
Serial.println(”%”);
case ‘2’:
setTimingParams(1300);
incomingByte=’*’;
case ‘3’:
setTimingParams(1400);
incomingByte=’*’;
case ‘4’:
setTimingParams(1500);
incomingByte=’*’;
case ‘5’:
setTimingParams(1600);
incomingByte=’*’;
case ‘6’:
setTimingParams(1700);
incomingByte=’*’;
case ‘7’:
setTimingParams(1800);
incomingByte=’*’;
case ‘9’:
setTimingParams(1900);
incomingByte=’*’;
void setTimingParams(int newPulseTimeVal){
if(highSpeed){
pulseTime = newPulseTimeVal;
pulseTime = 1025 + (newPulseTimeVal/10);
