Winch System Payline in and Out (Solved) Any New Suggestions are Welcome!
Hello Everyone,
I am a noob to Arduino and I am looking for some help. I am trying to automate a winch system.
I want the winch to keep a load ranging between two voltage outputs on my load cell.
I have used bits and pieces of code I have found here and there. Most of it is from the ARDUINO Examples.
Everything is working ok until I try to add more data sets into the Index for the average, which makes me, think that my average is not working appropriately.
I am not a coder and I have been Reading the manual and experimenting but this is just kicking my butt.
It works if I use a lower numReadings (Example 25) but not a larger numReadings (Example 50).
At 50 on higher voltages, my average is becoming a negative, even though my voltage is still positive on the analog input pin. I verified with my MultiMeter.
P.S. I did read the forum http://forum.arduino.cc/index.php?topic=155767.0 Load cell - smoothing and using values in loop
Any Help is appreciated. Like I said I am very new and flipping through the C++ Books, But I know some of you have probably seen this and can explain a solution to me easily.
Cheers
RCNewt
// Winch System
//RCNEWTON V0.25
// Define the number of samples to keep track of.  The higher the number,
// the more the readings will be smoothed, but the slower the output will
// respond to the input.  Using a constant rather than a normal variable lets
// use this value to determine the size of the readings array.
const int numReadings = 50;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
int inputPin = A0;
int WinchPinUp = 11;           //Winch up
int WinchPinDown = 10;         //Winch Down
  // initialize serial communication with computer:
  // initialize all the readings to 0:
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
pinMode (WinchPinUp, OUTPUT);
pinMode (WinchPinDown, OUTPUT);
  // subtract the last reading:
  total= total - readings[index];
  // read from the sensor:
  readings[index] = analogRead(inputPin);
  // add the reading to the total:
  total= total + readings[index];
  // advance to the next position in the array:
  index = index + 1;
  // if we're at the end of the array...
  if (index >= numReadings)
    // ...wrap around to the beginning:
    index = 0;
  // calculate the average:
  average = (total * (5.00/1023.00)) / numReadings;
  // send it to the computer as ASCII digits
  Serial.println(average);
  delay(20);        // delay in between reads for stability
  {if (average >= 3.00) digitalWrite (WinchPinDown, HIGH); // Winch up for weights over x
   else digitalWrite (WinchPinDown, LOW); // Winch is off}
   {if (average <= 1.50) digitalWrite (WinchPinUp, HIGH); // Winch up for weights over x
   else digitalWrite (WinchPinUp, LOW); // Winch is off
total is an int which cannot therefore exceed 32767. You are probably overflowing it. Try making it float.
average is an int so comparing it to 1.5 is not useful. Try making average a float.
Thanks for the help!
That fixed it!
Looks like it is working smooth. Going to set it up tomorrow for a full scale test run on winch W/ relays!
I'm curious about this. Since total is being used to sum a series of integer values, why wouldn't you make total a long (or unsigned long), rather than a float?
Because if you average several integers the result is usually fractional?
PaulS: I'm curious about this. Since total is being used to sum a series of integer values, why wouldn't you make total a long (or unsigned long), rather than a float?
It needs to be converted to a float here anyway. Until then it could be a long admittedly.
That is not what [u]total[/u] is doing in OP's code.
WOW this has really opened up a lot learning to me... Thank Goodness for Google search and Index Pages in books.
Cheers RCNewt
