Windows 10, 64bit get NullPointerException trying to run Arduino_debug.exe
I'm trying to use Arbotix-m robot controller. Just got all this awesome new hardware. It says it only works with version 1.0.6. I had version 1.8 installed.
I removed version 1.8 and reinstalled 1.0.6 but it didn't work. I tried but the unzip version and the installer with the same result. When I try to run Arduino the logo pops up then disappears. When I run arduino_debug.exe I see this.
Exception in thread "main" java.lang.NullPointerException
        at processing.app.I18n._(I18n.java:51)
        at processing.app.Base.getSettingsFolder(Base.java:1454)
        at processing.app.Base.getSettingsFile(Base.java:1471)
        at processing.app.Preferences.init(Preferences.java:246)
        at processing.app.Base.main(Base.java:117)
There are no JAVA* environment variables set. I DO have Java installed at E:\Java\jre1.8.0_271
I would l really like to get these servos working, so any help would be appreciated.
Found out that it was looking for the preferences folder on a removable drive. I re-inserted the drive and everything just worked. The error message wasn't very helpful. What it was looking for would have been useful. All good now.
Karma for reporting back the fix.
