windows 10 can't upload sketch to node mcu
ertus:
Hi
Also ı had same issue now,ı can compile codes in windows 8.1 but ı cannot compile same codes in windows 10.
Arduino: 1.8.1 (Windows 10), Board: "Arduino/Genuino Uno"
exit status -1073741819
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware
C:\Program Files (x86)\Arduino\hardware -tools
C:\Program Files (x86)\Arduino\tools-builder -tools
C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries
C:\Program Files (x86)\Arduino\libraries -libraries
C:\Users\EV.HP-HP\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10801 -build-path C:\Users\EVF2C6~1.HP-\AppData\Local\Temp\arduino_build_965673 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=
C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=
C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=
C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\EVF2C6~1.HP\AppData\Local\Temp\untitled1419457049.tmp\sketch_jan19a\sketch_jan19a.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\EV.HP-HP\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=0X2A03_0X0043 -ide-version=10801 -build-path C:\Users\EVF2C6~1.HP-\AppData\Local\Temp\arduino_build_965673 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\EVF2C6~1.HP-\AppData\Local\Temp\untitled1419457049.tmp\sketch_jan19a\sketch_jan19a.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\EVF2C6~1.HP-\AppData\Local\Temp\arduino_build_965673\sketch\sketch_jan19a.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10801 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino" "-IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard" "C:\Users\EVF2C6~1.HP-\AppData\Local\Temp\arduino_build_965673\sketch\sketch_jan19a.ino.cpp" -o "C:\Users\EVF2C6~1.HP-\AppData\Local\Temp\arduino_build_965673\preproc\ctags_target_for_gcc_minus_e.cpp"
I am getting the same error for nodemcu board. Can you guide me through this??
"exit status -1073741819
Error compiling for board NodeMCU 0.9 (ESP-12 Module)"
Yours is not the exact same error as it is for a completely different MCU
TOPIC SPLIT
DO NOT HIJACK / NECRO POST !
Could you take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
