Windows 10 Update 1709, Arduino Don't Work, please help!!!!
Arduino:1.8.1 (Windows 10), Tarjeta:"Arduino Nano, ATmega328P"
readlink C:\Users\jcrui\OneDrive\Arduino - DOC\Arduino\hardware: El sistema no puede encontrar el archivo especificado.
Error compilación en tarjeta Arduino Nano.
Este reporte podría tener más información con
"Mostrar salida detallada durante la compilación"
opción habilitada en Archivo -> Preferencias.
The IDE can be a little fussy when it comes to using network locations for sketches and libraries.
The ONEDRIVE is probably not your best option and you may want to locate your sketches on the computer itself.
In one Drive, run perfect to Friday, las Windows update... :(... I Install las version to Arduino in local C:, if not work. same error.
When you installed to the local drive C: did you uninstall the previous version fully ?
If not then it may still point to an invalid location.
Adding a little help guide to removal and installation under windows.
CLEAN UP BEFORE INSTALLING ANOTHER COPY OF THE IDE OR ARDUINO CREATE.pdf (345 KB)
I had the same problem with onedrive after the fall creator update. Just un-check "Files On-Demand", arduino IDE can normally read and compile sketch. In my case, it works.
