Windows 10 - USB port does not show up
I 'm trying to install Arduino IDE in Windows 10.
Arduino Mini Pro -FTDI232.
I 've tried lots of version but in all of them the USB port does not show up!
(in win 8 no problem)
From what I read win 10 is very picky in drivers installation.
I even tried with Disabling driver signature enforcement, but did not help.
I read here (page 29):
The certified driver supplied by FTDI will work with VID 0403 ....blahblah and PID 6001.
My FTDI has this combination of VID and PID but still nothing, USB port does not show up.
Any help would be appreciated.
Microsoft has utilities that can give you more information:
Universal Serial Bus Viewer in Windows - Windows drivers | Microsoft Learn
I have a desktop file to invoke:
echo off
IMHERE = cd
CD C:\Program Files (x86)\Windows Kits\10\Debuggers\x64\
start usbview.exe
cd IMHERE
IMHERE=""
exit
I saved as text the findings of the Universal Serial Bus viewer, but I can' t say I understand much (Arduino board+FTDI are not connected):
My Computer
Main controller Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced - 3B34
DriverKey: {36fc9e60-c465-11cf-8056-444553540000}\0001
VendorID: 8086
DeviceID: 3B34
SubSysID: 04341028
Revision: 06
Debug Port Number:  2
Bus.Device.Function (in decimal): 0.29.0
Host Controller Power State Mappings
System State		Host Controller		Root Hub	USB wakeup	Powered
S0 (working)    	D0              	D0
S1 (sleep)      	D? (unspecified)	D3
S2 (sleep)      	D? (unspecified)	D3
S3 (sleep)      	D3              	D2              Yes		Yes
S4 (Hibernate)  	D3              	D2
Last Sleep State	S3 (sleep)
RootHub
Root Hub: USB#ROOT_HUB20#4&3880ffa2&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
Hub Power:                    Self Power
Number of Ports:              3
Power switching:              Ganged
Compound device:              No
Over-current Protection:      Global
High speed capable:           Yes
High speed:                   Yes
Multiple transaction translations capable:                 No
Performs multiple transaction translations simultaneously: No
Hub wakes when device is connected:                        No
Hub is bus powered:           No
Hub is root:                  Yes
[Port1]  :  Generic USB Hub
External Hub: USB#VID_8087&PID_0020#5&364e8229&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
Is Port User Connectable:         no
Is Port Debug Capable:            no
Companion Port Number:            0
Companion Hub Symbolic Link Name:
Protocols Supported:
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Hub type:                     USB 2.0 Hub
Number of Ports:              8
Power switching:              Individual
Compound device:              No
Over-current Protection:      Individual
High speed:                   Yes
Hub is root:                  No
       ---===>Device Information<===---
ConnectionStatus:
Current Config Value:              0x01  -> Device Bus Speed: High (is not SuperSpeed or higher capable)
Device Address:                    0x01
Open Pipes:                           1
          ===>Device Descriptor<===
bLength:                           0x12
bDescriptorType:                   0x01
bcdUSB:                          0x0200
bDeviceClass:                      0x09  -> This is a HUB Device
bDeviceSubClass:                   0x00
bDeviceProtocol:                   0x01
bMaxPacketSize0:                   0x40 = (64) Bytes
idVendor:                        0x8087 = Intel
idProduct:                       0x0020
bcdDevice:                       0x0000
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bNumConfigurations:                0x01
          ---===>Open Pipes<===---
          ===>Endpoint Descriptor<===
bLength:                           0x07
bDescriptorType:                   0x05
bEndpointAddress:                  0x81  -> Direction: IN - EndpointID: 1
bmAttributes:                      0x03  -> Interrupt Transfer Type
wMaxPacketSize:                  0x0002 = 1 transactions per microframe, 0x02 max bytes
bInterval:                         0x0C
       ---===>Full Configuration Descriptor<===---
          ===>Configuration Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x02
wTotalLength:                    0x0019  -> Validated
bNumInterfaces:                    0x01
bConfigurationValue:               0x01
iConfiguration:                    0x00
bmAttributes:                      0xE0  -> Self Powered
  -> Remote Wakeup
MaxPower:                          0x00 =   0 mA
          ===>Interface Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x04
bInterfaceNumber:                  0x00
bAlternateSetting:                 0x00
bNumEndpoints:                     0x01
bInterfaceClass:                   0x09  -> HUB Interface Class
bInterfaceSubClass:                0x00
bInterfaceProtocol:                0x00
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x0C
[Port1]
Is Port User Connectable:         yes
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
ConnectionStatus:      NoDeviceConnected
[Port2]  :  Συσκευή διασύνδεσης USB
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Device Power State:               PowerDeviceD0
English product name: "USB Optical Mouse"
ConnectionStatus:
Current Config Value:              0x01  -> Device Bus Speed: Low
Device Address:                    0x02
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
bDeviceClass:                      0x00  -> This is an Interface Class Defined Device
bDeviceProtocol:                   0x00
bMaxPacketSize0:                   0x08 = (8) Bytes
idVendor:                        0x046D = Logitech Inc.
idProduct:                       0xC077
bcdDevice:                       0x7200
iManufacturer:                     0x01
     English (United States)  "Logitech"
iProduct:                          0x02
     English (United States)  "USB Optical Mouse"
iSerialNumber:                     0x00
bLength:                           0x07
wMaxPacketSize:                  0x0004
bInterval:                         0x0A
bLength:                           0x09
wTotalLength:                    0x0022  -> Validated
bmAttributes:                      0xA0  -> Bus Powered
  -> Remote Wakeup
MaxPower:                          0x32 = 100 mA
bLength:                           0x09
bNumEndpoints:                     0x01
bInterfaceClass:                   0x03  -> HID Interface Class
bInterfaceSubClass:                0x01
bInterfaceProtocol:                0x02
iInterface:                        0x00
          ===>HID Descriptor<===
bLength:                           0x09
bDescriptorType:                   0x21
bcdHID:                          0x0111
bCountryCode:                      0x00
bNumDescriptors:                   0x01
bDescriptorType:                   0x22 (Report Descriptor)
wDescriptorLength:               0x002E
bLength:                           0x07
bInterval:                         0x0A
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port4]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port5]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port6]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port7]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port8]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port2]
Is Port Debug Capable:            yes
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Κεντρικός ελεγκτής Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced - 3B3C
DriverKey: {36fc9e60-c465-11cf-8056-444553540000}\0000
VendorID: 8086
DeviceID: 3B3C
SubSysID: 04341028
Revision: 06
Bus.Device.Function (in decimal): 0.26.0
S0 (working)    	D0              	D0
S3 (sleep)      	D3              	D3
S4 (Hibernate)  	D3              	D3
RootHub
Root Hub: USB#ROOT_HUB20#4&156483d0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
Number of Ports:              3
Compound device:              No
High speed:                   Yes
Hub is root:                  Yes
External Hub: USB#VID_8087&PID_0020#5&251d4aec&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Number of Ports:              6
Compound device:              No
High speed:                   Yes
Hub is root:                  No
ConnectionStatus:
Device Address:                    0x06
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x0020
bcdDevice:                       0x0000
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bLength:                           0x07
wMaxPacketSize:                  0x0001 = 1 transactions per microframe, 0x01 max bytes
bInterval:                         0x0C
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x0C
External Hub: USB#VID_0A5C&PID_4500#6&296688d0&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Number of Ports:              3
Compound device:              Yes
High speed capable:           No
High speed:                   No
Hub is root:                  No
English product name: "BCM2046B1"
ConnectionStatus:
Current Config Value:              0x01  -> Device Bus Speed: Full (is not SuperSpeed or higher capable)
Device Address:                    0x07
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idVendor:                        0x0A5C = Broadcom Corp.
idProduct:                       0x4500
bcdDevice:                       0x0100
iManufacturer:                     0x01
     English (United States)  "Broadcom"
iProduct:                          0x02
     English (United States)  "BCM2046B1"
iSerialNumber:                     0x00
bLength:                           0x07
wMaxPacketSize:                  0x0001 = 0x01 bytes
bInterval:                         0xFF
bLength:                           0x09
  -> Remote Wakeup
MaxPower:                          0x2F =  94 mA
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0xFF
[Port1]  :  Συσκευή διασύνδεσης USB
 USB 1.1:                         yes
 USB 2.0:                         no
 USB 3.0:                         no
ConnectionStatus:
Device Address:                    0x03
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idVendor:                        0x413C = Dell Inc.
idProduct:                       0x8161
bcdDevice:                       0x0100
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bLength:                           0x07
wMaxPacketSize:                  0x0008 = 0x08 bytes
bInterval:                         0x0A
bLength:                           0x09
  -> Remote Wakeup
MaxPower:                          0x01 =   2 mA
bLength:                           0x09
bNumEndpoints:                     0x01
bInterfaceProtocol:                0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
wDescriptorLength:               0x0038
bLength:                           0x07
bInterval:                         0x0A
 USB 1.1:                         yes
 USB 2.0:                         no
 USB 3.0:                         no
ConnectionStatus:
Device Address:                    0x04
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x8162
bcdDevice:                       0x0100
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bLength:                           0x07
wMaxPacketSize:                  0x0004 = 0x04 bytes
bInterval:                         0x0A
bLength:                           0x09
wTotalLength:                    0x003E  -> Validated
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
wDescriptorLength:               0x0071
bLength:                           0x07
bInterval:                         0x0A
  -> This is a HID USB Device Interface Class
          ===>Descriptor Hex Dump<===
bLength:                           0x1C
bDescriptorType:                   0xFF
1C FF 42 49 53 54 00 01 03 08 05 00 00 00 00 00
01 09 F4 01 02 0A F4 01 03 0B F4 01
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         no
 USB 3.0:                         no
[Port2]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port4]  :  Σύνθετη συσκευή USB
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Device Power State:               PowerDeviceD3
String Descriptor for index 1 not available while device is in low power state.
ConnectionStatus:
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
bDeviceClass:                      0xEF  -> This is a Multi-interface Function Code Device
bDeviceSubClass:                   0x02  -> This is the Common Class Sub Class
bDeviceProtocol:                   0x01  -> This is the Interface Association Descriptor protocol
idVendor:                        0x0C45 = Sonix Technology Co., Ltd.
idProduct:                       0x6480
bcdDevice:                       0x9A07
iManufacturer:                     0x02
String Descriptor for index 2 not available while device is in low power state.
iProduct:                          0x01
iSerialNumber:                     0x00
bLength:                           0x07
bEndpointAddress:                  0x83  -> Direction: IN - EndpointID: 3
wMaxPacketSize:                  0x0010 = 1 transactions per microframe, 0x10 max bytes
bInterval:                         0x06
bLength:                           0x09
wTotalLength:                    0x0299  -> Validated
bNumInterfaces:                    0x02
bmAttributes:                      0x80  -> Bus Powered
MaxPower:                          0xFA = 500 mA
*!*ERROR:  0 is a Reserved USB Device Interface Class
bLength:                           0x28
28 FF 42 49 53 54 00 01 06 01 10 00 00 00 00 00
D1 10 F4 01 D2 11 F4 01 D3 12 F4 01 D4 13 F4 01
D5 14 F4 01 D6 15 F4 01
          ===>IAD Descriptor<===
bLength:                           0x08
bDescriptorType:                   0x0B
bFirstInterface:                   0x00
bInterfaceCount:                   0x02
bFunctionClass:                    0x0E  -> Video Interface Class
bFunctionSubClass:                 0x03  -> Video Interface Collection
bFunctionProtocol:                 0x00  -> PC_PROTOCOL_UNDEFINED protocol
iFunction:                         0x04
String Descriptor for index 4 not available while device is in low power state.
bLength:                           0x09
bNumEndpoints:                     0x01
bInterfaceClass:                   0x0E  -> Video Interface Class
bInterfaceSubClass:                0x01  -> Video Control Interface SubClass
iInterface:                        0x04
          ===>Class-Specific Video Control Interface Header Descriptor<===
bLength:                           0x0D
bDescriptorType:                   0x24
bDescriptorSubtype:                0x01
bcdVDC:                          0x0100
wTotalLength:                    0x0067  -> Validated
dwClockFreq:                 0x00E4E1C0 = (15000000) Hz
bInCollection:                     0x01
baInterfaceNr[1]:                  0x01
USB Video Class device: spec version 1.0
          ===>Video Control Output Terminal Descriptor<===
bLength:                           0x09
bDescriptorSubtype:                0x03
bTerminalID:                       0x02
wTerminalType:                   0x0101 = (TT_STREAMING)
bAssocTerminal:                    0x00
bSourceID:                         0x05
iTerminal:                         0x00
          ===>Video Control Extension Unit Descriptor<===
bLength:                           0x1A
bDescriptorSubtype:                0x06
bUnitID:                           0x04
guidExtensionCode:                 {28F03370-6311-4A2E-BA2C-6890EB334016}
bNumControls:                      0x08
bNrInPins:                         0x01
===>List of Connected Units and Terminal ID's
baSourceID[1]:                     0x03
bControlSize:                      0x01
bmControls : 0x1F
     D00 = 1  yes -  Vendor-Specific (Optional)
     D01 = 1  yes -  Vendor-Specific (Optional)
     D02 = 1  yes -  Vendor-Specific (Optional)
     D03 = 1  yes -  Vendor-Specific (Optional)
     D04 = 1  yes -  Vendor-Specific (Optional)
     D05 = 0   no -  Vendor-Specific (Optional)
     D06 = 0   no -  Vendor-Specific (Optional)
     D07 = 0   no -  Vendor-Specific (Optional)
iExtension:                        0x00
bLength:                           0x1A
bUnitID:                           0x05
guidExtensionCode:                 {0FB885C3-68C2-4547-90F7-8F47579D95FC}
bNumControls:                      0x04
bNrInPins:                         0x01
baSourceID[1]:                     0x04
bControlSize:                      0x01
bmControls : 0x0F
     D04 = 0   no -  Vendor-Specific (Optional)
iExtension:                        0x00
          ===>Video Control Input Terminal Descriptor<===
bLength:                           0x12
bDescriptorSubtype:                0x02
bTerminalID:                       0x01
wTerminalType:                   0x0201 = (ITT_CAMERA)
iTerminal:                         0x00
===>Camera Input Terminal Data
wObjectiveFocalLengthMin:        0x0000
wObjectiveFocalLengthMax:        0x0000
wOcularFocalLength:              0x0000
bControlSize:                      0x03
bmControls : 0x00 0x00 0x00
     D00 = 0   no -  Scanning Mode
     D01 = 0   no -  Auto-Exposure Mode
     D02 = 0   no -  Auto-Exposure Priority
     D03 = 0   no -  Exposure Time (Absolute)
     D04 = 0   no -  Exposure Time (Relative)
     D05 = 0   no -  Focus (Absolute)
     D06 = 0   no -  Focus (Relative)
     D07 = 0   no -  Iris (Absolute)
     D08 = 0   no -  Iris (Relative)
     D09 = 0   no -  Zoom (Absolute)
     D10 = 0   no -  Zoom (Relative)
     D11 = 0   no -  PanTilt (Absolute)
     D12 = 0   no -  PanTilt (Relative)
     D13 = 0   no -  Roll (Absolute)
     D14 = 0   no -  Roll (Relative)
     D15 = 0   no -  Reserved
     D16 = 0   no -  Reserved
     D17 = 0   no -  Focus, Auto
     D18 = 0   no -  Privacy
     D19 = 0   no -  Focus, Simple
     D20 = 0   no -  Window
     D21 = 0   no -  Region of Interest
     D22 = 0   no -  Reserved
     D23 = 0   no -  Reserved
          ===>Video Control Processing Unit Descriptor<===
bLength:                           0x0B
bDescriptorSubtype:                0x05
bUnitID:                           0x03
bSourceID:                         0x01
wMaxMultiplier:                  0x0000
bControlSize:                      0x02
bmControls : 0x7F 0x17
     D00 = 1  yes -  Brightness
     D01 = 1  yes -  Contrast
     D02 = 1  yes -  Hue
     D03 = 1  yes -  Saturation
     D04 = 1  yes -  Sharpness
     D05 = 1  yes -  Gamma
     D06 = 1  yes -  White Balance Temperature
     D07 = 0   no -  White Balance Component
     D08 = 1  yes -  Backlight Compensation
     D09 = 1  yes -  Gain
     D10 = 1  yes -  Power Line Frequency
     D11 = 0   no -  Hue, Auto
     D12 = 1  yes -  White Balance Temperature, Auto
     D13 = 0   no -  White Balance Component, Auto
     D14 = 0   no -  Digital Multiplier
     D15 = 0   no -  Digital Multiplier Limit
iProcessing :                      0x00
bLength:                           0x07
bInterval:                         0x06
          ===>Class-specific VC Interrupt Endpoint Descriptor<===
bLength:                           0x05
bDescriptorType:                   0x25
wMaxTransferSize:                0x0010 = (16) Bytes
bLength:                           0x09
bInterfaceNumber:                  0x01
bNumEndpoints:                     0x00
bInterfaceSubClass:                0x02  -> Video Streaming Interface SubClass
iInterface:                        0x00
          ===>Video Class-Specific VS Video Input Header Descriptor<===
bLength:                           0x0E
bNumFormats:                       0x01
wTotalLength:                    0x017B  -> Validated
bmInfo:                            0x00  -> Dynamic Format Change not Supported
bTerminalLink:                     0x02
bStillCaptureMethod:               0x02  -> Still Capture Method 2
bTriggerSupport:                   0x00  -> No Hardware Triggering Support
bTriggerUsage:                     0x00
bControlSize:                      0x01
Video Payload Format 1             0x00
     D00 = 0   no -  Key Frame Rate
     D01 = 0   no -  P Frame Rate
     D02 = 0   no -  Compression Quality
     D03 = 0   no -  Compression Window Size
     D04 = 0   no -  Generate Key Frame
     D05 = 0   no -  Update Frame Segment
     D06 = 0   no -  Reserved
     D07 = 0   no -  Reserved
          ===>Video Streaming Uncompressed Format Type Descriptor<===
bLength:                           0x1B
bDescriptorSubtype:                0x04
bFormatIndex:                      0x01
bNumFrameDescriptors:              0x07
guidFormat:                        {32595559-0000-0010-8000-00AA00389B71} = YUY2 Format
bBitsPerPixel:                     0x10
bDefaultFrameIndex:                0x01
bAspectRatioX:                     0x00
bAspectRatioY:                     0x00
bmInterlaceFlags:                  0x00
     D0    = 0x00 Interlaced stream or variable: No
     D1    = 0x00 Fields per frame: 2 fields
     D2    = 0x00 Field 1 first: No
     D3    = 0x00 Reserved
     D4..5 = 0x00 Field patterns  -> Field 1 only
     D6..7 = 0x00 Display Mode  -> Bob only
bCopyProtect:                      0x00  -> Duplication Unrestricted
          ===>Video Streaming Uncompressed Frame Type Descriptor<===
          --->This is the Default (optimum) Frame index
bLength:                           0x2E
bFrameIndex:                       0x01
bmCapabilities:                    0x00
wWidth:                          0x0280 = 640
wHeight:                         0x01E0 = 480
dwMinBitRate:                0x01770000
dwMaxBitRate:                0x08CA0000
dwMaxVideoFrameBufferSize:   0x00096000
dwDefaultFrameInterval:      0x00051615 = 33.333300 mSec (30.00 Hz)
bFrameIntervalType:                0x05
===>Additional Discrete Frame Type Data
dwFrameInterval[1]:          0x00051615 = 33.333300 mSec (30.00 Hz)
dwFrameInterval[2]:          0x0007A120 = 50.000000 mSec (20.00 Hz)
dwFrameInterval[3]:          0x000A2C2A = 66.666600 mSec (15.00 Hz)
dwFrameInterval[4]:          0x000F4240 = 100.000000 mSec (10.00 Hz)
dwFrameInterval[5]:          0x001E8480 = 200.000000 mSec (5.00 Hz)
bLength:                           0x2E
bFrameIndex:                       0x02
wWidth:                          0x0160 = 352
wHeight:                         0x0120 = 288
dwMinBitRate:                0x007BC000
dwMaxBitRate:                0x02E68000
dwMaxVideoFrameBufferSize:   0x00031800
bLength:                           0x2E
bFrameIndex:                       0x03
wWidth:                          0x0140 = 320
wHeight:                         0x00F0 = 240
dwMinBitRate:                0x005DC000
dwMaxBitRate:                0x02328000
dwMaxVideoFrameBufferSize:   0x00025800
bLength:                           0x2E
bFrameIndex:                       0x04
wWidth:                          0x00B0 = 176
wHeight:                         0x0090 = 144
dwMinBitRate:                0x001EF000
dwMaxBitRate:                0x00B9A000
dwMaxVideoFrameBufferSize:   0x0000C600
bLength:                           0x2E
bFrameIndex:                       0x05
wWidth:                          0x00A0 = 160
wHeight:                         0x0078 = 120
dwMinBitRate:                0x00177000
dwMaxBitRate:                0x008CA000
dwMaxVideoFrameBufferSize:   0x00009600
bLength:                           0x22
bFrameIndex:                       0x06
wWidth:                          0x0400 = 1024
wHeight:                         0x0300 = 768
dwMinBitRate:                0x03C00000
dwMaxBitRate:                0x06C00000
dwMaxVideoFrameBufferSize:   0x00180000
dwDefaultFrameInterval:      0x0010F447 = 111.111100 mSec (9.00 Hz)
bFrameIntervalType:                0x02
dwFrameInterval[1]:          0x0010F447 = 111.111100 mSec (9.00 Hz)
dwFrameInterval[2]:          0x001E8480 = 200.000000 mSec (5.00 Hz)
bLength:                           0x22
bFrameIndex:                       0x07
wWidth:                          0x0500 = 1280
wHeight:                         0x0400 = 1024
dwMinBitRate:                0x06400000
dwMaxBitRate:                0x0B400000
dwMaxVideoFrameBufferSize:   0x00280000
          ===>Still Image Frame Type Descriptor<===
bLength:                           0x22
bEndpointAddress:                  0x00
bNumImageSizePatterns:             0x07
wWidth[1]:                       0x0500
wHeight[1]:                      0x0400
wWidth[2]:                       0x0400
wHeight[2]:                      0x0300
wWidth[3]:                       0x0280
wHeight[3]:                      0x01E0
wWidth[4]:                       0x0160
wHeight[4]:                      0x0120
wWidth[5]:                       0x0140
wHeight[5]:                      0x00F0
wWidth[6]:                       0x00B0
wHeight[6]:                      0x0090
wWidth[7]:                       0x00A0
wHeight[7]:                      0x0078
bNumCompressionPattern:            0x00
          ===>Color Matching Descriptor<===
bLength:                           0x06
bDescriptorSubtype:                0x0D
bColorPrimaries:                   0x01
bTransferCharacteristics:          0x01
bMatrixCoefficients:               0x04
bLength:                           0x09
bAlternateSetting:                 0x01
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bmAttributes:                      0x05  -> Isochronous Transfer Type, Synchronization Type = Asynchronous, Usage Type = Data Endpoint
wMaxPacketSize:                  0x0080 = 1 transactions per microframe, 0x80 max bytes
bInterval:                         0x01
bLength:                           0x09
bAlternateSetting:                 0x02
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
wMaxPacketSize:                  0x0100 = 1 transactions per microframe, 0x100 max bytes
bInterval:                         0x01
bLength:                           0x09
bAlternateSetting:                 0x03
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
wMaxPacketSize:                  0x0320 = 1 transactions per microframe, 0x320 max bytes
bInterval:                         0x01
bLength:                           0x09
bAlternateSetting:                 0x04
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
wMaxPacketSize:                  0x0B20 = 2 transactions per microframe, 0x320 max bytes
bInterval:                         0x01
bLength:                           0x09
bAlternateSetting:                 0x05
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
wMaxPacketSize:                  0x1320 = 3 transactions per microframe, 0x320 max bytes
bInterval:                         0x01
bLength:                           0x09
bAlternateSetting:                 0x06
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
wMaxPacketSize:                  0x1400 = 3 transactions per microframe, 0x400 max bytes
bInterval:                         0x01
          ===>Additional Error Checking<===
PASS: number of uncompressed-frame frame descriptors (7) == number of frame descriptors (7) specified in uncompressed format descriptor(s)
[Port5]  :  Συσκευή αποθήκευσης USB
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
English product name: "USB2.0-CRW"
ConnectionStatus:
Open Pipes:                           2
bLength:                           0x12
bcdUSB:                          0x0200
idVendor:                        0x0BDA = Realtek Semiconductor Corp.
idProduct:                       0x0158
bcdDevice:                       0x5888
iManufacturer:                     0x01
     English (United States)  "Generic"
iProduct:                          0x02
     English (United States)  "USB2.0-CRW"
iSerialNumber:                     0x03
     English (United States)  "20071114173400000"
bLength:                           0x07
bEndpointAddress:                  0x01  -> Direction: OUT - EndpointID: 1
bmAttributes:                      0x02  -> Bulk Transfer Type
wMaxPacketSize:                  0x0200 = 0x200 max bytes
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x82  -> Direction: IN - EndpointID: 2
bInterval:                         0x00
bLength:                           0x09
wTotalLength:                    0x0020  -> Validated
iConfiguration:                    0x04
     English (United States)  "CARD READER"
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x02
bInterfaceClass:                   0x08  -> This is a Mass Storage USB Device Interface Class
bInterfaceSubClass:                0x06
bInterfaceProtocol:                0x50
iInterface:                        0x05
     English (United States)  "Bulk-In, Bulk-Out, Interface"
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
[Port6]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port2]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Ah... you really should connect the USB FTDI
All right, with the FTDI + Arduino Pro Mini connected:
My Computer
Main Controller Intel(R) 5 Series/3400 Series Chipset Family USB Enhanced - 3B34
VendorID: 8086
DeviceID: 3B34
SubSysID: 04341028
Revision: 06
S0 (working)    	D0              	D0
Last Sleep State	S? (unmapped)
RootHub
Number of Ports:              3
Compound device:              No
High speed:                   Yes
Hub is root:                  Yes
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Number of Ports:              8
Compound device:              No
High speed:                   Yes
Hub is root:                  No
ConnectionStatus:
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x0020
bcdDevice:                       0x0000
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bLength:                           0x07
bInterval:                         0x0C
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x0C
[Port1]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
ConnectionStatus:
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0xC077
bcdDevice:                       0x7200
iManufacturer:                     0x01
iProduct:                          0x02
iSerialNumber:                     0x00
bLength:                           0x07
bInterval:                         0x0A
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
bLength:                           0x07
bInterval:                         0x0A
[Port3]  :  USB Serial Converter
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
English product name: "FT232R USB UART"
ConnectionStatus:
Open Pipes:                           2
bLength:                           0x12
bcdUSB:                          0x0200
idVendor:                        0x0403 = Future Technology Devices International Limited
idProduct:                       0x6001
bcdDevice:                       0x0600
iManufacturer:                     0x01
     English (United States)  "FTDI"
iProduct:                          0x02
     English (United States)  "FT232R USB UART"
iSerialNumber:                     0x03
     English (United States)  "00000000"
bLength:                           0x07
wMaxPacketSize:                  0x0040 = 0x40 bytes
bInterval:                         0x00
bLength:                           0x07
bEndpointAddress:                  0x02  -> Direction: OUT - EndpointID: 2
bInterval:                         0x00
bLength:                           0x09
  -> Remote Wakeup
MaxPower:                          0x2D =  90 mA
bLength:                           0x09
bNumEndpoints:                     0x02
bInterfaceClass:                   0xFF  -> Interface Class Unknown to USBView
bInterfaceSubClass:                0xFF
bInterfaceProtocol:                0xFF
iInterface:                        0x02
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
[Port4]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port5]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port6]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port7]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port8]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port2]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
VendorID: 8086
DeviceID: 3B3C
SubSysID: 04341028
Revision: 06
S0 (working)    	D0              	D0
S3 (sleep)      	D3              	D3
RootHub
Number of Ports:              3
Compound device:              No
High speed:                   Yes
Hub is root:                  Yes
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Number of Ports:              6
Compound device:              No
High speed:                   Yes
Hub is root:                  No
ConnectionStatus:
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x0020
bcdDevice:                       0x0000
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bLength:                           0x07
bInterval:                         0x0C
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x0C
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
Number of Ports:              3
High speed:                   No
Hub is root:                  No
ConnectionStatus:
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x4500
bcdDevice:                       0x0100
iManufacturer:                     0x01
iProduct:                          0x02
iSerialNumber:                     0x00
bLength:                           0x07
bInterval:                         0xFF
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0xFF
 USB 1.1:                         yes
 USB 2.0:                         no
 USB 3.0:                         no
ConnectionStatus:
Device Address:                    0x05
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x8161
bcdDevice:                       0x0100
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bLength:                           0x07
bInterval:                         0x0A
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
bLength:                           0x07
bInterval:                         0x0A
 USB 1.1:                         yes
 USB 2.0:                         no
 USB 3.0:                         no
ConnectionStatus:
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x8162
bcdDevice:                       0x0100
iManufacturer:                     0x00
iProduct:                          0x00
iSerialNumber:                     0x00
bLength:                           0x07
bInterval:                         0x0A
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x09
bcdHID:                          0x0111
bCountryCode:                      0x00
bLength:                           0x07
bInterval:                         0x0A
bLength:                           0x1C
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         no
 USB 3.0:                         no
[Port2]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
ConnectionStatus:
Open Pipes:                           1
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x6480
bcdDevice:                       0x9A07
iManufacturer:                     0x02
iProduct:                          0x01
iSerialNumber:                     0x00
bLength:                           0x07
bInterval:                         0x06
bLength:                           0x09
bLength:                           0x28
bLength:                           0x08
iFunction:                         0x04
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x04
bLength:                           0x0D
bcdVDC:                          0x0100
bInCollection:                     0x01
bLength:                           0x09
bTerminalID:                       0x02
bSourceID:                         0x05
iTerminal:                         0x00
bLength:                           0x1A
bUnitID:                           0x04
bNumControls:                      0x08
bNrInPins:                         0x01
baSourceID[1]:                     0x03
bControlSize:                      0x01
bmControls : 0x1F
iExtension:                        0x00
bLength:                           0x1A
bUnitID:                           0x05
bNumControls:                      0x04
bNrInPins:                         0x01
baSourceID[1]:                     0x04
bControlSize:                      0x01
bmControls : 0x0F
iExtension:                        0x00
bLength:                           0x12
bTerminalID:                       0x01
iTerminal:                         0x00
bControlSize:                      0x03
     D20 = 0   no -  Window
bLength:                           0x0B
bUnitID:                           0x03
bSourceID:                         0x01
bControlSize:                      0x02
     D02 = 1  yes -  Hue
     D05 = 1  yes -  Gamma
     D09 = 1  yes -  Gain
iProcessing :                      0x00
bLength:                           0x07
bInterval:                         0x06
bLength:                           0x05
bLength:                           0x09
bNumEndpoints:                     0x00
iInterface:                        0x00
bLength:                           0x0E
bNumFormats:                       0x01
bTerminalLink:                     0x02
bTriggerUsage:                     0x00
bControlSize:                      0x01
bLength:                           0x1B
bFormatIndex:                      0x01
bBitsPerPixel:                     0x10
bAspectRatioX:                     0x00
bAspectRatioY:                     0x00
     D3    = 0x00 Reserved
bLength:                           0x2E
bFrameIndex:                       0x01
bLength:                           0x2E
bFrameIndex:                       0x02
bLength:                           0x2E
bFrameIndex:                       0x03
bLength:                           0x2E
bFrameIndex:                       0x04
bLength:                           0x2E
bFrameIndex:                       0x05
bLength:                           0x22
bFrameIndex:                       0x06
bLength:                           0x22
bFrameIndex:                       0x07
bLength:                           0x22
wWidth[1]:                       0x0500
wHeight[1]:                      0x0400
wWidth[2]:                       0x0400
wHeight[2]:                      0x0300
wWidth[3]:                       0x0280
wHeight[3]:                      0x01E0
wWidth[4]:                       0x0160
wHeight[4]:                      0x0120
wWidth[5]:                       0x0140
wHeight[5]:                      0x00F0
wWidth[6]:                       0x00B0
wHeight[6]:                      0x0090
wWidth[7]:                       0x00A0
wHeight[7]:                      0x0078
bLength:                           0x06
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x01
bLength:                           0x09
bNumEndpoints:                     0x01
iInterface:                        0x00
bLength:                           0x07
bInterval:                         0x01
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
ConnectionStatus:
Open Pipes:                           2
bLength:                           0x12
bcdUSB:                          0x0200
idProduct:                       0x0158
bcdDevice:                       0x5888
iManufacturer:                     0x01
iProduct:                          0x02
iSerialNumber:                     0x03
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x09
  -> Remote Wakeup
bLength:                           0x09
bNumEndpoints:                     0x02
iInterface:                        0x05
bLength:                           0x07
bInterval:                         0x00
bLength:                           0x07
bInterval:                         0x00
[Port6]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port2]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
[Port3]
 USB 1.1:                         yes
 USB 2.0:                         yes
 USB 3.0:                         no
The utility should appear similar to my cheap USB-serial module:
Using the utility shortcut:
REM http://archive.fabacademy.org/archives/2017/fablabverket/students/100/web/assignments/week16/pyserial_tutorial.html
ECHO OFF
cls
python -m serial.tools.list_ports
pause
exit
So, bad cable, bad port, bad module... no USB device enumeration.
No module named 'serial':
εικόνα
Everything works fine in this laptop in my other disk drive's installation of Win 8.
Problem is with Win 10.
So, cable port and module are fine.
Unlikely a Windows 10 OS issue, per se. A failed update, forced-driver install, etc... maybe.
Try using a USB mouse or USB storage stick in the same USB port you are having issues and ensure that that specific port is enumerating standard devices. Use the Windows utility to inspect enumeration.
If everything works on Win 10 except FTDI, it "may" be the FTDI hardware is not genuine. It has been a long time since I have heard of counterfeit adapter chips, but a possibility.
FTDI usb-serial counterfeit at DuckDuckGo
It 's such a pain.
I 'll just go back to my Win 8 installation where everything works as expected.
Thank you very much for your time and your effort!
Agreed.
Sadly, it is somewhat to be expected with the numerous security attacks on Windows as an OS. While Linux and MacOS are less prone to attacks, they are still being actively attacked by bad actors.
IMO:
The evolution of Windows XP through various stages to the current Windows 11 has had some shaky times, but I have numerous PC (desktops and tablets) running on Win 11 and have not seen a road-block to using Win-11OS64-bit for software development. I will concede the feature updates twice a year are a major annoyance and for many users, Microsoft will impede migration from 22H1 to 22H2. But security updates seem to be incorporated without too much pain.
Hint: if you think your Windows 10/11 installation is causing your USB plug & play issues, you may wish to consider booting to a Linux distribution on DVD or USB-flash and determining how Linux deals with the commodity hardware you are trying to attach. This is a rather painless way of doing a rather thorough determination of hardware vs OS.
linux bootable evaluation images at DuckDuckGo
