Windows 11 Error: write EOF: undefined
I've been trying to solve this error for a week but to no avail, can anyone help me?
OS : Windows 11
Several versions of the IDE that I tried : 2.2.2 (Nightly), 2.2.1, 2.2.0, 2.0.0
USB Driver : Silicon Labs CP210x USB to UART Bridge for (DOIT ESP32 DEVKIT V1 )
The code cannot be verified at all and an error appears as below.
I tried it with a simple code, but the error results are always the same
And here is the log
without seeing the code it's hard to know for sure, but EOF is a condition returned during a read. it sounds like you have code that is attempting to write the value defined as EOF which there is no need to do. simply close the file
Oh sorry, I forgot to include a code image. I tried it with a simple code, but the error results are always the same
not sure what you intend to show.
please don' t post images. instead, click the <code> icon and copy&paste both the error which identifies the line that the error is on along with the entire code.
oh sorry, here's the log
Started logging.
19:42:23.474838 Language server launched with arguments:
19:42:23.474838   arg[0] = c:\Users\masan\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\arduino-language-server.exe
19:42:23.474838   arg[1] = -clangd
19:42:23.474838   arg[2] = c:\Users\masan\AppData\Local\Programs\arduino-ide\resources\app\lib\backend\resources\clangd.exe
19:42:23.474838   arg[3] = -cli-daemon-addr
19:42:23.474838   arg[4] = localhost:49847
19:42:23.474838   arg[5] = -cli-daemon-instance
19:42:23.474838   arg[6] = 1
19:42:23.474838   arg[7] = -fqbn
19:42:23.474838   arg[8] = esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none
19:42:23.474838   arg[9] = -skip-libraries-discovery-on-rebuild
19:42:23.474838   arg[10] = -board-name
19:42:23.474838   arg[11] = "DOIT ESP32 DEVKIT V1"
19:42:23.474838   arg[12] = -no-real-time-diagnostics
19:42:23.474838   arg[13] = -log
19:42:23.474838   arg[14] = -logpath
19:42:23.474838   arg[15] = c:\GitHub\Arduino\Sketch\blank
19:42:23.474838 logging to c:\GitHub\Arduino\Sketch\blank\inols.log
19:42:23.475903 e[97mLS: : Initial board configuration: esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=nonee[0m
19:42:23.475903 e[97mLS: : arduino-language-server.exe Version: 0.7.4 Commit: d620b0b Date: 2023-01-11T15:42:52Ze[0m
19:42:23.475903 e[97mLS: : Language server build path: C:\Users\masan\AppData\Local\Temp\arduino-language-server550241502e[0m
19:42:23.475903 e[97mLS: : Language server build sketch root: C:\Users\masan\AppData\Local\Temp\arduino-language-server550241502\sketche[0m
19:42:23.475903 e[97mLS: : Language server FULL build path: C:\Users\masan\AppData\Local\Temp\arduino-language-server2724421017e[0m
19:42:23.475903 IN Elapsed: 0s
19:42:23.476425 e[92mIDE --> LS REQU initialize 0e[0m
19:42:23.476947 e[92m                initialize 0: e[93mwrite-lockede[0me[0m
19:42:23.476947 e[92m                initialize 0: e[93mwrite-unlockede[0me[0m
19:42:23.476947 e[96mINIT --- : initializing workbench: file:///c%3A/GitHub/Arduino/Sketch/blanke[0m
19:42:23.476947 e[96mINIT --- : e[93mread-lockede[0me[0m
19:42:23.476947 e[96mINIT --- : e[93mread-unlockede[0me[0m
19:42:23.476947 e[92m                initialize 0: initialization parameters: {"capabilities":{"textDocumentSync":{"openClose":true,"change":2,"save":{"includeText":true}},"completionProvider":{"triggerCharacters":[".","\u003c","\u003e",":","\"","/"],"allCommitCharacters":[" ","\t","(",")","[","]","{","}","\u003c","\u003e",":",";",",","+","-","/","*","%","^","\u0026","#","?",".","=","\"","'","|"],"completionItem":{}},"hoverProvider":{},"signatureHelpProvider":{"triggerCharacters":["(",","]},"definitionProvider":{},"documentHighlightProvider":{},"documentSymbolProvider":{},"codeActionProvider":{"codeActionKinds":["quickfix","refactor","info"]},"documentFormattingProvider":{},"documentRangeFormattingProvider":{},"documentOnTypeFormattingProvider":{"firstTriggerCharacter":"\n"},"renameProvider":{},"executeCommandProvider":{"commands":["clangd.applyFix","clangd.applyTweak"]},"workspaceSymbolProvider":{}},"serverInfo":{"name":"arduino-language-server","version":"0.7.4"}}e[0m
19:42:23.477487 e[32mIDE <-- LS RESP initialize 0e[0m
19:42:23.477487 OUT Elapsed: 0s
19:42:23.478027 IN Elapsed: 540µs
19:42:23.478027 e[92mIDE --> LS NOTIF initializede[0m
19:42:23.478027 e[92m                 initialized: Notification is not propagated to clangde[0m
19:42:23.478027 IN Elapsed: 0s
19:42:23.478027 e[92mIDE --> LS NOTIF textDocument/didOpene[0m
19:42:23.478569 e[92m                 textDocument/didOpen: e[93mwrite-lockede[0me[0m
19:42:23.478569 e[92m                 textDocument/didOpen: (throttled: waiting for clangd)e[0m
19:42:23.478569 e[92m                 textDocument/didOpen: e[93munlocked (waiting clangd)e[0me[0m
19:42:23.790782 e[96mINIT --- : Running build with: {
  "instance": {
    "id": 1
  "fqbn": "esp32:esp32:esp32doit-devkit-v1:UploadSpeed=921600,FlashFreq=80,DebugLevel=none,EraseFlash=none",
  "sketch_path": "C:\\GitHub\\Arduino\\Sketch\\blank",
  "build_path": "C:\\Users\\masan\\AppData\\Local\\Temp\\arduino-language-server2724421017",
  "verbose": true,
  "create_compilation_database_only": true
}e[0m
19:42:23.997771 e[96mINIT --- : build stdout:e[0m
19:42:23.997771 e[96mINIT --- : FQBN: esp32:esp32:esp32doit-devkit-v1
Using board 'esp32doit-devkit-v1' from platform in folder: C:\Users\masan\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11
Using core 'esp32' from platform in folder: C:\Users\masan\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11
cmd /c if exist "C:\\GitHub\\Arduino\\Sketch\\blank\\partitions.csv" COPY /y "C:\\GitHub\\Arduino\\Sketch\\blank\\partitions.csv" "C:\\Users\\masan\\AppData\\Local\\Temp\\arduino-language-server2724421017\\partitions.csv"
e[0m
19:42:23.997771 e[96mINIT --- : build stderr:e[0m
e[0m
19:42:23.997771 e[96mINIT --- : error starting clang: error running compile: rpc error: code = Internal desc = exit status 1e[0m
19:42:23.997771 e[92m                 textDocument/didOpen: e[93mlocked (waiting clangd)e[0me[0m
19:42:23.997771 e[92m                 textDocument/didOpen: clangd startup failed: quitting Language servere[0m
here he is
cmd /c if exist "C:\\GitHub\\Arduino\\Sketch\\blank\\partitions.csv" COPY /y "C:\\GitHub\\Arduino\\Sketch\\blank\\partitions.csv" "C:\\Users\\masan\\AppData\\Local\\Temp\\arduino\\sketches\\D9208B8E3DE256665AD74867ED6EA5AD\\partitions.csv"
exit status 1
Compilation error: exit status 1
int LED_BUILTIN = 2;
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);
  digitalWrite(LED_BUILTIN, LOW);
doubt i can help. This doesn't look like a simple compilation error for a program as that shown in post #9
looks like you're trying to compile a simple program for the esp32. i've used the Arduino IDE to compile programs for the esp32.
i'm not familiar with the Arduino language server
Try removing this line, I get an error that LED_BUILTIN is already defined. Not sure if that is connected to the error you are seeing, but I'm not compiling on Windows 11.
  pinMode(2, OUTPUT);
  digitalWrite(2, HIGH);
  digitalWrite(2, LOW);
how about this, the error looks the same
exit status 1
Try compiling that simplest possible sketch for a different target microprocessor board, like the UNO.
If you have no UNO, obvsly use verify, not upload.
If IDE 1.8.X can handle what you are hoping to accomplish, install and try that to compile a simple sketch for your intended target.
Your code isn't entering into the problem you are having.
a7
Even with empty code like this, when Verify it always shows an error with the same log...
Have you tried another version of the IDE? This may be a bug specific to the nightly build you are using.
I have tried all versions of IDE 2.0 and above
Will IDE 1.8.X handle your target board?
a7
i get the following compiling code from post #13
Using board 'esp32' from platform in folder: C:\Users\lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\lenovo\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\\stuff\\SW\\Arduino\\_Others\\Tst\\partitions.csv" copy /y "C:\\stuff\\SW\\Arduino\\_Others\\Tst\\partitions.csv" "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\partitions.csv"
cmd /c if not exist "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\partitions.csv" copy "C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\tools\\partitions\\default.csv" "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\partitions.csv"
Detecting libraries used...
"C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\sketch\\Tst.ino.cpp" -o nul
Generating function prototypes...
"C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\sketch\\Tst.ino.cpp" -o "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE=\"mbedtls/esp_config.h\"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/config" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_trace" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/app_update" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/asio" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bootloader_support" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/bt" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/coap" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/console" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/driver" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/efuse" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-tls" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_event" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_client" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_http_server" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_https_server" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/espcoredump" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ethernet" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/expat" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fatfs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freemodbus" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/freertos" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/heap" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/idf_test" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/jsmn" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/json" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/libsodium" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/log" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/lwip" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mbedtls" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mdns" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/micro-ecc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/mqtt" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/newlib" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nghttp" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/nvs_flash" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/openssl" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protobuf-c" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/protocomm" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/pthread" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/sdmmc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/soc" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spi_flash" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/spiffs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcp_transport" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/ulp" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/unity" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/vfs" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wear_levelling" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp32-camera" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/esp-face" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -Wall -Werror=all -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32_DEV\"" "-DARDUINO_VARIANT=\"esp32\"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\cores\\esp32" "-IC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6\\variants\\esp32" "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\sketch\\Tst.ino.cpp" -o "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\sketch\\Tst.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\lenovo\AppData\Local\Temp\arduino\cores\325653f989b3558edcef2648d7ff3d26\core.a
Linking everything together...
"C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-gcc" -nostdlib "-LC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/lib" "-LC:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/sdk/ld" -T esp32_out.ld -T esp32.project.ld -T esp32.rom.ld -T esp32.peripherals.ld -T esp32.rom.libgcc.ld -T esp32.rom.spiram_incompatible_fns.ld -u esp_app_desc -u ld_include_panic_highint_hdl -u call_user_start_cpu0 -Wl,--gc-sections -Wl,-static -Wl,--undefined=uxTopUsedPriority -u __cxa_guard_dummy -u __cxx_fatal_exception -Wl,--start-group "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E\\sketch\\Tst.ino.cpp.o" "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\cores\\325653f989b3558edcef2648d7ff3d26\\core.a" -lgcc -lesp_websocket_client -lwpa2 -ldetection -lesp_https_server -lwps -lhal -lconsole -lpe -lsoc -lsdmmc -lpthread -llog -lesp_http_client -ljson -lmesh -lesp32-camera -lnet80211 -lwpa_supplicant -lc -lmqtt -lcxx -lesp_https_ota -lulp -lefuse -lpp -lmdns -lbt -lwpa -lspiffs -lheap -limage_util -lunity -lrtc -lmbedtls -lface_recognition -lnghttp -ljsmn -lopenssl -lcore -lfatfs -lm -lprotocomm -lsmartconfig -lxtensa-debug-module -ldl -lesp_event -lesp-tls -lfd -lespcoredump -lesp_http_server -lfr -lsmartconfig_ack -lwear_levelling -ltcp_transport -llwip -lphy -lvfs -lcoap -lesp32 -llibsodium -lbootloader_support -ldriver -lcoexist -lasio -lod -lmicro-ecc -lesp_ringbuf -ldetection_cat_face -lapp_update -lespnow -lface_detection -lapp_trace -lnewlib -lbtdm_app -lwifi_provisioning -lfreertos -lfreemodbus -lethernet -lnvs_flash -lspi_flash -lc_nano -lexpat -lfb_gfx -lprotobuf-c -lesp_adc_cal -ltcpip_adapter -lstdc++ -Wl,--end-group -Wl,-EL -o "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E/Tst.ino.elf"
"C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\3.0.0/esptool.exe" --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E/Tst.ino.bin" "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E/Tst.ino.elf"
esptool.py v3.0-dev
"C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\1.0.6/tools/gen_esp32part.exe" -q "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E/partitions.csv" "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E/Tst.ino.partitions.bin"
"C:\\Users\\lenovo\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\xtensa-esp32-elf-gcc\\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-size" -A "C:\\Users\\lenovo\\AppData\\Local\\Temp\\arduino\\sketches\\16EA15000D7111310762E699783D361E/Tst.ino.elf"
Sketch uses 198834 bytes (15%) of program storage space. Maximum is 1310720 bytes.
Global variables use 13248 bytes (4%) of dynamic memory, leaving 314432 bytes for local variables. Maximum is 327680 bytes.
do the files in that error msg exist on you PC?
There is no such log message
Hi @kangangga. I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Select File > Quit from the Arduino IDE menus if it is running.
  2. Start Windows "File Explorer".
  3. Open the Arduino IDE installation folder.
    The default installation location is at one of the following paths:
    • C:\Program Files\Arduino IDE
    • C:\Users\<username>\AppData\Local\Programs\Arduino IDE
      (where <username> is your Windows username)
      :exclamation: If looking for it with your file manager or command line, note that the AppData folder is hidden by default. On Windows "File Explorer", you can make it visible by opening the "View" menu, then checking the box next to "☐ Hidden items".
  4. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  5. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  6. Type the following command:
    & ".\Arduino IDE"
  7. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  8. Wait for Arduino IDE to finish starting.
  9. Select File > New Sketch from the Arduino IDE menus.
  10. Select the "DOIT ESP32 DEVKIT V1" board from the Arduino IDE menus.
  11. Select Sketch > Verify/Compile from the Arduino IDE menus.
  12. Wait for the compile operation to fail spuriously as before.
  13. Attempt
  14. Switch back to the PowerShell window.
  15. Press Ctrl+Shift+A.
    This will select all the text in the PowerShell window.
  16. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  17. Open a forum reply here by clicking the "Reply" button.
  18. Click the <CODE/> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code tags icon on toolbar
  19. Press Ctrl+V.
    This will paste the output into the code block.
  20. Move the cursor outside of the code block markup before you add any additional text to your reply.
  21. Click the "Reply" button to post the output.
Please let me know if you have any questions or problems while following those instructions.
Page 1
PS C:\Program Files\Arduino IDE> & ".\Arduino IDE"
Starting backend process. PID: 12772
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/masan/.theia'
root INFO Backend Object.initialize: 5.7 ms [Finished 0.998 s after backend start]
root INFO Backend Object.configure: 4.5 ms [Finished 0.998 s after backend start]
root INFO Backend MessagingContribution.onStart: 1.9 ms [Finished 0.998 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.3 ms [Finished 1.041 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.3 ms [Finished 1.041 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.2 ms [Finished 1.041 s after backend start]
root INFO Backend LocalizationBackendContribution.initialize: 42.9 ms [Finished 1.041 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.2 ms [Finished 1.041 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 1.8 ms [Finished 1.043 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.5 ms [Finished 1.043 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 0.9 ms [Finished 1.044 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.4 ms [Finished 1.045 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 1.1 ms [Finished 1.046 s after backend start]
root INFO Backend NodeFileUploadService.configure: 2.2 ms [Finished 1.046 s after backend start]
daemon INFO Starting daemon from C:\Program Files\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 1.0 ms [Finished 1.048 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 0.8 ms [Finished 1.048 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.4 ms [Finished 1.049 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.5 ms [Finished 1.050 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.5 ms [Finished 1.051 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.051 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 0.8 ms [Finished 1.052 s after backend start]
root INFO Theia app listening on http://localhost:54129.
root INFO Finished starting backend application: 4.8 ms [Finished 1.055 s after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/masan/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/masan/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\masan\.arduinoProIDE\plugins does not exist.
Restoring workspace roots: c:\Users\masan\OneDrive\Dokumen\Arduino\sketch_sep23b
isTempSketch: false. Input was c:\Users\masan\OneDrive\Dokumen\Arduino\sketch_sep23b
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
root INFO ---- DURATION: loadCliConfig took 34.139 ms. Args: [] ----
root INFO Resolve plugins list: 51.2 ms [Finished 1.100 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Program Files\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 4.0 ms [Finished 1.104 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 2.4 ms [Finished 1.106 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 9.3 ms [Finished 1.116 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 2.1 ms [Finished 1.118 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 2.7 ms [Finished 1.121 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 81.4 ms [Finished 1.202 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\masan\\.arduinoIDE\\arduino-cli.yaml","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"arduino-cli.exe version 0.27.1","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2023-09-27T05:03:39+07:00"}
{"IP":"127.0.0.1","Port":"54130"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 74.4 ms [Finished 1.276 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 88.2 ms [Finished 1.365 s after backend start]
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\masan\\AppData\\Local\\Arduino15\\packages","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Loading package arduino from: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2023-09-27T05:03:39+07:00"}
{"error":"opening signature file: open C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2023-09-27T05:03:39+07:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.6","Latest":"1.8.6","Name":"Arduino AVR Boards"},"time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"0.11.0-arduino5","systems":[{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-darwin_amd64.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-darwin_amd64.tar.gz","Checksum":"SHA-256:9e576c6e44f54b1e921a43ea77bcc08ec99e0e4e0905f4b9acf9ab2c979f0a22","Size":72429,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-linux_arm.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-linux_arm.tar.gz","Checksum":"SHA-256:acd4bd283fd408515279a44dd830499ad37b0767e8f2fde5c27e878ded909dc3","Size":2512819,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-linux_arm64.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-linux_arm64.tar.gz","Checksum":"SHA-256:b3f46a65da0c2fed2449dc5a3351c3c74953a868aa7f8d99ba2bb8c418344fe9","Size":2607592,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-linux_amd64.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-linux_amd64.tar.gz","Checksum":"SHA-256:96c64c278561af806b585c123c85748926ad02b1aedc07e5578ca9bee2be0d2a","Size":2283425,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-linux_386.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-linux_386.tar.gz","Checksum":"SHA-256:9a707692261e5710ed79a6d8a4031ffd0bfe1e585216569934346e9b2d68d0c2","Size":2524406,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-windows_386.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-windows_386.tar.gz","Checksum":"SHA-256:6451e16bf77600fe2436c8708ab4b75077c49997cf8bedf03221d9d6726bb641","Size":571340,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"0.1.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"1.0.9","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"1.4.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"0.13.0","systems":null}}
{"level":"info","msg":"Loading package esp32 from: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware","time":"2023-09-27T05:03:39+07:00"}
{"error":"opening signature file: open C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\installed.json.sig","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"esp32:esp32","Installed":"2.0.13","Latest":"2.0.13","Name":"esp32"},"time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\tools","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\tools","time":"2023-09-27T05:03:39+07:00"}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"4.5.1","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-src.tar.gz","ArchiveFileName":"esptool-v4.5.1-src.tar.gz","Checksum":"SHA-256:aa06831a7d88d8ccde4ea21241e983a08dbdae967290e181658b0d18bffc8f86","Size":96922,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-src.tar.gz","ArchiveFileName":"esptool-v4.5.1-src.tar.gz","Checksum":"SHA-256:aa06831a7d88d8ccde4ea21241e983a08dbdae967290e181658b0d18bffc8f86","Size":96922,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-src.tar.gz","ArchiveFileName":"esptool-v4.5.1-src.tar.gz","Checksum":"SHA-256:aa06831a7d88d8ccde4ea21241e983a08dbdae967290e181658b0d18bffc8f86","Size":96922,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-src.tar.gz","ArchiveFileName":"esptool-v4.5.1-src.tar.gz","Checksum":"SHA-256:aa06831a7d88d8ccde4ea21241e983a08dbdae967290e181658b0d18bffc8f86","Size":96922,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-macos.tar.gz","ArchiveFileName":"esptool-v4.5.1-macos.tar.gz","Checksum":"SHA-256:78b52acfd51541ceb97cee893b7d4d49b8ddc284602be8c73ea47e3d849e0956","Size":5850888,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-win64.zip","ArchiveFileName":"esptool-v4.5.1-win64.zip","Checksum":"SHA-256:64d0c24499d46b80d6bd7a05c98bdacc3455ab6d503cc2a99e35711310216045","Size":6638448,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-win64.zip","ArchiveFileName":"esptool-v4.5.1-win64.zip","Checksum":"SHA-256:64d0c24499d46b80d6bd7a05c98bdacc3455ab6d503cc2a99e35711310216045","Size":6638448,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"3.0.0-gnu12-dc7f933","systems":[{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/aarch64-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"aarch64-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:fc56e389383749e4cf4fab0fcf75cc0ebc41e59383caf6c2eff1c3d9794af200","Size":44651,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/arm-linux-gnueabihf.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"arm-linux-gnueabihf.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:52b642dd0545eb3bd8dfb75dde6601df21700e4867763fd2696274be279294c5","Size":37211,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/i686-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"i686-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:7886051d8ccc54aed0af2e7cdf6ff992bb51638df86f3b545955697720b6d062","Size":48033,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/i686-w64-mingw32.mklittlefs-c41e51a.200706.zip","ArchiveFileName":"i686-w64-mingw32.mklittlefs-c41e51a.200706.zip","Checksum":"SHA-256:43740db30ce451454f2337331f10ab4ed41bd83dbf0fa0cb4387107388b59f42","Size":332655,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/x86_64-apple-darwin14.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"x86_64-apple-darwin14.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:e3edd5e05b70db3c7df6b9d626558348ad04804022fe955c799aeb51808c7dc3","Size":362608,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/x86_64-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"x86_64-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:66e84dda0aad747517da3785125e05738a540948aab2b7eaa02855167a1eea53","Size":46778,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/x86_64-w64-mingw32.mklittlefs-c41e51a.200706.zip","ArchiveFileName":"x86_64-w64-mingw32.mklittlefs-c41e51a.200706.zip","Checksum":"SHA-256:2e319077491f8e832e96eb4f2f7a70dd919333cee4b388c394e0e848d031d542","Size":345132,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"0.2.3","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-win32.zip","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-win32.zip","Checksum":"SHA-256:b647f2c2efe6949819c85ea9404271b55c7c9c25bcb98d3b98a1d0ba771adf56","Size":249809,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","Checksum":"SHA-256:9f43fc74a858cf564966b5035322c3e5e61c31a647c5a1d71b388ed6efc48423","Size":130270,"CachePath":"packages"}},{"os":"i386-apple-darwin","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","Checksum":"SHA-256:9f43fc74a858cf564966b5035322c3e5e61c31a647c5a1d71b388ed6efc48423","Size":130270,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux64.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux64.tar.gz","Checksum":"SHA-256:5e1a4ff41385e842f389f6b5254102a547e566a06b49babeffa93ef37115cb5d","Size":50646,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux32.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux32.tar.gz","Checksum":"SHA-256:464463a93e8833209cdc29ba65e1a12fec31718dc10075c195a2445b2c3f6cb0","Size":48751,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","Checksum":"SHA-256:ade3dc00117912ac08a1bdbfbfe76b12d21a34bc5fa1de0cfc45fe7a8d0a0185","Size":40665,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","Checksum":"SHA-256:ade3dc00117912ac08a1bdbfbfe76b12d21a34bc5fa1de0cfc45fe7a8d0a0185","Size":40665,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"v0.11.0-esp32-20221026","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-linux-amd64-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-linux-amd64-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:ce63e9b1dfab60cc62da5dc2abcc22ba7036c42afe74671c787eb026744e7d0b","Size":2051435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-linux-arm64-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-linux-arm64-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:fe60a3a603e8c6bee47367e40fcb8c0da3a38e01163e9674ebc919b067700506","Size":1993843,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-linux-armel-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-linux-armel-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:6ef76101cca196a4be30fc74f191eff34abb423e32930a383012b866c9b76135","Size":2092111,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-macos-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-macos-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:8edc666a0a230432554b73df7c62e0b5ec21fb018e7fda13b11a7ca8b6c1763b","Size":2199855,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-macos-arm64-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-macos-arm64-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:c426c0158ba6488e2f432f7c5b22e79155b5b0fae6d1ad5bbd7894723b43aa12","Size":2247179,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-win32-0.11.0-esp32-20221026.zip","ArchiveFileName":"openocd-esp32-win32-0.11.0-esp32-20221026.zip","Checksum":"SHA-256:e0e789d35308c029c6b53457cf4a42a5620cb1a3014740026c089c2ed4fd77b2","Size":2493214,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-win32-0.11.0-esp32-20221026.zip","ArchiveFileName":"openocd-esp32-win32-0.11.0-esp32-20221026.zip","Checksum":"SHA-256:e0e789d35308c029c6b53457cf4a42a5620cb1a3014740026c089c2ed4fd77b2","Size":2493214,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"esp-2021r2-patch5-8.4.0","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","Checksum":"SHA-256:f7d73e5f9e2df3ea6ca8e2c95d6ca6d23d6b38fd101ea5d3012f3cb3cd59f39f","Size":192388486,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","Checksum":"SHA-256:cf520ae3a72f65b9758ea187524b105b8b7546566d738c32e60a0df9846ef1af","Size":188626914,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","Checksum":"SHA-256:2dc3536214caa1697f6834bb4701d05894ca55b53589fc5b54064b050ef93799","Size":188624050,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","Checksum":"SHA-256:165d6d53e76d79f5ade7e2b7ade54b2b495ecfda0d1184d84d6343659d0e3bdb","Size":194606113,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","Checksum":"SHA-256:d6d4cef216cbf28d6fbb88f3e127d4f42a376d9497c260bf8c1ad9cef440f839","Size":199411930,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","Checksum":"SHA-256:6e03f2ab1f145be13f8890c6de77b53f52c7bffe3d9d5824549db20298f5ba91","Size":191209735,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","Checksum":"SHA-256:1e0cfcfbc8f82c441261cadd21742f66d716ec18c18bf10ed7c7d5b0bee6752f","Size":257844437,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","Checksum":"SHA-256:b08f568e8fe5069dd521b87da21b8e56117e5c2c3b492f73a51966a46d3379a4","Size":259712666,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"11.2_20220823","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-x86_64-linux-gnu.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-x86_64-linux-gnu.tar.gz","Checksum":"SHA-256:6bf5b5d2d407e074af2a74fc826764934ac1625a1751c52fbc0d4d7772061f8f","Size":26799809,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-aarch64-linux-gnu.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-aarch64-linux-gnu.tar.gz","Checksum":"SHA-256:e54ef67cdb5724fc2da8f0487f19b2c83c08b560fff317f5ffd98fbb230b397a","Size":27021672,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-arm-linux-gnueabi.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-arm-linux-gnueabi.tar.gz","Checksum":"SHA-256:86772c6aee8a05b2c75a6b04e9da630e35e8415b64da8ccde92a5fb2d3c7fcf4","Size":25532577,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-i586-linux-gnu.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-i586-linux-gnu.tar.gz","Checksum":"SHA-256:3463be3e24182b7f1bd0fb232020534445b2d0ea0e7093c1b4f4da102b3baf52","Size":26188698,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-x86_64-apple-darwin14.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-x86_64-apple-darwin14.tar.gz","Checksum":"SHA-256:a9db1811ebb9271134eba2f7c303fc2587bd4b2a1ae33cd05ff2605cd2fb30d2","Size":38397584,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-aarch64-apple-darwin21.1.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-aarch64-apple-darwin21.1.tar.gz","Checksum":"SHA-256:c94fb6d726b8d97e65e23237f5126a41343bca8f22a0414df5f0e6777e36f51c","Size":21593613,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-i686-w64-mingw32.zip","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-i686-w64-mingw32.zip","Checksum":"SHA-256:20cdee8a1c01428363ef02f4cc8035c65508d6b43560c525733eae94b7c7bb50","Size":23436802,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-x86_64-w64-mingw32.zip","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-x86_64-w64-mingw32.zip","Checksum":"SHA-256:add72366485b784b66837ce263548980f1df144d0954c42d75a81f6acbd43cac","Size":24802315,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"11.2_20220823","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-x86_64-linux-gnu.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-x86_64-linux-gnu.tar.gz","Checksum":"SHA-256:b5f7cc3e4b5a58db655754083ed9652e4953e71c3b4922fb624e7a034ec24a64","Size":26947336,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-aarch64-linux-gnu.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-aarch64-linux-gnu.tar.gz","Checksum":"SHA-256:816acfae38b6b443f4f1590395f68f079243539259d19c7772ae6416c6519444","Size":27134508,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-arm-linux-gnueabi.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-arm-linux-gnueabi.tar.gz","Checksum":"SHA-256:4dd1bace0633196fddfdcef3cebcc4bbfce22f5a0d2d1e3d618f3d8a6cbfcacc","Size":25205239,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-i586-linux-gnu.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-i586-linux-gnu.tar.gz","Checksum":"SHA-256:27744d09d171be2f55ec15fa7f2d7f8ff94d33f7e130d24ebe082cb6c438618b","Size":25978028,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-x86_64-apple-darwin14.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-x86_64-apple-darwin14.tar.gz","Checksum":"SHA-256:1432faa12d7301133f6ee654d60751b57adcc6cf323ee1ecc393f06f0225eff4","Size":38386785,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-aarch64-apple-darwin21.1.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-aarch64-apple-darwin21.1.tar.gz","Checksum":"SHA-256:d0b542ef070ea72857f9cf554f176a0a9d868cd59e05ac293ad39402bcc5277d","Size":21671964,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-i686-w64-mingw32.zip","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-i686-w64-mingw32.zip","Checksum":"SHA-256:1678b06aa80b1d689d05548056635efde5b73b98f2c3de5d555bcfc6f374c5d0","Size":23241302,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-x86_64-w64-mingw32.zip","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-x86_64-w64-mingw32.zip","Checksum":"SHA-256:7060df4b6aa133e282147c3651d50222d677d6a0fff92979c500353b099a3f41","Size":25135265,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"esp-2021r2-patch5-8.4.0","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","Checksum":"SHA-256:8ef14e0409c2011b41e504a30f70d3e35287313a795d1f2462ad2cd0e2052d37","Size":94397702,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","Checksum":"SHA-256:e7d217ac2ef52c746a41f8647840b2717edcd8afc15f081bc1c4505e10a189b7","Size":90684219,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","Checksum":"SHA-256:ea6631f8a5105ae90d7fc462c10ed4f9049924ea8c2f9391d90b339d5f881dac","Size":89954866,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","Checksum":"SHA-256:ecb90af9cede0982672234da0b1bd7b7f76eadde60aa5c82eefdf37d64ffe49f","Size":96354023,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","Checksum":"SHA-256:19af109fda024a3a4c989f7ccaa104f9b1b74cfd6c9363e730bb8cb9b50d5dc4","Size":101712946,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","Checksum":"SHA-256:b14189772d70a96813895fff7731d0f2fec0c825cfc02e002d6d91a0cc4b6b1d","Size":93104016,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","Checksum":"SHA-256:9851c2cfa355e1fad8abfb643a1c945d27385b1851f3ae468915ea78fcbec940","Size":118610020,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","Checksum":"SHA-256:a328b3c55631846241bbe7999a309b20b797c8dc50b6e8dccf463e66a2da5fb4","Size":121846722,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"esp-2021r2-patch5-8.4.0","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","Checksum":"SHA-256:19c77bd91fefab7c8c40a6334f9b985e2d9a1c7fac6d424b692110930dd3682f","Size":67849099,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","Checksum":"SHA-256:bdcd24676ef2a65b670ca9e0a01768ece47f4dfcfb545a3307f76a054c33b522","Size":64154532,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","Checksum":"SHA-256:b26723b6ce1c35b90f204eb39e5ab06a6f80fb7895f000e16b6962e4c176ae32","Size":63448105,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","Checksum":"SHA-256:da3b5c45e4997d14269df1814c92dd7004902bb810608341bc3819c3e506fa0b","Size":69656104,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","Checksum":"SHA-256:8eb63745b44083edef7cc6fdf3b06999f576b75134bc5e8b0ef881ca439b72d7","Size":75154138,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","Checksum":"SHA-256:4cd38d6ec31076c0aa083f62ab84ab5c33aa07fafd0af61366186e5f553aa008","Size":66457613,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","Checksum":"SHA-256:c758062295804b082fbd77fcd59a356f62d4e76372aaa29589cc871603309cba","Size":82338511,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","Checksum":"SHA-256:1c1e168ff8bc460a9719f3b216d3c1125d29040389786d738244838499362c74","Size":85579252,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:39+07:00","tool":{"version":"esp-2021r2-patch5-8.4.0","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","Checksum":"SHA-256:8aa17a6adf01efa5b1628c8ac578063a44d26ae9581d39486b92223a41ef262f","Size":68099473,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","Checksum":"SHA-256:b218c11122e5565b6442376ebd21a652abdfcbf90981afa3e177ce978710225d","Size":64233211,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","Checksum":"SHA-256:967477434ad5483718915936a77ce915a10c5972a6b3fd02688a5c4e14182bfb","Size":63530586,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","Checksum":"SHA-256:07671d01a63ebd389912787efb2b263677c7b351c07fe430ded733cdae95e81d","Size":70025439,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","Checksum":"SHA-256:99b6d44cea5aebbedc8b6965e7bf551aa4a40ed83ddbe1c0e9b7cb255564ded5","Size":75719772,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","Checksum":"SHA-256:c64b05be25d26916c65dcfe11de9e60b96d58980b2df706d3074cb70b1ef6cb9","Size":66791095,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","Checksum":"SHA-256:658d3036ffdf11ddad6f0a784c8829f6ffd4dbd7c252d7f61722256d0ad43975","Size":82665716,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","Checksum":"SHA-256:9000be38d44bf79c39b93a2aeb99b42e956c593ccbc02fe31cb9c71ae1bbcb22","Size":86022563,"CachePath":"packages"}}]}}
{"index":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2023-09-27T05:03:39+07:00","trusted":true}
{"error":"opening signature file: open c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig: The system cannot find the file specified.","index":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_esp32_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig","time":"2023-09-27T05:03:39+07:00"}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:03:39+07:00"}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:03:39+07:00"}
{"index":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2023-09-27T05:03:39+07:00"}
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 79.2 ms [Finished 1.444 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 43.5 ms [Finished 1.487 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 48.1 ms [Finished 1.535 s after backend start]
daemon INFO {"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2023-09-27T05:03:39+07:00"}
{"dir":"c:\\Users\\masan\\OneDrive\\Dokumen\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2023-09-27T05:03:39+07:00"}
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 15.6 ms [Finished 1.551 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 69.8 ms [Finished 1.621 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 66.0 ms [Finished 1.687 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 44.9 ms [Finished 1.732 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "C:\Program Files\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 47.6 ms [Finished 1.780 s after backend start]
root INFO Deploy plugins list: 51.2 ms [Finished 1.785 s after backend start]
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO {"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"starting discovery builtin:dfu-discovery process","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:dfu-discovery process","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:dfu-discovery","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2023-09-27T05:03:40+07:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:dfu-discovery","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:dfu-discovery received message type: start_sync, message: OK","time":"2023-09-27T05:03:40+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM3","time":"2023-09-27T05:03:40+07:00"}
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 127.6 ms [Finished 1.511 s after frontend start]
app-state-change >>> new app state <started_contributions was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <started_contributions> for window <1>
app-state-change >>> new app state <attached_shell was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <attached_shell> for window <1>
root INFO Start frontend contributions: 343.3 ms [Finished 1.687 s after frontend start]
root INFO Changed application state from 'init' to 'started_contributions'.
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO ------- SERIALIZED LAYOUT DATA -------
root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"counter":0,"kind":"navigatable","uri":"file:///c%3A/Users/masan/OneDrive/Dokumen/Arduino/sketch_sep23b/sketch_sep23b.ino"}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":10,\"column\":1},\"position\":{\"lineNumber\":10,\"column\":1}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":1,\"column\":1},\"firstPositionDeltaTop\":0},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":10,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"},{"constructionOptions":{"factoryId":"settings_widget"},"innerWidgetState":"{\"scopeTabBarState\":{\"scopeDetails\":{\"scope\":1,\"activeScopeIsFolder\":false}},\"editorState\":{\"firstVisibleChildID\":\"\"},\"searchbarWidgetState\":{\"searchTerm\":\"\"}}"}],"currentIndex":0}},"mainPanelPinned":[false,false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"}],"currentIndex":0}},"pinned":[false],"size":272,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":248},"rightPanel":{"type":"sidepanel","items":[]}}
root INFO ------- END SERIALIZED LAYOUT DATA -------
discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0xEA60"],["serialNumber","0001"],["vid","0x10C4"]]}},"error":""}
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e] Waiting for backend deployment: 84.5 ms [Finished 1.770 s after frontend start]
root INFO Refreshing token github|34059838
root INFO Attached boards and available ports changed:
Page 2
root INFO  - New port is available on COM3 Serial Port (USB)
root INFO ------------------------------------------
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496) starting instance
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 399.875 ms. Args: [{"uri":"file:///c%3A/Users/masan/OneDrive/Dokumen/Arduino"}] ----
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e] Sync of 16 plugins: 677.4 ms [Finished 2.447 s after frontend start]
app-state-change >>> new app state <initialized_layout was received from sender <1>. current window ID: 1
root INFO <<< The layout has been successfully restored.
app-state-change <<< new app state is <initialized_layout> for window <1>
root INFO Initialize the workbench layout: 991.2 ms [Finished 2.701 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][marus25.cortex-debug]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][vscode.cpp]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][vscode.json]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][vscode.json-language-features]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e] Load contributions of 16 plugins: 80.7 ms [Finished 2.783 s after frontend start]
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(cortex-debug@0.3.10 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] Debugger contribution has been registered: cortex-debug
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(cpp@1.52.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(json@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(json-language-features@1.46.1 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-cs@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-de@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-es@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-fr@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-it@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-ja@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-nl@1.48.3 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-pt-BR@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-ru@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-tr@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): initializing(vscode-language-pack-zh-hans@1.69.0 with C:\Program Files\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 23496] PLUGIN_HOST(23496): PluginManagerExtImpl/loadPlugin(C:\Program Files\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][marus25.cortex-debug]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][arduino.vscode-arduino-tools]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][vscode.cpp]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][vscode.json]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][vscode.json-language-features]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [da00ece4-13cf-4fb8-bec8-d59e0816d67e] Start of 16 plugins: 389.7 ms [Finished 3.180 s after frontend start]
app-state-change >>> new app state <ready was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <ready> for window <1>
root INFO Frontend application start: 2465.7 ms [Finished 5.079 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 849.5 ms [Finished 3.637 s after frontend start]
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO Executing startup tasks: []
root INFO ---- DURATION: installed took 20.233 ms. Args: [{}] ----
root INFO ---- DURATION: getSketchesNew took 42.549 ms. Args: [{}] ----
Checking for update
root INFO ---- DURATION: installed took 15.453 ms. Args: [{"fqbn":"esp32:esp32:esp32doit-devkit-v1"}] ----
root ERROR ---- !!!SLOW!!! DURATION: search took 692.144 ms. Args: [{"type":"Updatable"}] ----
root INFO Starting language server: esp32:esp32:esp32doit-devkit-v1
daemon INFO {"level":"info","msg":"Searching tools required for board esp32:esp32:esp32doit-devkit-v1","time":"2023-09-27T05:03:44+07:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"dfu-util","ToolVersion":"0.11.0-arduino5","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"esptool_py","ToolVersion":"4.5.1","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"mklittlefs","ToolVersion":"3.0.0-gnu12-dc7f933","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"mkspiffs","ToolVersion":"0.2.3","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"openocd-esp32","ToolVersion":"v0.11.0-esp32-20221026","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"riscv32-esp-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"riscv32-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"xtensa-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"xtensa-esp32-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"xtensa-esp32s2-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:44+07:00","tool":{"ToolName":"xtensa-esp32s3-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2023-09-27T05:03:44+07:00"}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:03:44+07:00"}
{"dir":"c:\\Users\\masan\\OneDrive\\Dokumen\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2023-09-27T05:03:44+07:00"}
Found version 2.2.1 (url: arduino-ide_2.2.1_Windows_64bit.exe)
daemon INFO {"level":"info","msg":"Searching tools required for board esp32:esp32:esp32doit-devkit-v1","time":"2023-09-27T05:03:45+07:00"}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"dfu-util","ToolVersion":"0.11.0-arduino5","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"esptool_py","ToolVersion":"4.5.1","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"mklittlefs","ToolVersion":"3.0.0-gnu12-dc7f933","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"mkspiffs","ToolVersion":"0.2.3","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"openocd-esp32","ToolVersion":"v0.11.0-esp32-20221026","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"riscv32-esp-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"riscv32-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"xtensa-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"xtensa-esp32-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
daemon INFO {"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"xtensa-esp32s2-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:45+07:00","tool":{"ToolName":"xtensa-esp32s3-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2023-09-27T05:03:45+07:00"}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:03:45+07:00"}
{"dir":"c:\\Users\\masan\\OneDrive\\Dokumen\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2023-09-27T05:03:45+07:00"}
daemon INFO {"level":"info","msg":"Searching tools required for board esp32:esp32:esp32doit-devkit-v1","time":"2023-09-27T05:03:46+07:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"dfu-util","ToolVersion":"0.11.0-arduino5","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"esptool_py","ToolVersion":"4.5.1","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"mklittlefs","ToolVersion":"3.0.0-gnu12-dc7f933","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"mkspiffs","ToolVersion":"0.2.3","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"openocd-esp32","ToolVersion":"v0.11.0-esp32-20221026","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"riscv32-esp-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"riscv32-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"xtensa-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"xtensa-esp32-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"xtensa-esp32s2-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:46+07:00","tool":{"ToolName":"xtensa-esp32s3-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2023-09-27T05:03:46+07:00"}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:03:46+07:00"}
{"dir":"c:\\Users\\masan\\OneDrive\\Dokumen\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2023-09-27T05:03:46+07:00"}
daemon INFO {"level":"info","msg":"Searching tools required for board esp32:esp32:esp32doit-devkit-v1","time":"2023-09-27T05:03:47+07:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"dfu-util","ToolVersion":"0.11.0-arduino5","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"esptool_py","ToolVersion":"4.5.1","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"mklittlefs","ToolVersion":"3.0.0-gnu12-dc7f933","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"mkspiffs","ToolVersion":"0.2.3","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"openocd-esp32","ToolVersion":"v0.11.0-esp32-20221026","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"riscv32-esp-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"riscv32-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"xtensa-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"xtensa-esp32-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"xtensa-esp32s2-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:03:47+07:00","tool":{"ToolName":"xtensa-esp32s3-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2023-09-27T05:03:47+07:00"}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:03:47+07:00"}
{"dir":"c:\\Users\\masan\\OneDrive\\Dokumen\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2023-09-27T05:03:47+07:00"}
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2023-09-27T05:03:50+07:00"}
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2023-09-27T05:03:50+07:00"}
daemon INFO {"level":"info","msg":"Updating index","time":"2023-09-27T05:03:50+07:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO core-client-provider [library-index]
root INFO core-client-provider [platform-index]
daemon INFO {"level":"info","msg":"URL: https://espressif.github.io/arduino-esp32/package_esp32_index.json","time":"2023-09-27T05:03:50+07:00"}
{"level":"info","msg":"Updating index","time":"2023-09-27T05:03:50+07:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"espressif.github.io","Path":"/arduino-esp32/package_esp32_index.json","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\masan\\AppData\\Local\\Arduino15\\packages","time":"2023-09-27T05:03:52+07:00"}
daemon INFO {"level":"info","msg":"Loading package arduino from: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2023-09-27T05:03:52+07:00"}
daemon INFO {"error":"opening signature file: open C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\installed.json.sig","time":"2023-09-27T05:03:52+07:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2023-09-27T05:03:52+07:00","tool":"builtin:serial-monitor"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.6","Latest":"1.8.6","Name":"Arduino AVR Boards"},"time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"0.11.0-arduino5","systems":[{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-darwin_amd64.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-darwin_amd64.tar.gz","Checksum":"SHA-256:9e576c6e44f54b1e921a43ea77bcc08ec99e0e4e0905f4b9acf9ab2c979f0a22","Size":72429,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-linux_arm.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-linux_arm.tar.gz","Checksum":"SHA-256:acd4bd283fd408515279a44dd830499ad37b0767e8f2fde5c27e878ded909dc3","Size":2512819,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-linux_arm64.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-linux_arm64.tar.gz","Checksum":"SHA-256:b3f46a65da0c2fed2449dc5a3351c3c74953a868aa7f8d99ba2bb8c418344fe9","Size":2607592,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-linux_amd64.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-linux_amd64.tar.gz","Checksum":"SHA-256:96c64c278561af806b585c123c85748926ad02b1aedc07e5578ca9bee2be0d2a","Size":2283425,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-linux_386.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-linux_386.tar.gz","Checksum":"SHA-256:9a707692261e5710ed79a6d8a4031ffd0bfe1e585216569934346e9b2d68d0c2","Size":2524406,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/dfu-util-0.11-arduino5-windows_386.tar.gz","ArchiveFileName":"dfu-util-0.11-arduino5-windows_386.tar.gz","Checksum":"SHA-256:6451e16bf77600fe2436c8708ab4b75077c49997cf8bedf03221d9d6726bb641","Size":571340,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"0.1.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"1.0.9","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"1.4.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"0.13.0","systems":null}}
{"level":"info","msg":"Loading package esp32 from: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware","time":"2023-09-27T05:03:52+07:00"}
daemon INFO {"error":"opening signature file: open C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\installed.json.sig","time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"esp32:esp32","Installed":"2.0.13","Latest":"2.0.13","Name":"esp32"},"time":"2023-09-27T05:03:52+07:00"}
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\tools","time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\tools","time":"2023-09-27T05:03:52+07:00"}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"4.5.1","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-src.tar.gz","ArchiveFileName":"esptool-v4.5.1-src.tar.gz","Checksum":"SHA-256:aa06831a7d88d8ccde4ea21241e983a08dbdae967290e181658b0d18bffc8f86","Size":96922,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-src.tar.gz","ArchiveFileName":"esptool-v4.5.1-src.tar.gz","Checksum":"SHA-256:aa06831a7d88d8ccde4ea21241e983a08dbdae967290e181658b0d18bffc8f86","Size":96922,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-src.tar.gz","ArchiveFileName":"esptool-v4.5.1-src.tar.gz","Checksum":"SHA-256:aa06831a7d88d8ccde4ea21241e983a08dbdae967290e181658b0d18bffc8f86","Size":96922,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-src.tar.gz","ArchiveFileName":"esptool-v4.5.1-src.tar.gz","Checksum":"SHA-256:aa06831a7d88d8ccde4ea21241e983a08dbdae967290e181658b0d18bffc8f86","Size":96922,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-macos.tar.gz","ArchiveFileName":"esptool-v4.5.1-macos.tar.gz","Checksum":"SHA-256:78b52acfd51541ceb97cee893b7d4d49b8ddc284602be8c73ea47e3d849e0956","Size":5850888,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-win64.zip","ArchiveFileName":"esptool-v4.5.1-win64.zip","Checksum":"SHA-256:64d0c24499d46b80d6bd7a05c98bdacc3455ab6d503cc2a99e35711310216045","Size":6638448,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/arduino-esp32/releases/download/2.0.7/esptool-v4.5.1-win64.zip","ArchiveFileName":"esptool-v4.5.1-win64.zip","Checksum":"SHA-256:64d0c24499d46b80d6bd7a05c98bdacc3455ab6d503cc2a99e35711310216045","Size":6638448,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"3.0.0-gnu12-dc7f933","systems":[{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/aarch64-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"aarch64-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:fc56e389383749e4cf4fab0fcf75cc0ebc41e59383caf6c2eff1c3d9794af200","Size":44651,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/arm-linux-gnueabihf.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"arm-linux-gnueabihf.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:52b642dd0545eb3bd8dfb75dde6601df21700e4867763fd2696274be279294c5","Size":37211,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/i686-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"i686-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:7886051d8ccc54aed0af2e7cdf6ff992bb51638df86f3b545955697720b6d062","Size":48033,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/i686-w64-mingw32.mklittlefs-c41e51a.200706.zip","ArchiveFileName":"i686-w64-mingw32.mklittlefs-c41e51a.200706.zip","Checksum":"SHA-256:43740db30ce451454f2337331f10ab4ed41bd83dbf0fa0cb4387107388b59f42","Size":332655,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/x86_64-apple-darwin14.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"x86_64-apple-darwin14.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:e3edd5e05b70db3c7df6b9d626558348ad04804022fe955c799aeb51808c7dc3","Size":362608,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/x86_64-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","ArchiveFileName":"x86_64-linux-gnu.mklittlefs-c41e51a.200706.tar.gz","Checksum":"SHA-256:66e84dda0aad747517da3785125e05738a540948aab2b7eaa02855167a1eea53","Size":46778,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/earlephilhower/esp-quick-toolchain/releases/download/3.0.0-gnu12/x86_64-w64-mingw32.mklittlefs-c41e51a.200706.zip","ArchiveFileName":"x86_64-w64-mingw32.mklittlefs-c41e51a.200706.zip","Checksum":"SHA-256:2e319077491f8e832e96eb4f2f7a70dd919333cee4b388c394e0e848d031d542","Size":345132,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"0.2.3","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-win32.zip","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-win32.zip","Checksum":"SHA-256:b647f2c2efe6949819c85ea9404271b55c7c9c25bcb98d3b98a1d0ba771adf56","Size":249809,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","Checksum":"SHA-256:9f43fc74a858cf564966b5035322c3e5e61c31a647c5a1d71b388ed6efc48423","Size":130270,"CachePath":"packages"}},{"os":"i386-apple-darwin","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-osx.tar.gz","Checksum":"SHA-256:9f43fc74a858cf564966b5035322c3e5e61c31a647c5a1d71b388ed6efc48423","Size":130270,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux64.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux64.tar.gz","Checksum":"SHA-256:5e1a4ff41385e842f389f6b5254102a547e566a06b49babeffa93ef37115cb5d","Size":50646,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux32.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux32.tar.gz","Checksum":"SHA-256:464463a93e8833209cdc29ba65e1a12fec31718dc10075c195a2445b2c3f6cb0","Size":48751,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","Checksum":"SHA-256:ade3dc00117912ac08a1bdbfbfe76b12d21a34bc5fa1de0cfc45fe7a8d0a0185","Size":40665,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/igrr/mkspiffs/releases/download/0.2.3/mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","ArchiveFileName":"mkspiffs-0.2.3-arduino-esp32-linux-armhf.tar.gz","Checksum":"SHA-256:ade3dc00117912ac08a1bdbfbfe76b12d21a34bc5fa1de0cfc45fe7a8d0a0185","Size":40665,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"v0.11.0-esp32-20221026","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-linux-amd64-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-linux-amd64-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:ce63e9b1dfab60cc62da5dc2abcc22ba7036c42afe74671c787eb026744e7d0b","Size":2051435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-linux-arm64-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-linux-arm64-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:fe60a3a603e8c6bee47367e40fcb8c0da3a38e01163e9674ebc919b067700506","Size":1993843,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-linux-armel-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-linux-armel-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:6ef76101cca196a4be30fc74f191eff34abb423e32930a383012b866c9b76135","Size":2092111,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-macos-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-macos-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:8edc666a0a230432554b73df7c62e0b5ec21fb018e7fda13b11a7ca8b6c1763b","Size":2199855,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-macos-arm64-0.11.0-esp32-20221026.tar.gz","ArchiveFileName":"openocd-esp32-macos-arm64-0.11.0-esp32-20221026.tar.gz","Checksum":"SHA-256:c426c0158ba6488e2f432f7c5b22e79155b5b0fae6d1ad5bbd7894723b43aa12","Size":2247179,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-win32-0.11.0-esp32-20221026.zip","ArchiveFileName":"openocd-esp32-win32-0.11.0-esp32-20221026.zip","Checksum":"SHA-256:e0e789d35308c029c6b53457cf4a42a5620cb1a3014740026c089c2ed4fd77b2","Size":2493214,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/openocd-esp32/releases/download/v0.11.0-esp32-20221026/openocd-esp32-win32-0.11.0-esp32-20221026.zip","ArchiveFileName":"openocd-esp32-win32-0.11.0-esp32-20221026.zip","Checksum":"SHA-256:e0e789d35308c029c6b53457cf4a42a5620cb1a3014740026c089c2ed4fd77b2","Size":2493214,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"esp-2021r2-patch5-8.4.0","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","Checksum":"SHA-256:f7d73e5f9e2df3ea6ca8e2c95d6ca6d23d6b38fd101ea5d3012f3cb3cd59f39f","Size":192388486,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","Checksum":"SHA-256:cf520ae3a72f65b9758ea187524b105b8b7546566d738c32e60a0df9846ef1af","Size":188626914,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","Checksum":"SHA-256:2dc3536214caa1697f6834bb4701d05894ca55b53589fc5b54064b050ef93799","Size":188624050,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","Checksum":"SHA-256:165d6d53e76d79f5ade7e2b7ade54b2b495ecfda0d1184d84d6343659d0e3bdb","Size":194606113,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","Checksum":"SHA-256:d6d4cef216cbf28d6fbb88f3e127d4f42a376d9497c260bf8c1ad9cef440f839","Size":199411930,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","Checksum":"SHA-256:6e03f2ab1f145be13f8890c6de77b53f52c7bffe3d9d5824549db20298f5ba91","Size":191209735,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","Checksum":"SHA-256:1e0cfcfbc8f82c441261cadd21742f66d716ec18c18bf10ed7c7d5b0bee6752f","Size":257844437,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","ArchiveFileName":"riscv32-esp-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","Checksum":"SHA-256:b08f568e8fe5069dd521b87da21b8e56117e5c2c3b492f73a51966a46d3379a4","Size":259712666,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"11.2_20220823","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-x86_64-linux-gnu.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-x86_64-linux-gnu.tar.gz","Checksum":"SHA-256:6bf5b5d2d407e074af2a74fc826764934ac1625a1751c52fbc0d4d7772061f8f","Size":26799809,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-aarch64-linux-gnu.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-aarch64-linux-gnu.tar.gz","Checksum":"SHA-256:e54ef67cdb5724fc2da8f0487f19b2c83c08b560fff317f5ffd98fbb230b397a","Size":27021672,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-arm-linux-gnueabi.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-arm-linux-gnueabi.tar.gz","Checksum":"SHA-256:86772c6aee8a05b2c75a6b04e9da630e35e8415b64da8ccde92a5fb2d3c7fcf4","Size":25532577,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-i586-linux-gnu.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-i586-linux-gnu.tar.gz","Checksum":"SHA-256:3463be3e24182b7f1bd0fb232020534445b2d0ea0e7093c1b4f4da102b3baf52","Size":26188698,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-x86_64-apple-darwin14.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-x86_64-apple-darwin14.tar.gz","Checksum":"SHA-256:a9db1811ebb9271134eba2f7c303fc2587bd4b2a1ae33cd05ff2605cd2fb30d2","Size":38397584,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-aarch64-apple-darwin21.1.tar.gz","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-aarch64-apple-darwin21.1.tar.gz","Checksum":"SHA-256:c94fb6d726b8d97e65e23237f5126a41343bca8f22a0414df5f0e6777e36f51c","Size":21593613,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-i686-w64-mingw32.zip","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-i686-w64-mingw32.zip","Checksum":"SHA-256:20cdee8a1c01428363ef02f4cc8035c65508d6b43560c525733eae94b7c7bb50","Size":23436802,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/riscv32-esp-elf-gdb-11.2_20220823-x86_64-w64-mingw32.zip","ArchiveFileName":"riscv32-esp-elf-gdb-11.2_20220823-x86_64-w64-mingw32.zip","Checksum":"SHA-256:add72366485b784b66837ce263548980f1df144d0954c42d75a81f6acbd43cac","Size":24802315,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"11.2_20220823","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-x86_64-linux-gnu.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-x86_64-linux-gnu.tar.gz","Checksum":"SHA-256:b5f7cc3e4b5a58db655754083ed9652e4953e71c3b4922fb624e7a034ec24a64","Size":26947336,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-aarch64-linux-gnu.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-aarch64-linux-gnu.tar.gz","Checksum":"SHA-256:816acfae38b6b443f4f1590395f68f079243539259d19c7772ae6416c6519444","Size":27134508,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-arm-linux-gnueabi.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-arm-linux-gnueabi.tar.gz","Checksum":"SHA-256:4dd1bace0633196fddfdcef3cebcc4bbfce22f5a0d2d1e3d618f3d8a6cbfcacc","Size":25205239,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-i586-linux-gnu.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-i586-linux-gnu.tar.gz","Checksum":"SHA-256:27744d09d171be2f55ec15fa7f2d7f8ff94d33f7e130d24ebe082cb6c438618b","Size":25978028,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-x86_64-apple-darwin14.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-x86_64-apple-darwin14.tar.gz","Checksum":"SHA-256:1432faa12d7301133f6ee654d60751b57adcc6cf323ee1ecc393f06f0225eff4","Size":38386785,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-aarch64-apple-darwin21.1.tar.gz","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-aarch64-apple-darwin21.1.tar.gz","Checksum":"SHA-256:d0b542ef070ea72857f9cf554f176a0a9d868cd59e05ac293ad39402bcc5277d","Size":21671964,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-i686-w64-mingw32.zip","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-i686-w64-mingw32.zip","Checksum":"SHA-256:1678b06aa80b1d689d05548056635efde5b73b98f2c3de5d555bcfc6f374c5d0","Size":23241302,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/binutils-gdb/releases/download/esp-gdb-v11.2_20220823/xtensa-esp-elf-gdb-11.2_20220823-x86_64-w64-mingw32.zip","ArchiveFileName":"xtensa-esp-elf-gdb-11.2_20220823-x86_64-w64-mingw32.zip","Checksum":"SHA-256:7060df4b6aa133e282147c3651d50222d677d6a0fff92979c500353b099a3f41","Size":25135265,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"esp-2021r2-patch5-8.4.0","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","Checksum":"SHA-256:8ef14e0409c2011b41e504a30f70d3e35287313a795d1f2462ad2cd0e2052d37","Size":94397702,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","Checksum":"SHA-256:e7d217ac2ef52c746a41f8647840b2717edcd8afc15f081bc1c4505e10a189b7","Size":90684219,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","Checksum":"SHA-256:ea6631f8a5105ae90d7fc462c10ed4f9049924ea8c2f9391d90b339d5f881dac","Size":89954866,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","Checksum":"SHA-256:ecb90af9cede0982672234da0b1bd7b7f76eadde60aa5c82eefdf37d64ffe49f","Size":96354023,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","Checksum":"SHA-256:19af109fda024a3a4c989f7ccaa104f9b1b74cfd6c9363e730bb8cb9b50d5dc4","Size":101712946,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","Checksum":"SHA-256:b14189772d70a96813895fff7731d0f2fec0c825cfc02e002d6d91a0cc4b6b1d","Size":93104016,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","Checksum":"SHA-256:9851c2cfa355e1fad8abfb643a1c945d27385b1851f3ae468915ea78fcbec940","Size":118610020,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","ArchiveFileName":"xtensa-esp32-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","Checksum":"SHA-256:a328b3c55631846241bbe7999a309b20b797c8dc50b6e8dccf463e66a2da5fb4","Size":121846722,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"esp-2021r2-patch5-8.4.0","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","Checksum":"SHA-256:19c77bd91fefab7c8c40a6334f9b985e2d9a1c7fac6d424b692110930dd3682f","Size":67849099,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","Checksum":"SHA-256:bdcd24676ef2a65b670ca9e0a01768ece47f4dfcfb545a3307f76a054c33b522","Size":64154532,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","Checksum":"SHA-256:b26723b6ce1c35b90f204eb39e5ab06a6f80fb7895f000e16b6962e4c176ae32","Size":63448105,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","Checksum":"SHA-256:da3b5c45e4997d14269df1814c92dd7004902bb810608341bc3819c3e506fa0b","Size":69656104,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","Checksum":"SHA-256:8eb63745b44083edef7cc6fdf3b06999f576b75134bc5e8b0ef881ca439b72d7","Size":75154138,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","Checksum":"SHA-256:4cd38d6ec31076c0aa083f62ab84ab5c33aa07fafd0af61366186e5f553aa008","Size":66457613,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","Checksum":"SHA-256:c758062295804b082fbd77fcd59a356f62d4e76372aaa29589cc871603309cba","Size":82338511,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","ArchiveFileName":"xtensa-esp32s2-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","Checksum":"SHA-256:1c1e168ff8bc460a9719f3b216d3c1125d29040389786d738244838499362c74","Size":85579252,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2023-09-27T05:03:52+07:00","tool":{"version":"esp-2021r2-patch5-8.4.0","systems":[{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-amd64.tar.gz","Checksum":"SHA-256:8aa17a6adf01efa5b1628c8ac578063a44d26ae9581d39486b92223a41ef262f","Size":68099473,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-arm64.tar.gz","Checksum":"SHA-256:b218c11122e5565b6442376ebd21a652abdfcbf90981afa3e177ce978710225d","Size":64233211,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-armel.tar.gz","Checksum":"SHA-256:967477434ad5483718915936a77ce915a10c5972a6b3fd02688a5c4e14182bfb","Size":63530586,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-linux-i686.tar.gz","Checksum":"SHA-256:07671d01a63ebd389912787efb2b263677c7b351c07fe430ded733cdae95e81d","Size":70025439,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-macos.tar.gz","Checksum":"SHA-256:99b6d44cea5aebbedc8b6965e7bf551aa4a40ed83ddbe1c0e9b7cb255564ded5","Size":75719772,"CachePath":"packages"}},{"os":"arm64-apple-darwin","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-macos-arm64.tar.gz","Checksum":"SHA-256:c64b05be25d26916c65dcfe11de9e60b96d58980b2df706d3074cb70b1ef6cb9","Size":66791095,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-win32.zip","Checksum":"SHA-256:658d3036ffdf11ddad6f0a784c8829f6ffd4dbd7c252d7f61722256d0ad43975","Size":82665716,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://github.com/espressif/crosstool-NG/releases/download/esp-2021r2-patch5/xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","ArchiveFileName":"xtensa-esp32s3-elf-gcc8_4_0-esp-2021r2-patch5-win64.zip","Checksum":"SHA-256:9000be38d44bf79c39b93a2aeb99b42e956c593ccbc02fe31cb9c71ae1bbcb22","Size":86022563,"CachePath":"packages"}}]}}
daemon INFO {"index":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2023-09-27T05:03:52+07:00","trusted":true}
daemon INFO {"error":"opening signature file: open c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig: The system cannot find the file specified.","index":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_esp32_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\package_esp32_index.json.sig","time":"2023-09-27T05:03:52+07:00"}
daemon INFO {"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:03:52+07:00"}
daemon INFO {"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:03:52+07:00"}
{"index":"c:\\Users\\masan\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2023-09-27T05:03:52+07:00"}
daemon INFO {"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2023-09-27T05:03:52+07:00"}
{"dir":"c:\\Users\\masan\\OneDrive\\Dokumen\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2023-09-27T05:03:52+07:00"}
discovery-log INFO restarting before stop
discovery-log INFO stop
discovery-log INFO >>> Stopping boards watcher...
discovery-log INFO Canceling boards watcher...
discovery-log INFO disposing requesting cancel
discovery-log INFO disposing canceled
discovery-log INFO error received
discovery-log INFO cancel error received!
discovery-log INFO stop received event: either end or cancel
discovery-log INFO stop stopped
discovery-log INFO received end
discovery-log INFO restarting after stop
discovery-log INFO start
discovery-log INFO start new deferred
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO {"level":"info","msg":"boards watcher stream closed","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:dfu-discovery process","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2023-09-27T05:03:53+07:00"}
{"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:dfu-discovery process","time":"2023-09-27T05:03:53+07:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:dfu-discovery","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2023-09-27T05:03:53+07:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2023-09-27T05:03:53+07:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2023-09-27T05:03:53+07:00"}
{"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2023-09-27T05:03:53+07:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:dfu-discovery received message type: hello, message: OK, protocol version: 1","time":"2023-09-27T05:03:53+07:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:dfu-discovery","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:dfu-discovery received message type: start_sync, message: OK","time":"2023-09-27T05:03:53+07:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM3","time":"2023-09-27T05:03:53+07:00"}
discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM3","label":"COM3","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0xEA60"],["serialNumber","0001"],["vid","0x10C4"]]}},"error":""}
discovery-log WARN Port 'COM3 Serial Port (USB)' was already available. Known boards before override: []
root INFO Attached boards and available ports changed:
root INFO No changes.
root INFO ------------------------------------------
daemon INFO {"level":"info","msg":"Searching tools required for board esp32:esp32:esp32doit-devkit-v1","time":"2023-09-27T05:04:02+07:00"}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"dfu-util","ToolVersion":"0.11.0-arduino5","ToolPackager":"arduino"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"esptool_py","ToolVersion":"4.5.1","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"mklittlefs","ToolVersion":"3.0.0-gnu12-dc7f933","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"mkspiffs","ToolVersion":"0.2.3","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"openocd-esp32","ToolVersion":"v0.11.0-esp32-20221026","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"riscv32-esp-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"riscv32-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"xtensa-esp-elf-gdb","ToolVersion":"11.2_20220823","ToolPackager":"esp32"}}
daemon INFO {"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"xtensa-esp32-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"xtensa-esp32s2-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"level":"info","msg":"Required tool","time":"2023-09-27T05:04:02+07:00","tool":{"ToolName":"xtensa-esp32s3-elf-gcc","ToolVersion":"esp-2021r2-patch5-8.4.0","ToolPackager":"esp32"}}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2023-09-27T05:04:02+07:00"}
{"dir":"C:\\Users\\masan\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\2.0.13\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2023-09-27T05:04:02+07:00"}
{"dir":"c:\\Users\\masan\\OneDrive\\Dokumen\\Arduino\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2023-09-27T05:04:02+07:00"}
root INFO Executing 'arduino.languageserver.notifyBuildDidComplete' with {"buildOutputUri":"file:///c%3A/Users/masan/AppData/Local/Temp/arduino-sketch-2840AADED5F92CEDC9C0A52B7F86D23B"}
root ERROR Unexpected error when firing event on build did complete. file:///c%3A/Users/masan/AppData/Local/Temp/arduino-sketch-2840AADED5F92CEDC9C0A52B7F86D23B
root ERROR Request executeCommand failed with error: Language client is not ready yet
