Hi, I have an UNO R3 and cannot get the computer to work with it. I have tried sending it to the folder containing the drivers from the device manager, it says there are no suitable drivers. I tried to use the preinstalled ones on my computer and it says the device cannot start. I followed every guide I could find on how to install this on windows 7, but I just can't get the drivers installed so I can't upload any sketches.
It shows up under "other devices" and doesn't call it arduino uno, it says USB2.0-Serial. And when I extract the files, and tell the computer to look in the folder for a driver, it says displays the following error.
I have installed the IDE using the installer from the website
Still no luck, I attached the screen that came up when I installed the driver. It's almost like I've installed the wrong driver, but I have tried both the R3 and the UNO driver from multiple sources and locations.
Turns out I didn't read the fine print of my order, I bought an arduino UNO compatible board, not the official UNO. So I needed drivers from another set-up as this uses slightly different hardware. I have attached the .zip which contains the necessary driver for anyone who may need it.
I purchased the kit off of eBay, from resistorsdirect. Here is a link to the product
Arduino UNO R3 Starter Kit K Compatible Microcontroller ATMEGA328P
Thank you all for your help! It's up and running now, the "blink" example is working just fine on my cheap clone.
