Wiper system with AccelStepper and a DRV8825
I am working on a project where a digital signal is sent to an Arduino Uno to run a stepper motor forward for a distance and back to its original point. When it reaches the original point it stops. I can get it to do one cycle after I download the program but when I send the start signal again it tries to go the wrong direction. The start signal is controlled by a relay connected to a robot. I also have the power for the stepper on the relay.
Any help would be greatly apricated.
We can't help unless you post your code, at least.
#include <AccelStepper.h>
// Define pin connections
const int dirPin = 2;
const int stepPin = 3;
const int start = 4;
// Define motor interface type
#define motorInterfaceType 1
// Creates an instance
AccelStepper myStepper(motorInterfaceType, stepPin, dirPin);
  pinMode(start, INPUT);
  // set the maximum speed, acceleration factor,
  // initial speed and the target position
  myStepper.setMaxSpeed(800);
  myStepper.setAcceleration(100);
  // Set the target position:
  if (digitalRead(start) == HIGH) {
    myStepper.moveTo(5985);  // Run to target position with set speed and acceleration/deceleration:
    myStepper.run();
   if (myStepper.currentPosition() == 5985)
    myStepper.moveTo(15);
    myStepper.runToPosition();
   if (myStepper.distanceToGo() == 0)
    myStepper.stop();
   if (digitalRead(start)==LOW)
    myStepper.setCurrentPosition(0);
I fixed it.
Thank you for looking.
