I'm reading an analog value from a voltage sensor. It works as expected when logging the output to the serial monitor. Then I attach a LCD display to display the voltage. It uses Wire.Begin() after that call my analogRead value changes. 12,5 volts to 14,4 volts.
olven:
Anybody know why this is happening?
The Wire library uses Analog pins A4, A5. So you cannot use these pins for Analog input while using I2C communications.
I would be helpful if you would include a copy of your sketch, and a description of the circuit.
Just saying 'I'm read an analog value from a voltage sensor', is not very helpful. And it would be nice to know which Arduino you are using? Is it a Due using 3.3v or a Uno running on 5v, have you directly connect 12.5 volts to an Analog input pin(critically bad idea) or are you using a SPI A/D converter?
Chuck.
Check out my Kickstarter Project Memory Panes an expansion RAM Shield for Mega2560's. It adds 1MB of RAM for those projects where 8KB is not enough.
