Wire.Endtransmission: How can I test if I2C device available
Hello
How can I test if an I2C cable is installed before trying to start it with the Wire command code? The I2C cable would be use to drive an LCD for a diagnostic only. Don't need to have it installed permanently
Problem, code stall after Wire.endTransmission();
Wire.beginTransmission(0x20);
Wire.write(0xff); // put a high level on pins
Martin
When the Wire.endTransmission() halts the sketch, then SDA is shortcut to GND or SCL is shortcut to GND or SDA is shortcut to SCL. Instead of a real "shortcut" it is also possible that a I2C device on the bus is not powered, or that there are no pullup resistors.
To check if something is on the bus. Use its address with Wire.beginTransmission(), then a Wire.endTransmission() and check the error returned by Wire.endTransmission().
That is how the I2C Scanner works: Arduino Playground - I2cScanner.
The I2C bus was not designed to let it go through a cable. How long is that cable ? What kind of cable ?
Can you tell which Arduino board you use and which display ?
you could do a check like suggested by sparkfun "isConnected" How to Write A Great Arduino Library - News - SparkFun Electronics
noiasca:
Thank you Noissca. Great info, Will go trough it tonight.
Stay safe
Martin
