Hi, I'm using the artik5 v0.5 board and I failed to upload a i2c sketch on it using Arduino IDE. (1.6.10 hourly builds)
I installed the ARM Linux Boards v0.3.8 and selected the artik5 v0.5 board in IDE.
There is a wire library in the contributed library part, but it seems that it's not activated.
I tried to compare the wire.h and wire.cpp in the arm linux board with the original one. but I couldn't find the problem because there are too many differences between them.
Other libraries seem to work well when using this board. Can you help me solve this problem?
(deleted)
understand. but same thing happened when I use v1.6.9IDE. It seems the arm linux board does not support the wire library.
