Wire.h in the ArduinoCore-megaavr misses signatures which are used in the ArduinoCore
In the megaavr core for the Every you see
size_t requestFrom(uint8_t, size_t);
size_t requestFrom(uint8_t, size_t, bool);
size_t requestFrom(int, int);
size_t requestFrom(int, int, int);
in the "Default" Wire.h from ArduinoCore-avr/Wire.h at master · arduino/ArduinoCore-avr · GitHub
uint8_t requestFrom(uint8_t, uint8_t);
uint8_t requestFrom(uint8_t, uint8_t, uint8_t);
uint8_t requestFrom(uint8_t, uint8_t, uint32_t, uint8_t, uint8_t);
uint8_t requestFrom(int, int);
uint8_t requestFrom(int, int, int);
This miss match can throw warnings in libraries using the interface according to the the Arduino-Core - which i consider as "standard" and how to do ...
example
#include <Wire.h>
void foo()
uint8_t address = 1;
Wire.requestFrom(address, (uint8_t)1);
Wire.begin();
brings
C:\Daten\myrepository\Arduino\Forum no SVN\sketch_sep18a\sketch_sep18a.ino: In function 'void foo()':
C:\Daten\myrepository\Arduino\Forum no SVN\sketch_sep18a\sketch_sep18a.ino:7:41: warning: ISO C++ says that these are ambiguous, even though the worst conversion for the first is better than the worst conversion for the second:
In file included from C:\Daten\myrepository\Arduino\Forum no SVN\sketch_sep18a\sketch_sep18a.ino:2:0:
C:\Users\werner\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\libraries\Wire\src/Wire.h:63:12: note: candidate 1: size_t TwoWire::requestFrom(int, int)
C:\Users\werner\AppData\Local\Arduino15\packages\arduino\hardware\megaavr\1.8.7\libraries\Wire\src/Wire.h:61:12: note: candidate 2: virtual size_t TwoWire::requestFrom(uint8_t, size_t)
I can't open an Issue on github, maybe some can hand over that ...
