Wire.h troubles
Hi
Could anyone please explain me why Wire.h library don’t work with Due but it works with mega2560?
When I try to compile (with Due) for example unmodified I2C-scanner by Mr Gammon, I only get error message “twi.c:25:20: fatal error: avr/io.h: No such file or directory” no matter which folder I try to copy such a file.
I’m using very version of Wire-library which is another attachment.
BR
  • Tommi
PS. I’ve tried IDE 1.6.0 and 1.5.8 so far.
I2C_scanner.ino (764 Bytes)
Wire.zip (54 KB)
Hi TommiP,
Each Arduino IDE 1.5.X and 1.6.0 contains its own Wire library under...
...\hardware\arduino\sam\libraries...
If you error comes from...
...C:\Users\xxx\Documents\Arduino\libraries\Wire\utility..
then you should remove that library.
p
Hi Palliser
Yes, that was the fault that I had Wire-library in my C:\Users... directory and it used the old one.
Thanks for help :)
-TommiP
