Wire has an easter egg? Max clock is 888888
I'm trying to implement the MCP4725 on the STM8S, but I haven't been able to yet, so I went to test the MCP4725 on the Arduino Nano. And I noticed that although the MCP4725 accepts up to 3.4MHz clock (using a slightly different protocol, High Speed), but the setClock() function managed to make it work with up to 888888, it seemed to me an interesting number.
    @file     sinewave.pde
    @author   Adafruit Industries
    @license  BSD (see license.txt)
    This example will generate a sine wave with the MCP4725 DAC.
    This is an example sketch for the Adafruit MCP4725 breakout board
    ----> http://www.adafruit.com/products/935
    Adafruit invests time and resources providing this open source code,
    please support Adafruit and open-source hardware by purchasing
    products from Adafruit!
#include <Wire.h>
#include "Adafruit_MCP4725.h"
//Adafruit_MCP4725 dac;
// Set this value to 9, 8, 7, 6 or 5 to adjust the resolution
#define DAC_RESOLUTION    (8)
/* Note: If flash space is tight a quarter sine wave is enough
   to generate full sine and cos waves, but some additional
   calculation will be required at each step after the first
   quarter wave.                                              */
const PROGMEM uint16_t DACLookup_FullSine_9Bit[512] =
  2048, 2073, 2098, 2123, 2148, 2174, 2199, 2224,
  2249, 2274, 2299, 2324, 2349, 2373, 2398, 2423,
  2448, 2472, 2497, 2521, 2546, 2570, 2594, 2618,
  2643, 2667, 2690, 2714, 2738, 2762, 2785, 2808,
  2832, 2855, 2878, 2901, 2924, 2946, 2969, 2991,
  3013, 3036, 3057, 3079, 3101, 3122, 3144, 3165,
  3186, 3207, 3227, 3248, 3268, 3288, 3308, 3328,
  3347, 3367, 3386, 3405, 3423, 3442, 3460, 3478,
  3496, 3514, 3531, 3548, 3565, 3582, 3599, 3615,
  3631, 3647, 3663, 3678, 3693, 3708, 3722, 3737,
  3751, 3765, 3778, 3792, 3805, 3817, 3830, 3842,
  3854, 3866, 3877, 3888, 3899, 3910, 3920, 3930,
  3940, 3950, 3959, 3968, 3976, 3985, 3993, 4000,
  4008, 4015, 4022, 4028, 4035, 4041, 4046, 4052,
  4057, 4061, 4066, 4070, 4074, 4077, 4081, 4084,
  4086, 4088, 4090, 4092, 4094, 4095, 4095, 4095,
  4095, 4095, 4095, 4095, 4094, 4092, 4090, 4088,
  4086, 4084, 4081, 4077, 4074, 4070, 4066, 4061,
  4057, 4052, 4046, 4041, 4035, 4028, 4022, 4015,
  4008, 4000, 3993, 3985, 3976, 3968, 3959, 3950,
  3940, 3930, 3920, 3910, 3899, 3888, 3877, 3866,
  3854, 3842, 3830, 3817, 3805, 3792, 3778, 3765,
  3751, 3737, 3722, 3708, 3693, 3678, 3663, 3647,
  3631, 3615, 3599, 3582, 3565, 3548, 3531, 3514,
  3496, 3478, 3460, 3442, 3423, 3405, 3386, 3367,
  3347, 3328, 3308, 3288, 3268, 3248, 3227, 3207,
  3186, 3165, 3144, 3122, 3101, 3079, 3057, 3036,
  3013, 2991, 2969, 2946, 2924, 2901, 2878, 2855,
  2832, 2808, 2785, 2762, 2738, 2714, 2690, 2667,
  2643, 2618, 2594, 2570, 2546, 2521, 2497, 2472,
  2448, 2423, 2398, 2373, 2349, 2324, 2299, 2274,
  2249, 2224, 2199, 2174, 2148, 2123, 2098, 2073,
  2048, 2023, 1998, 1973, 1948, 1922, 1897, 1872,
  1847, 1822, 1797, 1772, 1747, 1723, 1698, 1673,
  1648, 1624, 1599, 1575, 1550, 1526, 1502, 1478,
  1453, 1429, 1406, 1382, 1358, 1334, 1311, 1288,
  1264, 1241, 1218, 1195, 1172, 1150, 1127, 1105,
  1083, 1060, 1039, 1017,  995,  974,  952,  931,
  910,  889,  869,  848,  828,  808,  788,  768,
  749,  729,  710,  691,  673,  654,  636,  618,
  600,  582,  565,  548,  531,  514,  497,  481,
  465,  449,  433,  418,  403,  388,  374,  359,
  345,  331,  318,  304,  291,  279,  266,  254,
  242,  230,  219,  208,  197,  186,  176,  166,
  156,  146,  137,  128,  120,  111,  103,   96,
  88,   81,   74,   68,   61,   55,   50,   44,
  39,   35,   30,   26,   22,   19,   15,   12,
  10,    8,    6,    4,    2,    1,    1,    0,
  0,    0,    1,    1,    2,    4,    6,    8,
  10,   12,   15,   19,   22,   26,   30,   35,
  39,   44,   50,   55,   61,   68,   74,   81,
  88,   96,  103,  111,  120,  128,  137,  146,
  156,  166,  176,  186,  197,  208,  219,  230,
  242,  254,  266,  279,  291,  304,  318,  331,
  345,  359,  374,  388,  403,  418,  433,  449,
  465,  481,  497,  514,  531,  548,  565,  582,
  600,  618,  636,  654,  673,  691,  710,  729,
  749,  768,  788,  808,  828,  848,  869,  889,
  910,  931,  952,  974,  995, 1017, 1039, 1060,
  1083, 1105, 1127, 1150, 1172, 1195, 1218, 1241,
  1264, 1288, 1311, 1334, 1358, 1382, 1406, 1429,
  1453, 1478, 1502, 1526, 1550, 1575, 1599, 1624,
  1648, 1673, 1698, 1723, 1747, 1772, 1797, 1822,
  1847, 1872, 1897, 1922, 1948, 1973, 1998, 2023
const PROGMEM uint16_t DACLookup_FullSine_8Bit[256] =
  2048, 2098, 2148, 2198, 2248, 2298, 2348, 2398,
  2447, 2496, 2545, 2594, 2642, 2690, 2737, 2784,
  2831, 2877, 2923, 2968, 3013, 3057, 3100, 3143,
  3185, 3226, 3267, 3307, 3346, 3385, 3423, 3459,
  3495, 3530, 3565, 3598, 3630, 3662, 3692, 3722,
  3750, 3777, 3804, 3829, 3853, 3876, 3898, 3919,
  3939, 3958, 3975, 3992, 4007, 4021, 4034, 4045,
  4056, 4065, 4073, 4080, 4085, 4089, 4093, 4094,
  4095, 4094, 4093, 4089, 4085, 4080, 4073, 4065,
  4056, 4045, 4034, 4021, 4007, 3992, 3975, 3958,
  3939, 3919, 3898, 3876, 3853, 3829, 3804, 3777,
  3750, 3722, 3692, 3662, 3630, 3598, 3565, 3530,
  3495, 3459, 3423, 3385, 3346, 3307, 3267, 3226,
  3185, 3143, 3100, 3057, 3013, 2968, 2923, 2877,
  2831, 2784, 2737, 2690, 2642, 2594, 2545, 2496,
  2447, 2398, 2348, 2298, 2248, 2198, 2148, 2098,
  2048, 1997, 1947, 1897, 1847, 1797, 1747, 1697,
  1648, 1599, 1550, 1501, 1453, 1405, 1358, 1311,
  1264, 1218, 1172, 1127, 1082, 1038,  995,  952,
  910,  869,  828,  788,  749,  710,  672,  636,
  600,  565,  530,  497,  465,  433,  403,  373,
  345,  318,  291,  266,  242,  219,  197,  176,
  156,  137,  120,  103,   88,   74,   61,   50,
  39,   30,   22,   15,   10,    6,    2,    1,
  0,    1,    2,    6,   10,   15,   22,   30,
  39,   50,   61,   74,   88,  103,  120,  137,
  156,  176,  197,  219,  242,  266,  291,  318,
  345,  373,  403,  433,  465,  497,  530,  565,
  600,  636,  672,  710,  749,  788,  828,  869,
  910,  952,  995, 1038, 1082, 1127, 1172, 1218,
  1264, 1311, 1358, 1405, 1453, 1501, 1550, 1599,
  1648, 1697, 1747, 1797, 1847, 1897, 1947, 1997
const PROGMEM uint16_t DACLookup_FullSine_7Bit[128] =
  2048, 2148, 2248, 2348, 2447, 2545, 2642, 2737,
  2831, 2923, 3013, 3100, 3185, 3267, 3346, 3423,
  3495, 3565, 3630, 3692, 3750, 3804, 3853, 3898,
  3939, 3975, 4007, 4034, 4056, 4073, 4085, 4093,
  4095, 4093, 4085, 4073, 4056, 4034, 4007, 3975,
  3939, 3898, 3853, 3804, 3750, 3692, 3630, 3565,
  3495, 3423, 3346, 3267, 3185, 3100, 3013, 2923,
  2831, 2737, 2642, 2545, 2447, 2348, 2248, 2148,
  2048, 1947, 1847, 1747, 1648, 1550, 1453, 1358,
  1264, 1172, 1082,  995,  910,  828,  749,  672,
  600,  530,  465,  403,  345,  291,  242,  197,
  156,  120,   88,   61,   39,   22,   10,    2,
  0,    2,   10,   22,   39,   61,   88,  120,
  156,  197,  242,  291,  345,  403,  465,  530,
  600,  672,  749,  828,  910,  995, 1082, 1172,
  1264, 1358, 1453, 1550, 1648, 1747, 1847, 1947
const PROGMEM uint16_t DACLookup_FullSine_6Bit[64] =
  2048, 2248, 2447, 2642, 2831, 3013, 3185, 3346,
  3495, 3630, 3750, 3853, 3939, 4007, 4056, 4085,
  4095, 4085, 4056, 4007, 3939, 3853, 3750, 3630,
  3495, 3346, 3185, 3013, 2831, 2642, 2447, 2248,
  2048, 1847, 1648, 1453, 1264, 1082,  910,  749,
  600,  465,  345,  242,  156,   88,   39,   10,
  0,   10,   39,   88,  156,  242,  345,  465,
  600,  749,  910, 1082, 1264, 1453, 1648, 1847
const PROGMEM uint16_t DACLookup_FullSine_5Bit[32] =
  2048, 2447, 2831, 3185, 3495, 3750, 3939, 4056,
  4095, 4056, 3939, 3750, 3495, 3185, 2831, 2447,
  2048, 1648, 1264,  910,  600,  345,  156,   39,
  0,   39,  156,  345,  600,  910, 1264, 1648
void setup(void) {
  Serial.println("Hello!");
  // For Adafruit MCP4725A1 the address is 0x62 (default) or 0x63 (ADDR pin tied to VCC)
  // For MCP4725A0 the address is 0x60 or 0x61
  // For MCP4725A2 the address is 0x64 or 0x65
  //dac.begin(0x62);
  Wire.begin();
#define clockFrequency 888888
  Wire.setClock(clockFrequency);
  // set_dac_eeprom(2048); // Write EEPROM
  Serial.println("Generating a sine wave");
void set_dac(int value) {
  Wire.beginTransmission(0x62);
  Wire.write((value >> 8) & 0x0F);
  Wire.write(value & 0xFF);
  Wire.endTransmission();
void set_dac_eeprom(int value) {
  Wire.write(0x60); // write EEPROM
  Wire.write(value >> 4);
  Wire.write(value << 4);
  while(is_busy_dac()){
    Serial.println("DAC is busy");
int is_busy_dac(void){
  int value = 0;
  Wire.requestFrom(0x62, 1);    // request 6 bytes from peripheral device
  while (Wire.available()) { // peripheral may send less than requested
    value = Wire.read(); // receive a byte as character
  return value >> 7;
int get_dac(void) {
  int value = 0;
  int index = 0;
  byte x[5];
  Wire.requestFrom(0x62, 5);    // request 6 bytes from peripheral device
    x[index] = Wire.read(); // receive a byte as character
    index++;
  value = (x[1] << 4) + (x[2] >> 4); // DAC register Data
  // value = ((x[3] << 12) & 0xF00) + x[4]; // EEPROM Data
  return value;
void loop(void) {
  uint16_t i;
  // Push out the right lookup table, depending on the selected resolution
#if DAC_RESOLUTION == 5
  for (i = 0; i < 32; i++)
    //dac.setVoltage(pgm_read_word(&(DACLookup_FullSine_5Bit[i])), false);
#elif DAC_RESOLUTION == 6
  for (i = 0; i < 64; i++)
    //dac.setVoltage(pgm_read_word(&(DACLookup_FullSine_6Bit[i])), false);
#elif DAC_RESOLUTION == 7
  for (i = 0; i < 128; i++)
    //dac.setVoltage(pgm_read_word(&(DACLookup_FullSine_7Bit[i])), false);
#elif DAC_RESOLUTION == 9
  for (i = 0; i < 512; i++)
    //dac.setVoltage(pgm_read_word(&(DACLookup_FullSine_9Bit[i])), false);
#else    // Use 8-bit data if nothing else is specified
  for (i = 0; i < 256; i++)
    set_dac(pgm_read_word(&(DACLookup_FullSine_8Bit[i])));
//    Serial.print("set_dac:");
//    Serial.print(pgm_read_word(&(DACLookup_FullSine_8Bit[i])));
//    Serial.print(" get_dac:");
//    Serial.println(get_dac());
    // dac.setVoltage(pgm_read_word(&(DACLookup_FullSine_8Bit[i])), false);
    //delay(1000);
#endif
Ref.: How to make Arduino do High Speed I2C - Electrical Engineering Stack Exchange
You're saying 888889 fails?
Yep! :rofl:
Did you try heating or cooling the IC?
It comes down to these lines in the utilities:
void twi_setFrequency(uint32_t frequency)
  TWBR = ((F_CPU / frequency) - 16) / 2;
Likely there is a clue there. Yep. There is. :grin:
Good idea! :sunglasses:
Wire.setClock(x) just calls twi_setClock(x).
 * Function twi_setClock
 * Desc     sets twi bit rate
 * Input    Clock Frequency
 * Output   none
  /* twi bit rate formula from atmega128 manual pg 204
  SCL Frequency = CPU Clock Frequency / (16 + (2 * TWBR))
  note: TWBR should be 10 or higher for master mode
  It is 72 for a 16mhz Wiring board with 100kHz TWI */
I'm surprised that 888888 works. If TWBR should be at least 10, Frequency should be no higher than 444444.
Are you saying the Easter egg is rotten?
It happens because of a strange (at least to me) coincidence, 18x888888 is 15999984, almost the CPU frequency.
Prime factoring 888888 didn't really help me. 2, 2, 2, 3, 7, 11, 13, 37
and 16MHz = 2, 2, 2, 2, 2, 2, 2, 2, 2, 2, 5, 5, 5, 5, 5, 5
I'm not a Mensa type really, so I'll leave it there.
And clocked at 888888 the MCP4725 did over 9kHz :sweat_smile: using this useless code:
  while (1) {
    Wire.write(0x0F);
    Wire.write(0xFF);
    Wire.write(0x0);
    Wire.write(0x0);
I also found it interesting that the MCP4725 accepted up to 16 data values in sequence, would it be too much to ask for it to be infinite? :stuck_out_tongue_winking_eye:
  while (1) {
    for (int i = 0; i < 8; i++) {
      Wire.write(0x0F);
      Wire.write(0xFF);
      Wire.write(0x0);
      Wire.write(0x0);
