Wire Interface Example
This question is regarding examples from the Wire library, written by Nicholas Zambetti http://www.zambetti.com.
In this example (master_reader.pde and slave_writer.pde), the master requests 6 bytes from slave 2.
  Wire.requestFrom(2, 6);    // request 6 bytes from slave device #2
Somewhere the number of bytes requested gets thrown out. On the slave side you see:
// function that executes whenever data is requested by master
// this function is registered as an event, see setup()
void requestEvent()
  Wire.send("hello "); // respond with message of 6 bytes
                       // as expected by master
Is there any way to recover the number of bytes requested?
Thanks,
Justin
No, the Wire lib does not provide such info so you must use a local var for it.
int x = 6;
int y = Wire.request(2, x);
// x will hold the nr of bytes requested
// y will hold the nr of bytes actually read.
Check the library for details : - C:\Program Files (x86)\arduino-0021\libraries\Wire (my windows).
Bearing in mind that the Wire library supports a maximum of 32 bytes per transmission, I think there are two ways you can do this.
The first is, as part of the initial send, tell the receiver how many bytes you want, eg.
  Wire.beginTransmission (SLAVE_ADDRESS);
  Wire.send (1);  // do action 1
  Wire.send (6);  // and I want 6 bytes back, thanks!
  Wire.endTransmission ();
  Wire.requestFrom(SLAVE_ADDRESS, 6);    // request 6 bytes from slave device
Now the slave reads those two bytes and knows it has to perform action 1 (whatever that is) and limit its response to 5 bytes.
Alternatively, I think you could just request a response, eg.
  Wire.requestFrom(SLAVE_ADDRESS, 32);    // request up to 32 bytes from slave device
  while (Wire.available () > 0)
   // process each byte
    } // end of while
And then just use Wire.available to know how many bytes the slave sent back.
Thanks. I'll give these ideas a try.
Justin
