Wire Interruption - I²C
I’m doing one library to use the arduino as a slave, and the NXT as master.
But, doesen’t matter what i do, if i send one request from the NXT or send only data, the interruption always goes to onReceive Handle.
I wan’t to be able to respond with data and read data from i²c master, but enter in receive always, never request…
I want to respond with data, and read data according to the request.
Look at my code:
#include <Wire.h>
  Wire.begin(5);
  Wire.onRequest(requestEvent);
  Wire.onReceive(receiveEvent);
  delay(100);
void receiveEvent(int howMany)
  int A=0,B=0;
  Serial.print("REQUEST - ");
  Serial.print(howMany);
  Serial.println(" - ");
  while(1<Wire.available())
    A = Wire.receive();
  B = Wire.receive();
  Serial.print("*A: ");
  Serial.println(A);
  Serial.print("*B: ");
  Serial.println(B);
//NEVER enter here, only on receiveEvent
void requestEvent()
  int A=0,B=0;
  Serial.print("RECEIVE - ");
    A = Wire.receive();
  B = Wire.receive();
  Serial.println(A);
  Serial.println(B);
Sounds like the problem may be on the master not the slave then, do you have another Arduino that you could set up as a master first to rule out the slave? Also why are you trying to receive data in requestEvent?
Request event also sent a register, that should be read by slave and sent back to master. That register is the data... Is there a better way to do that? I'm very confused with this communication, with PIC i did and everything went good, but i didn't succeded now... I will try to see the master code, might be the problem. My others 4 arduino nanos didn't arrived yet, so i can't debug with them. Thanks, Ivan
