Wire Lcd Display
Hi!
I want to connect a lcd display to my Arduino Nano 33 IoT. I did everything as described in the datasheet:
And wrote this code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(2,4, 8, 9, 10, 11);
  lcd.begin(16, 2);
  lcd.setCursor(0,0);
  lcd.print("Hello");
Unfortunately the display isn´t showing anything. I don´t really know what´s wrong. Hopefully you can help me.
Thanks in advance!
Can you tell which datasheet that is ?
Which display is it ? Most LCD displays are for 5V boards, such as a Arduino Uno.
I think that there should be a potentiometer or a resistor to control the contrast.
this is the Link to the datasheet. I know I saw some videos, but unfortunately I don´t have a potentiometer or resistor at home.
It is an error in the datasheet. The pot is shown in the connection diagram for raspberry pi, but not shown in the connection diagram for Arduino. The pot is always required.
Well you are not in a very good position to do anything with Arduinox or displays then, are you? :astonished:
Just to start with, connect pin 3 on the display ("Vo") to ground. You should get a display. Later, you will want a 1k (not a 10k) potentiometer to connect one end to ground and the wiper to "Vo" to adjust the contrast.
Or just as readily, get a multi-resistor pack which should only be a few dollars and try a few values such 120, 220, 330, 470, 680 or 1k Ohms between "Vo" and ground.
I might just add that the idea of connecting "Vo", pin 3 of the display to PWM "pin 3" on the Arduino is a rather stupid idea someone had to "imitate" a potentiometer. It never works - except when you set the PWM value to zero and the pin is thereby effectively grounded in a rather silly fashion.
This topic was automatically closed after 120 days. New replies are no longer allowed.
