Wire lib operations both inside & outside an ISR causes system hanging
MCP4725 (DAC) and MPR121 (touch sensor) both are on i2c bus using the Wire lib.
The code below outputs a voltage sweep. If I fly my finger on the mpr121 pads (triggering ISR), it can easily hang the whole thing. Any help appreciated! Thanks!
#include "mpr121.h"
#include <Wire.h>
#include <Adafruit_MCP4725.h>;
Adafruit_MCP4725 dac0;
  attachInterrupt(4, readTouchInputs, FALLING);
  Wire.begin();
  dac0.begin(0x62);
  mpr121_setup();
  for (int i = 1000; i < 4095; i++) {
    dac0.setVoltage(i, false);
void readTouchInputs() {
  sei();
  Wire.requestFrom(0x5A, 2);
  dac0.setVoltage(random(0,4095),false);
Generally, in an interrupt routine, doing anything much more complicated than setting a flag is dubious practice. Try refactoring your code to use a volatile flag variable and check it in your for loop.
Turning interrupts on in an ISR is generally NOT a good idea. Deal with the interrupt and get out. Then, allow the other interrupts to happen.
Thank you for the help! Now I've rewritten the code (just setting a flag), now it runs no problem. 8)
