Wire library and EEPROM
Hello. I'm trying to work with EEPROM using I2C (my chip is 24LS256). I use Wire library and I should not use EEPROM library. It works properly with EEPROM library but doesn't work by Wire. This problem has been resolved many times and a lot of solutions are presented in internet, althought not all are correct. Newertheless my code doesn't work and I don't know how make it work. Here is my code for Arduino
#include <Wire.h>
#include <EEPROM.h>
int ptr = 0;
int mem_cell_num=100;
const int devadress=0x50;
   Wire.begin(); // ??????????? ? ???? i2c
   byte a=Serial.read();
  if (a==0xA1)
     byte val = 0;
     Wire.beginTransmission(devadress);
     Wire.write((int)highByte(mem_cell_num));
     Wire.write((int)lowByte(mem_cell_num));
     Wire.write(val+4);
     Wire.endTransmission();
     delay(10);
     Wire.requestFrom(devadress+1,1);
     while(Wire.available()==0);
     val=Wire.read();
     Serial.write(0xC0);
     Serial.write(val);
     EEPROM.write(ptr, val+4);
     val= EEPROM.read(ptr);
     if(val>0)
        Serial.write(0xC0);
        Serial.write(val);
Code with EEPROM library works but Wire. I tried to read from the same adress i.e. Wire.requestFrom(devadress,1); I would be vary appriciate if anybody point me the possible reason.
Shouldn't requestFrom() use the same device address as the other calls? Why devadress+1?
I don't think the (int) casts are necessary, but I'm not sure they'd be a problem either.
Yes, it should. I also tried so. Still doesn't work. Adresess 0x55, 0x57, 0x54, 0x56 are also checked with the same result.
Ah right I see where you said that now.
So what output do you get?
I listening serial port by my PC program. When I use EPROM then answer is correct, I get 4, but in case with Wire, i dont have an answer, because arduino waiting a byte in while(Wire.available()==0);
I'd start by checking the return values from the endTransmission() calls. What return values do you get?
I think the 10ms delay should be long enough, but I can't find a datasheet for a 24LS256 so I can't be sure. Is that the right part number? Do you have a datasheet? I have a datasheet for a 24LC256 and it says 5ms for the write time. I might try a test with 50ms. Polling as described in the datasheet might be a better option.
PS: I believe the EEPROM should have three address pins (A0, A1, A2). How are they wired?
That line is not necessary. See: Gammon Forum : Electronics : Microprocessors : I2C - Two-Wire Peripheral Interface - for Arduino
There was a recent thread about reading stuff back. Read this:
http://forum.arduino.cc//index.php?topic=192952
Please post your amended code. You should requestFrom the same address you wrote to.
Please run the I2C scanner on this page and report the results.
I tried your code and it works. Like Nick said, the while statement can be eliminated, but neither does it cause a problem. I did change the input character that starts the write process and also the way the output was sent so I could read it on the serial monitor. So run the I2C scanner as Nick suggested, check your wiring, address pins on the EEPROM, etc.
#include <Wire.h>
#include <EEPROM.h>
int ptr = 0;
    if (a=='g')
        byte val = 0;
        Wire.write(val+4);
        delay(10);
        val=Wire.read();
        Serial.print(mem_cell_num);
        Serial.print(' ');
        Serial.println(val);
         if(val>0)
         Serial.write(0xC0);
         Serial.write(val);
Thanks a lot for your helping, guys. I did it as you recomended, but it brought no progress. Howewer, I observed an amazing thing. I run I2C scanner and found 4 devices with addresses 0x50, 0x51, 0x52, 0x53. But is should be only 0x50, judging by wiring. May it be the result of a closing caused by unaccurate soldering? While was removed because Wire.available() does not return result. Here is my corrected code:
#include <Wire.h>
#include <EEPROM.h>
const int a0=70;
const int a1=130;
int ptr = 0;
   Wire.begin();
  if (a==0xA1)
     byte val = 4;
     Wire.write ((int)lowByte(mem_cell_num));
     Wire.write(val);
     if(Wire.endTransmission()!=0)//OK
         //send error code if fail
        Serial.write(0xC0);
        Serial.write(13);
     delay(5);
     if (Wire.endTransmission()!=0)//OK
        Serial.write(0xC0);
        Serial.write(15);
     if (Wire.requestFrom(devadress,1)==1)//FAIL
       //send data if success
       val=Wire.read();
       Serial.write(0xC0);
       Serial.write(val);
     ptr = ptr + 1;
     if (ptr == 512)
       ptr = 0;
     if(val>0)
        Serial.write(0xC0);
        Serial.write(val);
Seems like it would just about have to be hardware, like I said, the previous code works for me. At this point it would be good to have a schematic and a picture of the circuit.
I'm still confused about the chip you're using, you say it's 24LS256, I can't find that on Mouser, Digikey, etc. I tested with a 24LC256. Do you have a link to a datasheet or where you got this chip? The scanner only returns 0x50 for me, I have pins 1, 2, 3 (A0, A1, A2) grounded.
Oh, sorry. There was a misprint. I meant 24LC256 .
How are the address pins wired?
Just on a lark, I disconnected the address pins (A0, A1, A2) and let them float. (Not recommended by the datasheet.) Running the scanner multiple times, all I could get was 0x50. Tried two different chips, one a 24LC256 and one a 24FC256, and even tried grabbing onto the address pins, no change. More robust than I might have thought. They must have pulldown resistors.
A0, A1, A2 connected each other and ground.
Can you describe what pull-up resistors you have connected to SDA and SCL?
4,7 kilohm
Let's see a photo of what you've done. A nice sharp one.
