Wire library, linking arduinos programming question
Hello everyone, I'm working on a color tracking, obstacle avoiding robot for a class project and need a little help understanding the programming link between the two arduinos. Just to make sure, the
void recieveData(int howMany){
  int c=Wire.read(); //Confidence from the CMUcam4
  int a=Wire.read(); //X position of the object via the CMUcam4
  int b=Wire.read(); //Y position of the object via the CMUcam4
  int p=Wire.read(); //Pixel density from the CMUcam4
  float cm=Wire.read(); //distance measurements the Ping sensor on the master
section of code works just like any other loop right? so I can call this when I need in my void loop to obtain the latest set of data being transmitted from the master arduino?
c, a, b, p, and cm are local variables that go out of scope when the function ends. Wire.read returns a byte (an integer type value). Storing that in a float won't make it a 4 byte float value.
